Nilesat 101 at Kigali | |
| Member Join Date: 17-02-2008 Location: Rwanda
My System: panamsat and xp |
I am situated at Kigali-Rwanda-Central africa- at 30East. I wanted to whether it is possible to capture Nilesat 101 at Kigali. If then wat should be the Dish size of the antenna | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Here's the footprint _http://www.lyngsat-maps.com/maps/nile101.html you are quite a way outside it, but it would be possible with a big enough dish.
__________________ | |||
| The Following User Says Thank You to rolfw For This Useful Post: | bijucvarghese (22-05-2008) |
I have seen thathe page but no idea what should be the minimum size of the dish especially since it is a ku band. please send replies to email address removed | ||
| | #4 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Please do not ask for stuff to be sent to an email address - non personal info should be available to all our members - you never know there may be someone else in Kigali looking for the same info!
| | #5 | ||||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | So extrapolating the footpint mapyou are probably looking at a minimum of 3m diameter, possibly much bigger
__________________ | ||||
| | #6 | ||
| Specialist Contributor Join Date: 28-05-2003 Location: Stuttgart (48.79N/9.19E)
My System: Kabel BW | Some months ago i read about 7W reception in Addis Abeba Ethiopia. 3m dishes are needed there so expect at least this size not even much bigger. Maybe you cannot receive 7W at all. Without a test nobody can tell you for sure. You can get in contact with some people in Africa using bigger dishes here: _http://www.rdi-board.com/showthread.php?t=36090 26E C-Band reception is possible down to South Africa. I know it's a poor alternative but you are far outside the 7W/26E Ku footprints.
__________________ I demand: Pay-TV subscriptions worldwide available - with any receiver - just like print magazines ! Free access for free citizens now ! | ||
| | #7 | ||
My System: panamsat and xp | thank you for your support. I was trying to capture Nilesat in order to watch the channels in ADD package, since i am interested in some indian channels in there. Does anybody can suggest an alternative | ||
| | #8 | ||
My System: Kabel BW | Oh i see. I cannot recommend which indian channels can substitute those of the ADD package but there are indian channels that you should be able to get over 68.5E: http://www.lyngsat.com/intel10.html. 76.5E carries some Bangla channels and you should get it since i know somebody in Gabon gets it. 78.5E has been received in Lubumbashi some years ago on 3.70m. It's hard to say if 83E/93.5E/105.5E can be gotten as well with big dishes. The only easily to get satellite in Rwanda carrying indian content i found is 7E with http://www.lyngsat.com/packages/gtvew3a.html but i have no idea how to get this package and how expensive it is. You should get strong signal on a 1m dish if the footprint shows the real conditions.
| | #9 | ||
My System: panamsat and xp | thank you so much. Those are not channels that i am looking for. Channels like asianet and Kairali which is found in ADD package as well as in Tatasky in insat4A.Seconldy i see that these channels are available in south africa by insat12, and i donot know how, who are all the providers. | ||
| | #10 | ||
My System: Kabel BW | Ok, let's see: Asianet transmits for SA at 72E: http://www.lyngsat.com/intel4.html and for the rest of the world here: http://www.lyngsat-address.com/ab/Asianet.html Kairali is not officially available in Africa: http://www.lyngsat-address.com/gk/Kairali-Ch.html Here's a list of all indian channels Lyngsat has listed: http://www.lyngsat-address.com/tv/India.html Well, since i don't believe any footprints any more after such all extreme out of footprint cases, if you have the chance to test a really big dish, say 3-5m i would do it. I mean testing before buying because if you don't get anything all the money would be out of the window as we use to say here in Europe. But as there are people in the rdi board, some of them not too far from you (Kenya, Somalia and Tanzania) i would give a try and ask there.
| | #11 | ||
My System: panamsat and xp | thank you once again. What is that atlantic 4 -7.2 west with middleast beam just near by rwanda, and also i see one nilesat on that. Can i try to get some channels on that. thank you | ||
| | #12 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | The Atlantic Bird 4 steerable beam: _http://www.eutelsat.com/satellites/7wab4_popd.html# is a possibility for you. However theres not much on it.... The outer 40dBW line means about a 120cm dish is needed in the outer fringe area..
| | #15 | ||
My System: Kabel BW | At 7W there are 3 Satellites: Nilesat 101, 102 and AB4 AB4 has just 1 frequency (10758V) on the Middle East Beam as you can see here: http://www.lyngsat.com/ab4.html but the channels on it aren't interesting as far as i know. No indian content so far there.
| | #17 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | If you cant get the Nilesats on a 3.5m dish you may as well give up - theres not many dishes bigger available to the hobby market - 4.2m is about the biggest available.....
| | #18 | |||
My System: Kabel BW | 7.0W (Middle-East) 2008-05-19 21:29:38 madi22 (-,0cm) ? bangui-center africa Correct reception from tps: 10719V , 10834V, 10796V, 10911V, 10873V, 12341V;incorrect from 10853H, 10892H,10930H, with 310cm in bangui i need help source: http://en.kingofsat.net/beams.php
__________________ I demand: Pay-TV subscriptions worldwide available - with any receiver - just like print magazines ! Free access for free citizens now ! | |||
| | #19 | |||
| | #20 | ||
My System: Kabel BW | You're right, this is AB4, but i thought it would be of interest. So the chances are very low if it was a solid 3.5m.
