Dish size for.... Badr6 in the uk & europe
Thread Tools Display Modes
Old 18-08-2008   #1
Design Engineer/Installer
pedro2000uk's Avatar
My System: 75e-75w C & KU, 36v diseqc Anlg to HD Channel Master C120 dishes, stbs, lnbs, motors, too much to list
Now that the dust has settled (hopefully) over these first BADR6 TP/ Channel changes, we're seeing really dead TPs from that bird - below noise - usually you'd expect to see a below lock / but above background noise signal - but there is almost nothing and worse than 7w H's.
So .. has anyone got a lock in the UK yet on a big dish on BADR6... ?
pedro2000uk is offline   Reply With Quote
Old 18-08-2008   #2
Site administrator
Analoguesat's Avatar
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S
Ive seen reports that 1.5m is required in Bavaria. No signal on a 1.2m elsewhere in Germany (no exact location given)
__________________
Analogue forever!
RIP BBC2 analogue on all Scottish Borders transmitters, switched off 0031GMT November 6th 2008
Final analogue switch off from all Scottish Borders transmitters - BBC1 ITV C4 & C5 - 0010GMT November 20th 2008.
Analoguesat is online now   Reply With Quote
Old 18-08-2008   #3
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband!
with gregory 90 cm i have same transponder then with grgory 1,25m that means 1,50m is not enough!
you need 2 meter++
to reveive 11900 V for example!
the last 3 transponder in the lyngsat list also with gregory 1,25m no signal all other works find
this is only short channel list at the moment,i dont know when badr 6 will acticated more transponders and whats on there!
Turok is offline   Reply With Quote
Old 18-08-2008   #4
Rd100
Posts: n/a
I am pulling in the badr6 no problems at all I have a1.8m prodelin on 26 east which i also use for eurobird2 25.5 east
Old 18-08-2008   #5
Thanks RD ....
...How does BADR6 compare with 7w Hs on that dish there?
We are about 100 miles further away from the footprint so it still could still be 2.4m here considering how it can drop off so fast going north like Nilesat.
Old 18-08-2008   #6
Turok's Avatar
how good is the signal in wales,on the analoguge channels in cband?
euronews etc?
how much treshhold extension do you need?
is there any difrents in the signal strenth day/night sunshine/cloudy weather?
Old 19-08-2008   #7
Rd100
Posts: n/a
At the moment i only have 3 dishes set up 80cm on astra 28.2 east and 2x prodelin 1.8m rdishes 1 on 7w and the other on 25.5/26 east,
The signal is fine on both 7w and badr6 and eurobird2 it is raining very hard here tonight and the signal from badr 6 is fine
euronews etc?
The Following User Says Thank You to For This Useful Post:
pedro2000uk (19-08-2008)
Old 19-08-2008   #8
My System: Kabel BW
Here's how the situation looks like in Italy:
_http://www.digital-forum.it/showthread.php?t=59849
Western Europe is extremely priviledged for Badr 6. I have not finished in doing research what's going on in Eastern Europe but can tell you that Badr 6 is very weak even in Northern Greece.
__________________
I demand: Pay-TV subscriptions worldwide available - with any receiver - just like print magazines !
Free access for free citizens now !
deepbluesky is offline   Reply With Quote
Old 28-08-2008   #9
Looks like 11823v is yet another tp that's going over to badr6 but is still on its old tp and too strong for BADR6 only ... until it's switched off.
A member on DS has 11727h & 11804h as the stronger BADR6 tps on a 1.2m near Heathrow and our first measurements agree.
The strongest BADR6 tps here (mid UK) are:
11727h 30%
11747v 25%
11804h 30%
11823v n/a....
11843h 25%..
11862v 30%
11900v 26%.. new
For reference:
12183h was at 76% (max recorded peak 85%) 11919h was about 63% last evening test. All badr6 tps peak values only and are no lock on a 1.1m triax x tms 1000 x silvercrest (lidl) .2 lnbf x 30mt decent copper/ copper 100 cable...mid UK location - quite busy 26e line of sight ...trees/ roofs chimneys/ aerials etc.
