Nilesat 102 and Badr 4 in NetherlandsIf you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here. | |
| | #1 | |||
| Regular Member Join Date: 12-03-2008 Location: NL+IT
My System: * Clarke Tech 5000 HD Combo Plus * Gibertini 104 cm * Invacom TNH-031 0.3dB * Diablo Light 2.3 + CAS 3 plus * motor GT SAT - DM15AT * 53°E - 58°W in USALS * Full HD LG Scarlet 42lg7000 * Western Digital HD TV Player * |
![]() I would like you to give me some hopes in receiving Nilesat 102 (7.0°W) and Badr 4 (26.0°E) here in The Netherlands. How do you get them? What do you advice me in case I like to replace the Penta85? Bedankt | |||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | greenmanbelg uses a channel master 1.2m dish to receive them in his location | ||
My System: * Clarke Tech 5000 HD Combo Plus * Gibertini 104 cm * Invacom TNH-031 0.3dB * Diablo Light 2.3 + CAS 3 plus * motor GT SAT - DM15AT * 53°E - 58°W in USALS * Full HD LG Scarlet 42lg7000 * Western Digital HD TV Player * | | ||
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | no you need a proper motor to move the dish and use the polar mount and actuator diseqc motors aren't suitable for channel master dishes you could probably use a gibertini 1.2m dish on one if your setup is in a garden | ||
| | #5 | |||
My System: * Clarke Tech 5000 HD Combo Plus * Gibertini 104 cm * Invacom TNH-031 0.3dB * Diablo Light 2.3 + CAS 3 plus * motor GT SAT - DM15AT * 53°E - 58°W in USALS * Full HD LG Scarlet 42lg7000 * Western Digital HD TV Player * | why in the garden? As you can see by the foto-avatar, my system is placed on the roof.Have a great Sunday | |||
| | #6 | ||
| Design Engineer/Installer Join Date: 08-08-2007 Location: Central UK, E Cheshire ..near Jodrell
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... | Wind loading is far less in a sheltered garden location compared to an exposed roof and it makes a big difference as to the motor you can use as well as to what brackets/pole/ fixings you can use. On a roof like that with a 1.2 CM Wod's giving good advice re: a polar mount and actuator. There is a Superjack diseqc motor that looks more capable of carrying a 1.2 but still not in an exposed location. | ||
| The Following User Says Thank You to pedro2000uk For This Useful Post: | divibi (25-01-2009) |
| | #7 | |||
![]() Might follow the wod's advice if only I will be sure to get the 2 sats and (more important) in each weather condition | |||
| | #8 | |||
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... | …but in the centre of the UK Badr 4 45cm* $ky dish .... Yemen's TP (no others** ) 60cm* Dubai One etc. (but not MBC2**) are watchable but with low weather margin (5-10%) 80cm* you get MBC2 etc (with a low margin for MBC (5-10%)** & higher margin for Dubai One etc (20-25% med' rain/ cloud) 1m-1.1m+ and you should nail MBC2 etc.. in bad weather ....only to loose it in weather that would normally block $ky/ Freesat on a $ky z1 dish. *45cm, 60cm & 80cm have to be 100% setup throughout. Badr 6** Estimates here are 2.4m-3m+... Nilesat** For Nilesat it’s very unpredictable (hotspots/ cold spots/ noise level etc.. )… but a 2.4m gets all Vs & Hs here ...but has to be 100% setup right... ideally in a rural location and no major local (especially city) noise issues. Prime focus may help with local & ground noise issues**. Margins can still be low on mid to lower strength Tps. Time of day effects the signal greatly for 7w where mid day to mid afternoon signals are far lower and the peak values are for evening to early morning only - the aim usually is to get the signals mid day/ mid afternoon. **..but we're always working on it. where is the lnb on the penta btw... | |||
| | #9 | |||
You destroyed all my hopes for getting the 4 Al Jazeera sport channels ![]() PS what do you mean by " where is the lnb on the penta btw..." ? | |||
| | #10 | |||
...is the LNB in the middle of the holder... as far back as it will go.. or as far foreword. btw.. where you are you might be able to reduce sizes by 30% or more ... a 1.2m should get many Vs and could get some Hs on 7w.. | |||
| | #11 | |||
My System: * Clarke Tech 5000 HD Combo Plus * Gibertini 104 cm * Invacom TNH-031 0.3dB * Diablo Light 2.3 + CAS 3 plus * motor GT SAT - DM15AT * 53°E - 58°W in USALS * Full HD LG Scarlet 42lg7000 * Western Digital HD TV Player * | ![]() http://img145.imageshack.us/img145/3...e042ly0.th.jpg | |||
| | #12 | ||
My System: * Clarke Tech 5000 HD Combo Plus * Gibertini 104 cm * Invacom TNH-031 0.3dB * Diablo Light 2.3 + CAS 3 plus * motor GT SAT - DM15AT * 53°E - 58°W in USALS * Full HD LG Scarlet 42lg7000 * Western Digital HD TV Player * | Sorry for UPping this thread but I would like to ask news regarding better signal transmitted from Nilesat (Al jazeera sport channels @12456 V and @12284 V). Who gets them in UK+NL? what dish size? Thanks | ||
| | #13 | ||
| Sat Freak Join Date: 05-05-2005 Location: javea,costablanca..ESPAÑA
