Nilesat Horizontals quite strong at the moment
If you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here.
Old 03-05-2009   #1
Robbo's Avatar
Real name: Mark
Just had a quick check and managing to get these right now.
Getting 11919H,11996H,12226H,12303H with a good picture here, near London.
plus almost getting quite a few others.
Old 03-05-2009   #2
Real name: nelson
My System: Strong 4375 - 1.8 channel master offset - inverto 0.3 C120 twin and pauxis C band l.n.b.,s - Vantage X221S CI usb - skystar 2 pc card - Technomate 1500 CI super - + fixed dishes
hi -
yes indeed -- i,v only ever picked up 1 horizontal a few weeks ago here in northwest uk - with 1.8 metre dish
tonight i,m getting pictures from 3 or 4 horizontals with no break up -- watching fox movies right now --- brilliant
regards n_b
nelson_b is offline   Reply With Quote
Old 03-05-2009   #3
Robbo's Avatar
Real name: Mark
Can't get Fox movies, almost though, just a few more cm would do it right now.
Old 03-05-2009   #4
Real name: nelson
just beginning to break up - now
certainly the best result i,v had from nilesat --
time to turn in now though
cheers n_b
Old 03-05-2009   #5
My System: 1.3M eurostar DISH,MOTOR 42e-18w,65CM FOR SKY, TMS 1500 , ECHOLINK 777, SHARP LNB,TM6800 HD+WF165 CABLE
Hi all
i have to agree with you all that the last few days the H transponders have been v strong.
I can even get 11804H at 9pm.(this transponder is super weak)
FORKS is offline   Reply With Quote
Old 03-05-2009   #6
Robbo's Avatar
Real name: Mark
Can you normally get any of the H's on the 1.3m forks?
11766H in particular?
Old 03-05-2009   #7
sonnetpete's Avatar
Real name: Pete
My System: Gibertini 1M XP Premium - Inverto Black Ultra .2db LNB - Technomate 2200 motor - Vantage 7100 HD. 57E - 22W - 60cm solid oval dish fixed on 28.2 - Humax Freesat HD - Sony Bravia LCD - Sony BluRay and Sony Home Cinema
After reading this thread I rescanned 7°W and found the following:
11104H_S/R_2169_T1 Service_63 Strength_81 Quality
11098H_S/R_2169_Waseet_62 Strength_72 Quality
11104 is showing a press conference and 11098 a station logo slide, which confusingly states 'Nilesat 10775H, Arabsat 11823V'.
Can someone can confirm the above are indeed on Nilesat, or am I picking up something spurious?
Pete
sonnetpete is offline   Reply With Quote
Old 03-05-2009   #8
Real name: nelson
hi --- sorry - sonnetpete -
your slightly off -- and on 8 west
http://www.flysat.com/abird2.php
cheers n_b
The Following User Says Thank You to nelson_b For This Useful Post:
sonnetpete (03-05-2009)
Old 03-05-2009   #9
sonnetpete's Avatar
Real name: Pete
Aw sh......... darn it!!!!
Checked the tp's on 8W but couldn't see either of those, guess I'll have to rescan!
Pete
Old 04-05-2009   #10
My System: Sky; Raven 90 multi-LNB 1W, 7E, 9E, 13E 16E, 19E; 1m Orbital dish on Moteck SG2100 motor; Technomate 1500, Phoenix Apollo and Kathrein (analogue) etc etc Receivers
I waited up tonight specifically for the possible Hs; decent results (in order of strength) from 12226, 12303, 11919, 12149 and 11996.
Can go and sleep in peace now!
bigtee is offline   Reply With Quote
Old 04-05-2009   #11
SatSearcher's Avatar
My System: 1.2M Channel Master, C120 Invacom 0.3 LNB & Feedhorn, with Humax HDCI2000. 68.5E - 61W
I tried these too last night but no luck getting any H's, but the V's were a bit stronger than usual, even managed to get a watchable picture on the weakest V frequency (12283V) which i can only get every now and then.
SatSearcher is offline   Reply With Quote
The Following User Says Thank You to SatSearcher For This Useful Post:
divibi (04-05-2009)
Old 04-05-2009   #12
Robbo's Avatar
Real name: Mark
Yes, I missed 12149, will have to wait til late to check, not quite there mid afternoon.
You should be able to get the MBC's then, as that transponder (11938V) is about the same strength.
The Following User Says Thank You to Robbo For This Useful Post:
jedi72003 (07-05-2009)
Old 04-05-2009   #13
Yes i get the MBC frequency with about 25% on my Humax HDCI2000, a fair bit stronger than the 18-20% i'm getting on 12283V. For me 12283V is the weakest V. Still never managed to get a lock on an H yet, but will keep trying!
Old 07-05-2009   #14
Robbo's Avatar
Real name: Mark
Right now getting full audio and pictures on FOX Movies, bit like watching a slide show though, with approx 50% missing frames. Watchable though, just,
Also now getting full quallity audi and video on :
12073H,12149H
Old 07-05-2009   #15
sonnetpete's Avatar
Real name: Pete
Just to add to the info, last night I took the following readings.
11919H_64S43Q
12034H_65S43Q
12149H_65S43Q
12226H_65S45Q
12303H_63S46Q
From 43%Q upwards I get a watchable picture, with about 20% or less frames missing. All this has made me hanker after a TD110 or a Fracarro Penta 85!!
