Anyone tried to make BIG dish at home?If you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here. | |
| LinkBack | Thread Tools | Display Modes |
| | #101 | ||
| Regular Member Join Date: 20-09-2008 Location: Chicago
My System: 1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver. Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band. ![]() Though defeated by the evil Fresnel this warrier will return victorious! | I went ahead and painted the dish with enamel exterior porch and floor paint. It takes along time to dry. Today I put the dish out in the sun to dry. ![]() I am making a 4" X 4" by 1 1/2" mounting plate and 2 5/16" pole. I'll place Patio blocks on it to hold it down. Some new pictures. | ||
| | #102 | ||
| Regular Member Join Date: 28-08-2007 Location: Ilhéu das Formigas - Azores
My System: Sugar antennas:) | @Satcom1 i wish all my homemade antennas were nicelly done like yours Will you test the antenna for C-Band satellite? when you expect to do the first test? | ||
| | #103 | |||
My System: 1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver. Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band. ![]() Though defeated by the evil Fresnel this warrier will return victorious! | Casser- Pictures are deceiving, If you were here you would say " I could do better". ![]() Rainy day today. ![]() I did go to the hardware store and have what I need to make an adjustable (azimuth/elevation) bracket to mount the dish. Testing on the dish should begin this weekend. I will align the dish with the KU band signals first and then test for C-Band reception. I have a new receiver that is more sensative then the Twinhan 1025 PCI card. It will be intereseting to see how the dish works. Here are todays pictures of the dish stand I made for the new dish, enjoy. | |||
| The Following User Says Thank You to Satcom1 For This Useful Post: | divibi (07-10-2008) |
| | #104 | |||
| Regular Member Join Date: 26-07-2005 Location: London
My System: dvb-s pci card 85 cm offset dish |
![]() What is, in your opinion, the most sensitive receiver? I read somewhere that Twinhan SP 400 pci card has the most sensitive tuner, so what is better and what receiver do you have now? | |||
| | #105 | |||
My System: 1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver. Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band. ![]() Though defeated by the evil Fresnel this warrier will return victorious! | Hope all is well with you, just wondered what kind of projects you like? I can only speak from my own experience on the issue of STB vs PCI. The Twinhan 1025 is just as good as the KWorld PCI for sensativety but the 1025 does HDTV ATSC. The Coolsat 6000 Premium works so much better then the PC software like ProgDVB and DVBDream. PC software is always crashing. STB is better at Diseqc 1.0/1.1, 22Khz switch configuration. ProgDVB is useless for switches and DVBDream does switches but not HH Motors. ![]() Most folks in US have STB and some have PCI and STB. I have not heard anything good on the US forums about Twinhan SP 400. Folks here are very interested in Tecnotrend PCI because it does all the new video compression, 8PSK/4.2.2 etc. Big interest in HDTV format, If card lacks good sensativety they use bigger dish. The Invacom LNBF's are most popular because of .03 Noise and Quality. Many use the QPH-031 which is circular and linear. The 90 cm dish is accepted by most wives here but 1 meter or bigger is frowned upon by the little lady. Makes for chilly relations or worse. | |||
| The Following User Says Thank You to Satcom1 For This Useful Post: | divibi (10-10-2008) |
| | #106 | ||
My System: Sugar antennas:) | @SatCom1 Since you´re using a PCI card, try the FastSatFinder software it also support C-Band ..when i used a SkyStar, the software help me a lot checking the polarization/signal/etc of the antenna, i thought the antenna received both H/V polarization´s, but no...the LNB at 0º it received only V pol and at 90º received H pol. At 45º didint receive any pol. But with your antenna that will not happen | ||
| | #107 | ||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | There are plugins for everything, so both motor rotation, diseqc and other things are possible on most PCI DVB-S cards. | ||
| | #108 | |||
