every year again Sun Outage!If you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here. | |
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! |
Hello! hope iam right here in this section with my topic now ever year the same,in oktober,the sun stands very deep,between the satelites,and the earth here a calculation site **tp://www.satellite-calculations.com/SUNcalc/SUNcalc.htm could a lnb or dish,realy damage,in this critical moment? maybe alumonium dishes,that reflekt the sunlight stronger,then other material? | ||
| The Following User Says Thank You to Turok For This Useful Post: | divibi (02-10-2008) |
| The radiation would be unlikely to damage anything down the signal path, however the heat is another matter The feedhorn, and/or LNB feed cap, possibly the waterproofing membranes between individual components and maybe the first few centimetres of cabling, but the damage would realistically occur in equatorial zones, on a cloudless sky and on a large dish. | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| The Following User Says Thank You to Channel Hopper For This Useful Post: | divibi (02-10-2008) |
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hello! good morning @ all! thanx for always fast reply! intresting whould be what the maximium temperature whould be,that a lnb,or even a dish,dipends on the material cam handle! for e.g. in the desert +/- 50 degrees, a aluminiums dish,would reflect the sunlight and the heat so strong,that a focus point of the heat,could destroy the lnb,in a extrme case in the past only smw manufactor get a lnb protocoll paper inside the box,and define the maximum temperature,that a lnb can tolerate,up +/- 40 degrees when the box of the lnb is cheap plastik like today,proberbly could disforment, so i dont live in the desert,but i could imagine that this senario could happen! no lnb manufactur,has today measurment protokoll inside the box ,only smw,so we dont know,how big the deciance realy are,depend,on outside temprature +/- 40 does cheap lnbs realy perform bader,on hot temperatures,then the expensive ones,in todays test reports i dont read nothing about it! when the sun shines direkt into lnb,the signal must be much lower,i wil lock exactly that time on ,my location on difrent staliltes how much,i will be the signal lost,in this critical moment! | ||
| Regular Member Join Date: 08-02-2005 Location: Lot, Dordogne, Correze border.
My System: FTE Max, Skystar2.3 and Skystar2.6, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky. | I built an LNB holder for my converted meteosat dish from an old 80mm drain pipe, that deformed slightly due to (focused) heat. With proper materials any heat issue should be addressed with a commercial product. Heat (or temperature) is one of the main sources of noise, this is why some critical installations will have buried cable runs and some will cool the LNB. I seem to recall from my college days that noise is proportional to root 4KBTR. (though it was 20 odd years ago, and I can't be bothered to google it!) | ||
| | #5 | |||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Slightly OT I followed the sun round the arc one sunny October weekend a few years back with an old dish I had lying around. It was intersting to watch the signals fade out one at a time | |||
| | #6 | ||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | Hehe yes, and what is very strange, for C band, sun was killing L polarisation, while R stays intact. I don't have any explanation for this. | ||
| | #7 | ||
| Specialist Contributor Join Date: 28-11-2004 Location: Lanzarote, Canary Islands
My System: 30W,7W,13E,16E,19E & 28E Dishes everywhere Darkbox 2008HD Sly+ V3 | We have seen some significant damage to LNB´s here in Lanzarote. Specifically with 2.7M off-set Fiberglass dishes from Poland. When I first saw one I really thought someone had got a blow torch to it. It affects these specifically due to the shiny gel coat on the dish. I think I have one of the LNB´s in the van and if so can photograph it and post on here. The plastic cover was significantly burned. The 3.1M Famaval prime focus dishes are fine because the LNB is "hidden" behind the metal feedhorn which is also like a heat sink. Triggs | ||
| | #8 | ||
My System: 30W,7W,13E,16E,19E & 28E Dishes everywhere Darkbox 2008HD Sly+ V3 | Sorry Double post | ||
| outage, sun, year |