My System: Motorized Gibertini OP150 ,Motorized Fibo MF90, 2X ASC signal 1.20 on stand by,ASC signal 1.80 ,Famaval 1.80 , 60cm eliptical raven ..hirschmann fibre glass 1.20m....and more gadgets | i just came back from algiers the capital of algeria in north africa ,there i heard reports of decent signal for Atlantic bird 4 at position 7ºwest using an old 1.80m alcoa dish ..more tests and reports needed in our positions in europe in the other side check at position 26ºeast Badr 6 at frequency 12.341 H ,27500 3/4 you will find all aljazeera sport channels providing you have a good 1.20 up dish in europe | ||
Last edited by pipino; 12-08-2009 at 04:39 PM. Reason: more footprints added | |||
| The Following User Says Thank You to pipino For This Useful Post: | LAURO2008 (12-08-2009) |
| | #14 | ||
I'm extremely happy .... ![]() ![]() ![]() I was trying to find some signal on Badr but just like (almost) everybody else, the strong 28.2 est or 23.5 est disturb the 26.0 est. Then I fooled the receiver and I changed Badr from 26 to 25 est and from USALS to Disecq ....the result is now that I see Aljazeera's channels @ 12034H very well Unfortunately the 12.341 H ,27500 3/4 mentioned by @pipino is not receivable. I also see France 2, 3 and 5 @ 11590V on 7W and some other TP's but not the strong @12284V or 12256V.... NOW THE QUESTION: IS ALL NORMAL ? How about changing the Penta85 which performs almost like a 100 cm dish into a bigger one? Could a 120cm get 7W and the TP 12.341 H @26Est? Thanks | ||
| | #15 | ||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | | ||
| The Following User Says Thank You to Tivù For This Useful Post: | LAURO2008 (12-08-2009) |
| | #16 | |||
| | #17 | |||
My System: * Clarke Tech 5000 HD Combo Plus * Gibertini 104 cm * Invacom TNH-031 0.3dB * Diablo Light 2.3 + CAS 3 plus * motor GT SAT - DM15AT * 53°E - 58°W in USALS * Full HD LG Scarlet 42lg7000 * Western Digital HD TV Player * | ..it can be done but I don't like extra pistons, attuators or extra cables from the roof....can I install a 1.50 cm on a clarke tech HH 390?And after all, are you sure I will get 12284V or 12256V @7W ? In each meteo condition? Thanks | |||
| | #18 | ||
My System: Motorized Gibertini OP150 ,Motorized Fibo MF90, 2X ASC signal 1.20 on stand by,ASC signal 1.80 ,Famaval 1.80 , 60cm eliptical raven ..hirschmann fibre glass 1.20m....and more gadgets | i think HH390 wouldn´t stand OP150 as its slitly heavy but with OP120 i think yes ,,regarding the reception ..i can tell you there is no garanty on anything specialy receiving signals on fring areas sometimes you have to make experiments like most of us here in this board ..or ask guys with the proper gear near your area about the possibility of receiving the signal you want hopefuly someone could give some advise...good luck | ||
| The Following User Says Thank You to pipino For This Useful Post: | LAURO2008 (13-08-2009) |
| | #19 | ||
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5ºN, 0.5ºW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | | ||
| | #20 | ||
My System: Motorized Gibertini OP150 ,Motorized Fibo MF90, 2X ASC signal 1.20 on stand by,ASC signal 1.80 ,Famaval 1.80 , 60cm eliptical raven ..hirschmann fibre glass 1.20m....and more gadgets | actualy one of the best sport packages around and its very cheap to subscribe yearly (about 70 us$) ,where i am many bars use aljazeera sport video mixed with spanish radio sound"cadena SER" (special piece of hardware with a 5seg delay system) to watch la liga , when police raided one of them once suspecting a pirate D+ signal they where surprised with a arabic speaking channel check this up _http://www.adm.ae/ | ||
| | #21 | ||
My System: * Clarke Tech 5000 HD Combo Plus * Gibertini 104 cm * Invacom TNH-031 0.3dB * Diablo Light 2.3 + CAS 3 plus * motor GT SAT - DM15AT * 53°E - 58°W in USALS * Full HD LG Scarlet 42lg7000 * Western Digital HD TV Player * | Finally yesterday I received my Aljazeera card with 8 channels + 1 in HD @ 13est and I must say it is a fantastic deal: 70 eur for 12 months. ![]() Unfortunately human being wants always more ...so the video bitrate of Aljazeera package on 7west is higher/better than 13est...that's why I am so interested in 7w.Anyway yday night I was watching 4 international football matches live and 2 of them in English ...so as the first day I can't complain![]() Looking forward to enjoying e.g. Serie A, Liga and Champions League !!! | ||
| | #22 | |||
but I have found these on EbayAlso I've read that they Viaccess 3.0. Would I need a cam for this? Or do the multicrypt slots on the Vantage x221 support this? And, Where can you get the delay device? My father-in-law would be furious if I had this as he is paying 60€ + PPV to Digital + every month. | |||
| | #23 | |||
| | #24 | |||
unfortunately it is right and I hope your are wrong ![]() I just issued an official complaint to the UK shop on Ebay | |||
| | #25 | ||
| 102, badr, netherlands, nilesat |