My System: 1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver. Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band. ![]() Though defeated by the evil Fresnel this warrier will return victorious! | I hope all is going well for you there. I heard on RT that John McCain went to visit President of Georgia two weeks before war. Even worse, Our idiot George W. Bush is threatening Russia with missle installations in Poland and Ukraine. Maybe, we will have a change in government here that will help things. Our Republican party will do anything to scare public into keeping them in power. ![]() Unfortunately, my PCI card uses the 878 device driver and not the WDM and is not compatable with "FastSatFinder" and other useful software. This is one of the primary reasons I went with a STB. | |||
| | #109 | ||
My System: 1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver. Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band. ![]() Though defeated by the evil Fresnel this warrier will return victorious! | Getting ready for testing new dish. ![]() In todays pictures you will see the mounting bracket that I fabricated. It uses simple hardware that was available from the local hardware store. The pipe mast has a hose clamp just below the mast brackets to prevent the assembly from slipping down and allows for easy azimuth rotation. The large threaded U bolt is used to adjust elevation and has hex nuts on both sides of the plate. I set the dish to south and then adjust the elevation with the board and protractor. My dish elevation is 42 degrees and I will select a strong satellite as close to south as possible. It's a good starting point. Here are todays pictures- | ||
| | #110 | ||
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | Satcom1, If no McCain and U.S. Government support, I wouldn't be alive now and making posts here ![]() And please - listen to RT less, they always say false things (Very good Soviet Style propaganda). Regarding McCain, for your reference - he has Georgian citisenship, so can wisit Georgia anytime he likes to do it | ||
| The Following User Says Thank You to BombedOne For This Useful Post: | Satcom1 (10-10-2008) |
| | #111 | |||
| Member Join Date: 25-05-2008 Location: London
My System: Raven 60cm, fixed for Hispa, 30W, Fibo 90cm 53E - 61W (ex 16E - 28E), Channel Master 90cm 15W -28E, Technomate 5400, Echolink 777. For feeds: Vantage 221, Quali-TV 1080IRCI (4:2:2). Panasonic TH42PX80B Plasma TV. |
Anyway, have you checked out a Nigerian member called Okeme? He was building a 3M fibreglass dish when I last saw his posts...claimed to be getting Astra (not 2D of course) in Nigeria with a homemade dish! Here you go: _http://www.satellites.co.uk/satellite/fringe-reception-general/114339-hotbird-nigeria.html#post731598 It was Astra 1, but still good going....and there are sceptics but I believe it! | |||
| The Following User Says Thank You to joekir For This Useful Post: | Satcom1 (10-10-2008) |
| | #112 | ||
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | If anyone interested what really happend and see some eywithness data, we can open separate topic for it. Regarding our task, making the dish - today I made some tests. Results are attached as pictures, and here's some conclusions: 1. Quite precise work, needs lot of patience and steady hand. 2. Dangerous for health! epoxy in huge amounts releases styrol and other toxic fumes, you'll need airtight helmet, if doing indoors, or VERY WINDY weather, if outside. 3. I tried to use epoxy with fiberglass filler, this was my error, it has very low penetration rate, only reached down to two layers of my fiberglass net, while just a drop of ABRO™ transparent epoxy went down trough 8 layers without no problems. 4. If anyone tries to repeat this method, I'd suggest to use lowest dry speed, highest liquidity epoxy, to simplify the work (I watched "How things made" at discovery, guy was doing small sporting boat from fiberglass sheet. His epoxy was so thin, he was applying it just using plain brush) | ||
| | #113 | |||
Regarding your dish project- This is very interesting! Please post more, thanks. This looks very well made. | |||
| | #114 | ||
My System: 1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver. Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band. ![]() Though defeated by the evil Fresnel this warrier will return victorious! | With a SF-95c+ Satellite Finder meter attached to the dish was adjusted for signal strength. The dish really lights up strong! Able to swing the dish across several satellites to my true south and had very strong readings. With my one meter dish the meter gain was set four to five times higher then with this dish. ![]() Both KU and C bands are very strong. ![]() Hope to have more data in a couple of days. | ||
| | #115 | ||
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | Thanks everybody ![]() Regarding this dish, I'll go more liquid epoxy and try to finish this one asap. After that, I'll try to polish it's internal side and cover it with aluminum powder. And finally, I'll try to make big (2 meters or more) positive concrete mould for dish. I'm writing down all expenses, so will post exact calculation of pricing also. | ||
