South Beam Sky | |
| Member Join Date: 08-08-2008 Location: Devon
My System: FTA and Sky. Fixed dish and motorhome fixed dish | I understand that if you retune a skybox to the south beam it is possible to get better coverage in parts of Spain. I know how to do this. However, will a free to air receiver also be able to receive channels on the south beam automatically. Or is this south beam thing peculiar to Sky? Sorry if this is a totally nieve question but I'm learning. I have a 66cms dish, a Pace skybox and an SL30 free to air receiver. | ||
| | #2 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Every satellite has one or more satellite footprints. The satellites at 28E that Sky uses have at least 10 different coverage footprints! Astra 2A - 2 Astra 2B - 2 (plus a Nigerian beam!) Astra 2C - 2 Astra 2D - 1 Eurobird 1 - 3 (one of which isnt used for anything much atm) Each beam will be received at different strengths in different area - in the UK all are received with good strength as thats where the signal is destined for. In Spain the Astra 2D beam is very weak, and the Astra 2A & 2B north beams arent very good either. Sky doesnt own the satellites - they just rent capacity on it so no the south beam isnt peculiar to Sky - if for no other reason the same channels are being used for the new Freesat service!
__________________ | |||
| | #3 | |||
| Regular Member Join Date: 05-04-2008 Location: Gandia, Spain
My System: 1.8m Famaval PF Dish, Pace 3100, 2600, 430, freesat Humax HD, Freesat Grundig, 0.8m illusion motor, Dreambox DM7025 |
this process is only used to help the sky box boot up, it does not increase the amount of channels you get or increase the signal strength of the channels on the sky guide. a freesat box looks at a signal that is easily available in spain (eurobird) , so you dont need to change anything on them. non sky or freesat boxes just look at the channels directly, without anything like the sky guide or freesat epg... hope this helps | |||
| Information Exec Join Date: 07-05-2007 Location: Midlands - UK and Lanzarote - Canary Islands
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | A major factor depends on what region in Spain you are located in. The default Tp only applies to Sl<y receivers in order to get the full EPG to function. You should be able to pick up South beam with a 50cm dish, see South beam footprint: _http://www.lyngsat-maps.com/maps/astra2a_south.html If your going to use a Sl<y receiver, when you first power on, you'll know if your able to pull in North beam as the EPG will function or not. Dish size depends on your region. As said above, the box tries to look at 11.778 North beam. If it can't see the transponder, the box does nothing and says 'no sat signal being received' See North beam footprint: _http://www.lyngsat-maps.com/maps/astra2a_north.html Full instructions to change default transponder if required: To change the default transponder setting, you will first need to access the hidden INSTALLERS SETUP menu First press the SERVICES button on your Sky remote then '4' to access SYSTEM SETUP Although it is not displayed, you will need to press '0' then '1' then SELECT to access the INSTALLERS SETUP menu then select '2' to enter DEFAULT TRANSPONDER Select 'Frequency (GHz)'. By typing in the relevant numbers, change the settings from 11.778 to 12.129 When the changes have been made, select 'Save New Settings' Press BACK UP to return to main screen On the screen you will then see the Sky Welcome Channel or it will say 'searching for listings' please wait Wait until Sky Welcome Channel appears and then start viewing Upon return to Northern Europe, the system will automatically default back to the North beam default transponder frequency.
__________________ - .....A Detailed DiSEqC Motor Installation Set Up Guide HERE Motor Installation 'Quick' Reference Guide also HERE Satellites UK site Advertisers - | ||
| The Following User Says Thank You to satelliteman For This Useful Post: | evans88 (08-08-2008) |
| | #5 | ||
| Regular Member Join Date: 29-12-2007 Location: Cornwall, UK
My System: Sky Freesat in UK, Astra 1 ana/dig in UK, Astra 2 South Beam in Spain. | Can I just add to the excellent answers you have already received evans88, that the following site might be useful for you in setting up your dish and receiver in your motor home:- http://homepage.ntlworld.com/de.sullivan/ | ||
