english speaking | |
| Member Join Date: 13-08-2008 Location: telford uk
My System: motorized fortec star |
hi setup my dish had a quick scan is there anymore than astra 28.2 that is english speaking im in the west midland and i have a 90cm dish cheers | ||
| Design Engineer/Installer Join Date: 08-08-2007 Location: Central UK near Jodrell
My System: 75e-75w C & KU, 36v diseqc Anlg to HD Channel Master C120 dishes, stbs, lnbs, motors, too much to list | 26e ... a gem for movies etc.. but you are on the limit of getting it with a 90 there- you'll need everything spot on especially 11919h the best tp with mbc2/ persia on it | ||
| | #5 | ||
My System: 75e-75w C & KU, 36v diseqc Anlg to HD Channel Master C120 dishes, stbs, lnbs, motors, too much to list | That should be it ... but it may have an old transponder list ... try 12182H 16200 (input it manually if you have to) it's perhaps the strongest .. once you get it and get in the middle so you have the strongest signal ..... power scan the satellite ...... also look for 11919h 27500 if it's not there input that manually and try to scan it ..it's usually the hardest but best. Usually Arabsat 26e (now known as BADR3/4/6) needs very fine tuning at the dish with a TV screen and meters on it or high grade meter (not beeper/ needle type) and fine adjustments while on 11919h MBC2 of SKEW and alignment (in good weather too). | ||
| | #6 | ||
| Information Exec Join Date: 07-05-2007 Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | I'm guessing in Telford on a 90cm, 26e will be tight with those dishes
__________________ - .....A Detailed DiSEqC Motor Installation Set Up Guide HERE Motor Installation 'Quick' Reference Guide also HERE Satellites UK site Advertisers - | ||
| | #7 | ||
My System: 75e-75w C & KU, 36v diseqc Anlg to HD Channel Master C120 dishes, stbs, lnbs, motors, too much to list | you're not wrong.. worth a pop though .. we've used 80s before now here and he's a bit nearer... | ||