39- 40% is usually lock level on the tms- far too busy to try it on other dishes/lnbs or even tweaking at moment and haven't tried for the C band yet either- again far too busy.
Judging by those peak values it might just be a do-er without going 8m.
__________________
xxxxo0O0oxxxx
ONLINE STORES THAT HELP SUPPORT THIS FORUM
Old 06-09-2008   #10
My System: fortec-star 1.2 dish nokia 9600 with dvb2000 software strong analogue receiver to move dish strong 4375 receiver fortec-star 1500 plus+ultra manhatten lt-7600 analogue receiver for c-band on arab sat 1224 heavy duty htoh motor titanium 0.2 lnb
hi all i tried this bird yesterday in heavy wind and rain this is what i received,11727h and 11747v 38% quality,11804h,11862v and 11900v 42% quality,11823v 75% quality and11843h 25-30% quality no lock.
pride21 is offline   Reply With Quote
Old 06-09-2008   #11
My System: Kabel BW
On 1.20m only ?!!
__________________
Old 07-09-2008   #12
hi deepbluesky yes thats what i said on a 1.2mtr offset dish and a 0.1 lnb
Old 07-09-2008   #13
My System: Kabel BW
50.3N and only 1.20m for Badr 6 !!
I really wonder if there is any other region on the same latitude that gets it so easily. Probably in the Eastern Ukraine but i haven't seen any reports yet from there.
Thanks for your very useful report pride21.
__________________
Old 07-09-2008   #14
SatSearcher's Avatar
My System: 1.2M Channel Master, C120 Invacom 0.3 LNB & Feedhorn, with Humax HDCI2000. 68.5E - 61W
Thats really good going getting signal from BADR 6 on just a 1.2m dish, and in windy and rainy conditions! I get absolutely nothing with same size dish in west yorkshire, regardless of weather conditions!
SatSearcher is offline   Reply With Quote
Old 07-09-2008   #15
pictures
here are pictures i got today with no rain
Old 07-09-2008   #16
Thanks for the photos/ reports... that 11823's high .. the others are about what you'd expect considering where you are....mind you it's lousy weather too
__________________
xxxxo0O0oxxxx
Old 07-09-2008   #17
My System: Kabel BW
Many thanks for the screenshots.
__________________
Old 08-09-2008   #18
Rd100
Posts: n/a
Just put a 1.0m andrew on 26'e with lnb-f and receiving badr-6 no problem some transponder are weak but no signal brake up
Old 08-09-2008   #19
Rd100
Posts: n/a
pride can you receive any thing from eurobird2 25.5 east
Old 08-09-2008   #20
hi rd i tried this bird today all i got was 11009v,11075v and 11585v
Old 21-09-2008   #21
My System: Arabsat - 26 east 1.1m dish
i live in london with a triax 1.1 dish but still cant recieve the 11 843
satellites08 is offline   Reply With Quote
Old 22-09-2008   #22
My System: 3.7 MESH
at
CIVITANOVA central italy
11804 h not compare in any case
other tp ok
with a good margin
12455 h for example is good
but the only one that is DIE is 11804 h
i dont know
P. GRANDICELLI with 1,8 m FIBERGLASS DISH in CENTRAL ITALY
paul682 is offline   Reply With Quote
Old 04-10-2008   #23
My System: FERGUSON 8900 120CM DISH SKY HD IPBOX 422s
any chance of receiving eurobird 25.5e with a 1.2m dish?
orb8 is offline   Reply With Quote
Old 04-10-2008   #24
Information Exec
satelliteman's Avatar
Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N
Here's the footprint:
_http://www.lyngsat-maps.com/maps/eb2_fixed.html
__________________
A Detailed DiSEqC Motor Installation Set Up Guide HERE
Motor Installation 'Quick' Reference Guide also HERE
Old 04-10-2008   #25
My System: Skystar 2.3i 7W-5E-13E-25.5E-26E-36E-40E-42E-53E-75E-90E
60cm triax dish. All TP OK from that sat, only die in very very dense rain.
Can you please explain me, why you trying to receive this satellites so hardly? any interesting shows there?
BombedOne is offline   Reply With Quote
[IMG] code is Off
Forum Jump
