Megasat LNB's | |
| Member Join Date: 25-11-2007 Location: Lincoln UK
My System: Fortec Star Zeta Receiver, Fraccaro 85cm motorized Dish | Does anyone have any experience with these (Megasat) LNB's? A signal to noise ratio of 0.1 db seems to be exceptional, and are they really any better in poor weather conditions compared to other LNB's? I'm looking to get the best possible signal/Quality from an 85cm fraccaro dish looking at BADR3,4. I already recieve MBC but it's a bit twitchy and I am looking for any improvements that I can make without going to a bigger dish. My location is Lincoln in the UK. | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
I am not aware of any major engineering leaps in the design manufacture and production of lnbs in the past five years. Quite honestly the only major difference is the different methods each manufacturer uses to measure then brag about the performance of their lnb not allowing the consumer to make a direct comparison . Unless someone does a direct contrast and compare exercise with that lnb against another of a particular known quality you will not get an answer.
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| The Following User Says Thank You to Topper For This Useful Post: | divibi (27-08-2008) |
| | #3 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Which LNB are you using at present?
__________________ | |||
| | #5 | ||
| Member Join Date: 08-01-2008 Location: Sweden
My System: WaveFrontier T-90 16LNB Cathing 18 birds 22w-33e Dreambox7020 HDD 5 Spaun 420 1 SPAUN 410 In the satworld since 1991 | Hi For a year ago i made a test of ca 15 universal LNB. I also tested the Megasat Diavolo Single 0,1dB. In my simple hometest i find that the Megasat was one of the most crappy i ever tried. The 0,1dB is just a way to sell, dont take that serius. I dont know if its allowed to put up link to another forum So i put up some of the info here. I did my test on my T-90 and 4w and a Dreambox 7020 This i not a hightech test,just made at home. 1 MTI High Line AP8-T2NRC 0,2dB 0 Maximum V-1 0,2dB Bad quality 5 of 12 broken in 9months 2 Smart Titanium 2nd Ed TSG 0,2dB 3 Golden Interstar GI-201 0,3dB 4 Smart Titanium Edition TSX 0,2dB 5 Alps BSTE8-751B 0,4dB 6 Echosat 0,2dB 7 Digistar SF-1 0,5dB Used 8 Megasat Diavolo 0,1dB 9 MTI BlueLine AP8-T2B 0,6dB Used, 4 years old 10 MTI AP8-T2 0,6dB Used 11 Inverto SilverTech 0,2dB 12 Alps BSTE8-851A 0,6dB 13 Invacom SNH-031 0,3dB 14 Gold Edition 0,3dB Last edited by Hakon; 28-08-2008 at 09:33 AM | ||
| The Following 2 Users Say Thank You to Hakon For This Useful Post: | Chesters (28-08-2008), pedro2000uk (28-08-2008) |