| The Following User Says Thank You to BombedOne For This Useful Post: | divibi (11-10-2008) |
| | #116 | |||
![]() If you can, post the measures of each ring, so i can simulate it in my university for C-Band.. | |||
| | #117 | |||
My System: 1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver. Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band. ![]() Though defeated by the evil Fresnel this warrier will return victorious! | This dish suggests Fresnel and Scalar technology so conventional Parabola math would not be accurate. I have no idea how to get individual ring data now that it is assembled. | |||
| | #118 | ||
My System: 1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver. Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band. ![]() Though defeated by the evil Fresnel this warrier will return victorious! | My Zenith Satellite is Galaxy 28. I first set the dish with a compass, this method is not very accurate. Then I go to the NOAA Sunrise/Sunset Calculator and input my Lat. & Long., this then gives me the exact time for solar noon. Then at that time of day, I move the dish so that the LNBF shadow is in the exact center of the dish axis. ![]() Here are pictures of Prime Focus and Offset dishes using this method. | ||
| The Following User Says Thank You to Satcom1 For This Useful Post: | divibi (18-10-2008) |
| | #119 | ||
My System: 1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver. Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band. ![]() Though defeated by the evil Fresnel this warrier will return victorious! | Here is an example of how you can check your LNBF focus visually. ![]() By placing three small mirrors around the dish at solar noon, you will be able to precisely focus your LNBF. By using three coin sized mirrors they will all make overlaping images on the face of the LNBF. If they don't form one image, then something is out of adjustment. A cloverleaf pattern means the LNBF is too close or too far from the dish surface. Here are pictures. | ||
| | #120 | ||
My System: 1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver. Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band. ![]() Though defeated by the evil Fresnel this warrier will return victorious! | This dish produces signal strengths of 98% on Coolsat 6000 Premium receiver. Sorry to say that that does not produce a usable KU or C-band signal, either linear or circular. ![]() It would make a dandy solar cooker with mirrored surface. I will try to come up with a new parabolic dish that is simple to make and works really good for little cost and effort. ![]() ![]() It is valuable to know one more thing not to try. ![]() Thanks for your interest in my project. ![]() | ||
| The Following User Says Thank You to Satcom1 For This Useful Post: | divibi (31-10-2008) |
| | #121 | ||
| ASBO Club Member - Persona non grata Join Date: 07-10-2008 Location: Ireland
My System: sky digibox also U P C Ireland | when Sky was Analouge at 19.2 east I used a Dustbin lid as dish Not at all helpful I know but felt the need to boast about it! lol | ||
| The Following User Says Thank You to ynotdu For This Useful Post: | Satcom1 (01-11-2008) |
| | #122 | ||
My System: 1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver. Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band. ![]() Though defeated by the evil Fresnel this warrier will return victorious! | Yes, you are very likely correct about the analog signal being easier to capture. Certainly it is better quality. | ||
| | #123 | ||
| Member Join Date: 01-10-2006 Location: Coimbatore -India
My System: 16 feet motorised dish for c and ku band,6 ft offset dish,6ft prime focus,DM500,Tecnosat 1100plus,MetaboxIII,(146E to 25.5E) |
Hello can any one guide me to get calculations for arriving the offset dish of size 10 and 12 ft. vkumar | ||
| | #124 | |||
| The Consumate Dreamer Join Date: 01-01-2000 Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
Blog Entries: 5 My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh |
Still: Well done, I applaud you for trying and testing and coming to a conclusion. I certainly enjoy reading this thread. Next dish will be better!! | |||
| | #125 | ||
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | I talked with one local importer today, as he said, shortly he'll have stock of 2.4m and 3.6m C band mesh dishes for reasonable price. Interesting, if anyone had tried to receive Ku band signals using C band mesh dish. | ||
| big, dish, home, make |