Pete
Old 07-05-2009   #16
My latest results at 10pm on nilesat h transponders.
1.3 dish + sharp lnb + wf165 cable. West london
in ascending order - 49% needed for picture lock on tm6800.
12226h 63%q
11919h 62%q
12303h 61%q
12149h 60%q
11996h 60%q
12073h 59%q
12034h 58%q
11958h 57%q
11776h 55%q
11881h 55%q
11843h 54%q
11804h 51%q
The Following 3 Users Say Thank You to FORKS For This Useful Post:
divibi (08-05-2009), Robbo (07-05-2009), SatSearcher (07-05-2009)
Old 07-05-2009   #17
I have some tips for nilesat H transponders.
Try changing the S/R to 27499. I have done a few blind scans and some H transponders show 27499 instead of 27500.
Also i find dropping the frequency by 1 or 2 helps(some some lnbs can have some frequency drift + or - 1 or 2)
or this could be complete nonsense
Set up of the dish is important , just a few mm and the weaker transponders can drift. Even strong wind can make the dish bounce and lose the weak H transponders.
tip 1 - Clean the face of the dish of all dust and clean the lnb cap.
tip 2 - Use the best cable you can afford.
tip 3 - Don’t try and set up the dish in the afternoon as all transponders dive in strength from 3pm-5pm.
tip 3 - Try and align the dish from 9pm(in the UK) as you can make fine mm adjustments that will help you get the weaker H transponders.
tip 4 - Clear sky is the best for H transponders .Even light to medium cloud can drop a few % on the quality.
tip 5 - If the dish is on a motor then set the motor to 0.
Make sure the dish bracket is perfect centre on the motor.
Use a spirt level for all angles of the pole.
Stick a spirt level down the side of the motor bracket and check.
Balance a sprit level on the back side of the dish bracket and check.
Make sure the lnb arm holder is level.
Balance a level on top of the lnb and check.(works with sharp lnb)
Try all adjustments moving the lnb forward and back.
Now drive you motor to 7W
Dont use the loop through on the motor.(this can have a large loss on some frequencys) Cable the lnb direct to the reciver and drive the motor from a second reciever.
I hope this helps get some of those H transponders.
The Following User Says Thank You to FORKS For This Useful Post:
divibi (08-05-2009)
Old 07-05-2009   #18
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4
Surely it must be easier getting those channels from 26ºE. From here you can pick it up on a coat hanger.
Huevos is offline   Reply With Quote
Old 07-05-2009   #19
Robbo's Avatar
Real name: Mark
Yes, some parts of Southern Europe are within the footprint of BADR6, but the UK isn't. Fox movies is not possible on a 1m dish from 26E in the UK.
Old 07-05-2009   #20
Also I lost all transponders on AB4A (_http://www.lyngsat.com/ab4a.html) for about 2 weeks after the switch over but now they are all possible on a 1.5m from here.
Latest trend here is an Invacom bullet LNB for 26ºE attached on the side of the spider of a prime focus Famaval dish. Works on dishes from 1.8m upwards.
The Following User Says Thank You to Huevos For This Useful Post:
divibi (08-05-2009)
Old 12-05-2009   #21
satelliteman's Avatar
Real name: Paul
1m Gibertini, location Midlands. Obviously no H Tp's but receivable locked V transponders are as follows >
11823v, 11862v, 11977v, 12015v
satelliteman.
An Installers Choice
Follow us on
Old 12-05-2009   #22
Robbo's Avatar
Real name: Mark
That is most of the Nilesat 101 verticals, just missing 11747V and 11785V.
Old 12-05-2009   #23
Just in case anyone is interested I've now found AB4A (A.K.A. Hotbird 10) again. I lost it because it has moved and is not right next to Nilesat 101 anymore but 0.35º to the west and still slowly going west.
Old 12-05-2009   #24
ian xtv's Avatar
Real name: ian
My System: TRIPLE DRAGON with 500 gb Hard drive. SAB Explorer CISC. Gibertini dish 1m Aluminum. STAB-USALS "GbSat" Branded HH100 Motor. cas interface 3. Diablo Light v.2.3. Redlight Tv card. 45 East - 45 West
1m Gibertini, location NORTH WEST city 7,Txt are the best signal here from 9pm-1030pm.Tested SAB Explorer CISC Digital satellite receiver, Getting plenty of V transponders last night.Triple Dragon only gets City 7 and TxT.
ian xtv is offline   Reply With Quote
Old 14-05-2009   #25
'What's On' Guru
dvmedia's Avatar
Real name: Chris
My System: 1m Orbital Motorised Dish, Fixed 65cm Fortec Dish on Astra 1, Fixed 45cm Minidish on Hotbird, Pace MSS500, TM-5600D CI USB Super, Nokia 9800s, Skystar USB 2, Grundig Sky Digibox, Manhattan Plaza XT-M
Best newbie geek pit /age ratio 2005
Now getting FOX Series blasting in on a 1M Orbital on Nilesat.
Solid, watchable 55% quality
>> BBC Worlds' ultimate fan <<
>> Satellites are an expensive hobby that run away with you. I am living proof of this... <<
dvmedia is offline   Reply With Quote
horizontals, moment, nilesat, strong
[IMG] code is Off
