mpeg 4 packet ( like BIG TV )MEASAT | |
| | #3 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | You can buy an MPE4 CAM what is mpeg 4? how to recieve?
__________________ | |||
| Member Join Date: 28-04-2008 Location: sollentuna sweden
My System: cm120 | an mpeg4 cam is just like putting hd ready on an lnb or it might be that some older cams are not capable of processing the datarates needed for mpeg4, in short you need a mpeg4 decoder somewhere, your sat box doesn't have the cpu power, if it had it would be marked so i have recorded mpeg4 from sat and played them on my pc, works fine | ||
