Seriously big dishes, are they one-piece? | |
| Regular Member Join Date: 26-07-2005 Location: London
My System: dvb-s pci card 85 cm offset dish |
Hello, I have no immediate need to know, but for the sake of knowledge and curiosity ; do dishes like 6,50m 7,50m, 9,30m Andrew, 10m Siemens (that Turok mentioned), 15m RSi Vertex come with a solid ONE-piece reflector surface? Personally, I would always go for single piece dishes. So far I only came across info about one Turkish solid 1- piece spun aluminium 6,20m dish. But I also read that dishes over 5,00m should or must be made of steel and a big aluminium dish could quickly deteriorate in colder climes.Additionally, I read that Klaus Schumacher from southern Brazil made his own 8m dish from a negative concrete mould; so is his a one-piece dish??? If so then that would be the biggest one-piece dish I've heard of so far. And is it fiberglass? | ||
| Member Join Date: 27-03-2005
My System: skystar2, nokia9902, xcam, matrix, tpfld 3000cipp | I dont think any dish more than 3.2m solid would fit in a container unless it was manufactured on the spot.4,3m i set up yesterday 16 pieces alloy. | ||
| The Following User Says Thank You to andmac For This Useful Post: | divibi (07-09-2008) |
| Regular Member Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | you need big dishes,no problem ![]() you only need much much $$$ also i nice 7.6 M Andrew Gregprian how about this? looks also very nice and should be enough,for central europe in c and kuband i think! here,a nice company from switzerland,only 150 km away from my location! so if i would win in lottery,i would buy everthing on that you can see on this page,and then,some satelites uk mebers,must come to help installing! **/www.globotech.ch/html/antennen.htm l espasly the vertex rsi Torus,looks very nice,you have gain winning on all satelites,without using motor of ,4,5 meter in c and kuband! there is a distrubutor in london,so try to find out more infromation how much this little baby would costs ![]() in swoterland,there are many experts,but its to expensive with the import tax! when you buy andrew today,it is dificult to find,single antenna parts for ech modell ,usa import is then the only way! ps_are the some pictures,of the curent andrew setup,you also have motor solution? i dont think that we here in europe can "use" a 10 mter dish,i want to say,with 7 .8 meter all weak satelitessignals,should be posible! but,without testing it,we will never know it! from the brazil man,we only need a orginal model of the casting box,of the 8 meter antnna,with this,then,we could make our own antennas! good night,until tomorow evening! | ||
| The Following User Says Thank You to Turok For This Useful Post: | divibi (07-09-2008) |
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | Hi! here,iam back again,with some nice Ebay i would say this are our dream antennas ![]() Ofer 1 Vertex 13 Meter!! http://h**tp://cgi.ebay.at/ws/eBayIS...E:B:SS:AT:1123 11 Meter! special Offer 2 h*ttp://cgi.ebay.at/ws/eBayISAPI.dll?ViewItem&item=370084578055&ssPageNam e=ADME:B:SS:AT:1123 9.2 Meter this should be enough for my usage ![]() Offer 3 Nice Andrew 7 Meter Antenna *ttp://cgi.ebay.at/ws/eBayISAPI.dll?ViewItem&item=370084578319&ssPageNam e=ADME:B:SS:AT:1123 and here 2 Times a 9.2 meter Antnna! *ttp://cgi.ebay.at/ws/eBayISAPI.dll?ViewItem&item=370084578397&ssPageNam e=ADME:B:SS:AT:1123 | ||
| The Following User Says Thank You to Turok For This Useful Post: | divibi (09-09-2008) |
