Nilesat Horizontals quite strong at the momentIf you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here. | |
| | #26 | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| | #27 | ||
| 'What's On' Guru Real name: Chris Join Date: 25-06-2005 Location: High Wycombe, Nr London, UK
My System: 1m Orbital Motorised Dish, Fixed 65cm Fortec Dish on Astra 1, Fixed 45cm Minidish on Hotbird, Pace MSS500, TM-5600D CI USB Super, Nokia 9800s, Skystar USB 2, Grundig Sky Digibox, Manhattan Plaza XT-M ![]() Best newbie geek pit /age ratio 2005 | | ||
| >> BBC Worlds' ultimate fan << >> Satellites are an expensive hobby that run away with you. I am living proof of this... << | |||
| | #28 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Not to mention, Nip Tuck, Desperate Housewives,CSI,ER etc, if you like that sort of thing. | ||
| | #29 | ||
| Regular Member Join Date: 15-06-2008 Location: Birthplace of Television
My System: Cuberevo Twin HD on a 85cm motorised Fracarro Penta dish. Superior Dark Motor. Inverto BLACK Ultra Single lnb (IDLP-SINL40-ULTRA-OPP) | I get all the V's here in 1066 country with my Fracarro 85cm. City7 is watchable 24/7 it is so strong. The weakest signals (and poorest bitrate anyway) are those Education channels 1-4. They can get a bit chppy. Not been lucky enough to get any of the 'H' channels, but I'll keep trying lol | ||
| | #30 | ||
| Regular Member Join Date: 04-09-2006 Location: Kent, UK
My System: Sky; Raven 90 multi-LNB 1W, 7E, 9E, 13E 16E, 19E; 1m Orbital dish on Moteck SG2100 motor; Technomate 1500, Phoenix Apollo and Kathrein (analogue) etc etc Receivers | In my experience, if one is struggling with those education channels (i.e. 11747V) it means the dish elevation ('declination') is not quite right. I used to have the same issue but now, barring bad weather, the 11747 channels are basically 24/7. With that adjustment, the weakest transponder will then be 11900 but then even that is around 18/7 barring bad weather. | ||
| | #31 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Yes, I have not experienced any problems on 11747V it's no weaker that 11938V (MBCs) plus lots of others. 11900V is my weakest too. | ||
| | #32 | ||
| Specialist Contributor Join Date: 07-05-2008 Location: NW, Ireland
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters | I realize you guys are using bigger dishes, but I'm not getting a sniff of anything here. I cant scan in any services from any of the TPs. | ||
| | #33 | |||
My System: 1m Orbital Motorised Dish, Fixed 65cm Fortec Dish on Astra 1, Fixed 45cm Minidish on Hotbird, Pace MSS500, TM-5600D CI USB Super, Nokia 9800s, Skystar USB 2, Grundig Sky Digibox, Manhattan Plaza XT-M ![]() Best newbie geek pit /age ratio 2005 | I'm using a one meter dish, in the South of the UK, and only getting 40% (unwatchable) quality of most transponders. - I'm not quite sure how much more you could expect to achieve if anything, considering you are much further North West than me... (and signal starts to drop off quite quickly..) | |||
| >> BBC Worlds' ultimate fan << >> Satellites are an expensive hobby that run away with you. I am living proof of this... << | ||||
| | #34 | ||
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5ºN, 0.5ºW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | | ||
| | #35 | |||
My System: 1m Orbital Motorised Dish, Fixed 65cm Fortec Dish on Astra 1, Fixed 45cm Minidish on Hotbird, Pace MSS500, TM-5600D CI USB Super, Nokia 9800s, Skystar USB 2, Grundig Sky Digibox, Manhattan Plaza XT-M ![]() Best newbie geek pit /age ratio 2005 | My box wasn't picking up all the channels and the list of transponders seemed to be a bit buggered so I just did a blind | |||
| | #36 | |||
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters | ![]() Unfortunately, my location puts me outside a lot of interesting footprints. | |||
| | #37 | |||
My System: 1m Orbital Motorised Dish, Fixed 65cm Fortec Dish on Astra 1, Fixed 45cm Minidish on Hotbird, Pace MSS500, TM-5600D CI USB Super, Nokia 9800s, Skystar USB 2, Grundig Sky Digibox, Manhattan Plaza XT-M ![]() Best newbie geek pit /age ratio 2005 | I would have thought you'd maybe get a few channel names or something.. ![]() I mean, that's REAL fringe reception but defo play with skew.. it helped me | |||
| | #38 | |||
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters | . I can tweak azimuth using the remote, elevation is as close as I could possibly get it and I've got too much other stuff on to be bothered fiddling with it.I'm crippled by laziness | |||
| | #39 | |||
| Member Real name: ian Join Date: 21-04-2009 Location: North West uk
My System: TRIPLE DRAGON with 500 gb Hard drive. SAB Explorer CISC. Gibertini dish 1m Aluminum. STAB-USALS "GbSat" Branded HH100 Motor. cas interface 3. Diablo Light v.2.3. Redlight Tv card. 45 East - 45 West | | |||
| horizontals, moment, nilesat, strong |
