Hispasat in Florida?
If you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here.
Old 26-12-2008   #1
My System: Viewsat, and Sonic View
Question Hispasat in Florida?
Hi, I would like to know if i would be able to get Hispasat with my Globecast dish, Cause i have tried nothing come up, and is Hispasat far from 61.5 eckostar 3
rjlove1 is offline   Reply With Quote
Old 26-12-2008   #2
Site administrator
Analoguesat's Avatar
Make sure you are looking for the channels on the American beam. You have no hope of getting the European beam channels.
_http://www.lyngsat.com/hispa.html
Hispasat 30W is a long way from Echostar 61.5W!
Analogue forever!
Analoguesat is online now   Reply With Quote
Old 26-12-2008   #3
I want to know if it's close to the east cause when i used my compass it shows me far from west it's more likely south east am i right, and also i would like to know with my globecast 36' dish does it make any difference because it's a globecast dish not a regular dish iam not getting no Q at all i try one of the America Freq
Old 26-12-2008   #4
Site administrator
Ah - you probably need to change the lnb - Europe uses linear (H/V) polarization - America tends to use circular (L/R) polarity
30 W will be out towards the east
_http://www.lyngsat.com/tracker/hispa1d.html
Analogue forever!
Old 26-12-2008   #5
if i change the lnb would i be able to get it and could u tell me in my area i see they give me do i have to sub that from 90 degrees the lnb skew equal 33 and is the lnb skew located from the back of the dish where the numbers are i got puzzle sometimes is the elevation accurated
Elevation: 27.3°
Azimuth (true): 110.1°
Azimuth (magn.): 116.0°
LNB Skew [?]: -57.4° Dish Skew [?]: 90.0°
Old 26-12-2008   #6
Am i right what the compass gave me it was more south east far from the west
Old 26-12-2008   #7
I thank you also for taking your time with me help out
Old 26-12-2008   #8
Site administrator
The elevation will be about right - remember for you that 30W will be on the lower part of the arc and therefore not very high in the sky for you.
Theres no guarantees that you will be able to get it, although you should have a reasonable chance.
Analogue forever!
Old 27-12-2008   #9
is that hard to get i don't want to waste time and if can't get it at all
Old 27-12-2008   #10
Design Engineer/Installer
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions...
Is that a 36' or 36"... a 36' might do it... a 36" will not ... not the European beam.. the fact that it's oval doesn't really matter.... you'll get the US beam though.. !
pedro2000uk is offline   Reply With Quote
Old 27-12-2008   #11
Site administrator
What are you wanting to watch on Hispasat?
Analogue forever!
Old 28-12-2008   #12
Listen one of my Brother get the hispasat but not a strong signal about 60's Q and also it's only scanned 52 channel on that Freq 11884 why should it do and other to get more channel and how much channel that he should have, do u think the dish to small or the lnb not power enough it's a 30' dish
Old 28-12-2008   #13
I was worried about the LNB Globecast dish would i be able to get it with that LNB or it doesnt matter. and how many channel should i get with it
Old 28-12-2008   #14
More soccer what you think would i be able to get them cause i saw on Lyngsat it seem like a lot of soccer from all over there, and also if i have a a second lnb next to the main one would i be able to get intelsat 903 at 34w
Old 28-12-2008   #15
Old 28-12-2008   #16
We don't know that dish / lnbf too well here... it could be it is not too suitable until it's modified a bit..
can you see the information sticker on the LNBf and the settings for the lnb in the satellite receiver?
and what satellite/s should it be used on?
EDIT... just read it... 61.5w echostar 3
Old 28-12-2008   #17
OK... you need another LNBf......... a ku universal 9.75-10.6 (about $6-$10?) because 30w is H/V not L/R (circular). You could just fasten it on the side of the Glogecast LNB and add a switch... that will mean you can get other satellites too that are H/V... using a circular LNBf on 30w might work but you will lose signal.
here's hispasat at 30w.......... _http://www.lyngsat.com/hispa.html ..........have a look at the channels on the American beam (in far right column)
here's Echostar at 61.5w.btw..... _http://www.lyngsat.com/echo3.html
the channels you can expect to receive on 30w are on the American beam here.... _http://www.lyngsat-maps.com/maps/hispa1d_am.html
Old 28-12-2008   #18
Hi, I have my brother just got hispasat and it's only 60% Q and also he only get 52 channels why is it so low i would like to know how many channels should he gets with aa normal setting, the elevation it catch the hispasat was at 30 he has a wineguard round dish Please help he wants more channels for soccer
Old 28-12-2008   #19
Is it the lnbf not strong enough or the dish to small he has a 30 inch. would it make any different if he order a c/ku lnbf and other to get more channels now he only has a single ku should he gets c/ku instead or doesn't matter
Old 28-12-2008   #20
Site administrator
Why is he expecting more? Theres only 50 or so channels transmitting on the USA beam - which you would know if you had checked the link & info you were given in post 32 properly.
If he wants more channels on Hispasat he will have to move to Europe!
Analogue forever!
Old 28-12-2008   #21
Now i got Intelsat 5 with it but i was wondered if i could get any ku satellites with it
Old 28-12-2008   #22
ok now would i be able to get intelsat 903 from where i am at
Old 28-12-2008   #23
it seem like its not to far from Hispasat. and also Please tell what other satellites you guys can suggest n other to get way more channels meaning soccer and other world stuff i hate watch local which not live stuff and also I really thank everyone in this forum that have patient to help others thank you guys God bless all
Old 28-12-2008   #24
Site administrator
If you have been using it on Echostar 61.5W you have already been using in Ku band
Analogue forever!
Old 28-12-2008   #25
Site administrator
Yes - but only channels on the American C-band beams or the pay service on the Caribbean spotbeam.
The best thing you could do is move to Europe! Via satellite you cant get any of the satellites hovering above Europe as they are below your eastern horizon. You can get the birds hovering over the Atlantic but only beams that are transmitting into America.
There is one alternative if you are willing to invest a lot of dollars - a slingbox. Someone in Europe hosts a slingbox and gives you the login details. You can then watch their av-source, although you need reasonably quick broadband at both ends.
Ive got a slingbox and its a neat bit of kit, although sadly Ive never got it working through the firewalls at my workplace.
Analogue forever!
The Following User Says Thank You to Analoguesat For This Useful Post:
divibi (30-12-2008)
florida, hispasat
[IMG] code is Off
