Hispasat in Florida?If you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here. | |
| | #26 | |||
| Member Join Date: 26-12-2008 Location: I am in Florida Zip 33351
My System: Viewsat, and Sonic View |
| | #27 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | A slingbox is a box of tricks that takes an av stream, compresses it and placeshifts it across the internet via broadband. A European box would give you access to any channel from the satellite kit or other av source that its connected to. Note - you get to watch the SAME channel as the host if its in someones house - so if they switch over two minutes into the football game then its bad luck! There are companies setting up now that do dedicated hosting of a dedicated satellite receiver, SB plus a fast internet pipe - there are definitely some for the UK pay service, although its not cheap. Presumably there are similar services for the Spanish channels. SB's only work with one viewer at a time so you couldnt pass on your log in details to your brother and hope for both of you to watch a game. Google Slingbox to get a better idea of their capabilities. | ||
| The Following User Says Thank You to Analoguesat For This Useful Post: | divibi (30-12-2008) |
| | #28 | |||
| Member Join Date: 12-06-2008 Location: Italy
My System: TV on Mac |
Have been following your thread with interest, Ref your Slingbox not viewable from your work place, probably due to the firewall, Try setting your Slingbox at home with Port 443 (you'll have to do a manual setup instead of 'auto') on your router too Take care | |||
| The Following User Says Thank You to speedy For This Useful Post: | divibi (30-12-2008) |
| | #29 | ||
My System: Viewsat, and Sonic View | can somebody tell if i have a 30' inches dish would i be able to add a c/ku lnb on it and would i b able to get that satellite: Star One C2 at 70.0°W with my 30 inch dish, and my last question i have a AT9 ka/ku directv dish can i used it for any satellites beside dire ctv sat, is that true that i wouldn' b able to get any of dire ctv sat with my fta receiver just a question | ||
| | #30 | ||
| Design Engineer/Installer Join Date: 08-08-2007 Location: Central UK, E Cheshire ..near Jodrell
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... | 70w is for S America ... you will not normally be able to see it with a 30" dish in Miami... but try to get local reports as we get some off footprint satellites that are as far away as that is from you and with 30" dishes or less ... here's why anyway... _http://www.lyngsat-maps.com/maps/staronec2_sam.html also you need a H/V KU lnb-(linear) you may have a L/R (circular polarised one) You can get C band on a 30" but only if the signal is very strong. better a 6' or 8' mesh dish. you should get fta on other sats | ||
| | #31 | |||
We do not permit ANY questions relating to the American pay tv providers on this forum, so we cant answer that part of the question. To be honest you need local information as to whats possible with fringe reception from 70W - you need to find an American forum. Most of our members are based in Europe, the Middle East, and India. We only have a handful of members from the Americas | |||
| | #32 | ||
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... | If you can’t find enough info locally .. have a look on lyngsat.com at satellites between about 35w to about 125w which you can at least 'see' from there easily (you can see further if you are high up and/ or have a clear view.. to an absolute maximum of 5w and 155w from there), then you need to make sure they are sending a signal you can actually get in Miami (click on the maps at the right side ... or if there isn't one, you might need to find out from the supplier or other local forum), then check the lnb needed c or ku L/R or H/V & dish size needed ... etc.. and if it's free to air... (I think we get get 30+ satellites here and 1000s of free channels) .... and as explained .. we don't discus pay tv in the US. | ||
| | #33 | ||
My System: Viewsat, and Sonic View | would i be able to add a c/ku lnb on a 30'inch or a 36 inch dish, and would i be able to get Star One C2 at 70.0°W with a 30 or 36 inch dish if i add c/ku lnb | ||
| | #35 | ||
| | #36 | |||
My System: Viewsat, and Sonic View | I have another question would i be also get sat Star One C2 at 70.0°W with a 30 inch or 36 inch ku lnb | |||
| | #37 | ||
| | #38 | ||
My System: Viewsat, and Sonic View | | ||
| | #39 | ||
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... | yes & no................................................ .......... | ||
| | #40 | ||
| Member Join Date: 17-09-2008 Location: Canada
My System: .9m offset on hh-90 motor- visionsatIV200 | No, you cannot get Star 1C2. It is beamed at south america and you are not there. The Lnb you have on a globcast dish is a linear lnb and it will work for Hispasat. A 30" or 36" dish is too small for c band reception. You can get some c band with a 6' or larger dish but an 8 1/2' dish is recomended for cband in NA as it is 2 degree compliant and won't get interferance from neighbouring sats. Even with a 8 1/2' C band dish you still need to be in the beam of the satelite you want. | ||
| florida, hispasat |
