Sirius 5e - Nordic Transponders???
If you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here.
Old 03-05-2009   #1
My System: Sky; Raven 90 multi-LNB 1W, 7E, 9E, 13E 16E, 19E; 1m Orbital dish on Moteck SG2100 motor; Technomate 1500, Phoenix Apollo and Kathrein (analogue) etc etc Receivers
I am curious as to whether folk here can receive signals from the BSS/FSS Nordic beams of the 4.8e satellite. If so, which transponders?
I'm planning to fine-tune my set up and it would be helpful to use this as a test and compare.
@Robbo (who is near me), your results on the 1m Orbital in particular and the TD 110 (if they are available) would be very helpful.
bigtee is offline   Reply With Quote
Old 03-05-2009   #2
My System: Passion HD, Nova HD S2, 85cm Mesh Dish, Fortec Star Diseqc Motor, Diablo CAM, Sky+ HD, Selfsat H10D2, Hauppauge HD PVR
With my 85cm dish in Glasgow I can get all of the Nordic beams in good weather. Some are stronger than others, here is a list of signal quality readings from my Passion HD taken today (dry but partly cloudy).
11727 H - 64%
11785 V - 51%
11804 H - 54%
11823 V - 52%
11843 H - 55%
11862 V - 54%
11881 H - 54%
11900 V - 54%
11919 H - 55%
11938 V - 54%
11958 H - 55%
11977 V - 55%
11996 H - 55%
12015 V - 55%
12034 H - 56%
12054 V - 51%
12092 V - 52%
12399 V - 50%
12437 V - 53%
12456 H - 60%
12476 V - 62%
The Passion needs 50% quality to reliably lock a signal so as you can imagine most of these have no rain fade margin.
Ratchet is offline   Reply With Quote
The Following User Says Thank You to Ratchet For This Useful Post:
bigtee (03-05-2009)
Old 03-05-2009   #3
My System: Fortec Star FS-4200, Comag SL30/12, Triax TD110 dish, Jaeger99 motor, AzureWave AD-SP400 PCI card (Twinhan thing)
Ive just had a look at 5e too In Southampton on my TD110 and the Nordics seem to be about 58-59% Level, 98% quality on ALT-DVB (Mantis DVBS2 card). I havent double checked every Nordic freq, just picked a couple off of Lyngsat that are listed as Nordic and not Europe beams.
Weather currently overcast, dish probably isn't perfectly aligned either!
moojuice is offline   Reply With Quote
The Following User Says Thank You to moojuice For This Useful Post:
bigtee (03-05-2009)
Old 03-05-2009   #4
My System: TM 6900 Combo Motorised 80cm + dual lnb in UK TM 1500 Motorised 80cm in Cyprus Pinnacle Showcenter 200 MR Reloaded Diablo 2.3 Hotbird 13E Astra 1M widebeam Astra 1H 1W T2 Beam 7E,5E,10E,16E,26E,33E,42E 4W,7W,8W,12.5W,15W All Ok with 80
50% signal in SE kent with 80cm
Uk2cyp is offline   Reply With Quote
The Following User Says Thank You to Uk2cyp For This Useful Post:
bigtee (03-05-2009)
Old 03-05-2009   #5
satelliteman's Avatar
Real name: Paul
4.8°E, BSS Nordic beam Transponders >
11.727H
11.785V
11.862V
Midlands, 85cm.
satelliteman.
An Installers Choice
Follow us on
The Following User Says Thank You to satelliteman For This Useful Post:
bigtee (03-05-2009)
Old 03-05-2009   #6
wod
wod's Avatar
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+
here is what i get but I'm probably nearer the footprint
11727 H - 83%
11747v 73%
11785 V - 70%
11804 H - 76%
11823 V - 75%
11843 H - 76%
11862 V - 76%
11881 H - 76%
11900 V - 73%
11919 H - 76%
11938 V - 73%
11958 H - 76%
11977 V - 73%
11996 H - 76%
12015 V - 73%
12034 H - 76%
12054 V - 73%
12092 V - 76%
12399 V - * hd no receiver to test
12437 V - * hd no receiver to test
12456 H - 83%
12476 V - 83%
west yorkshire, 90cm channel master, smart titanium lnb, vantage x221ci receiver
The Following User Says Thank You to wod For This Useful Post:
bigtee (03-05-2009)
Old 03-05-2009   #7
Site administrator
Analoguesat's Avatar
I can just get the Nordic beams on one of my battered 80cm dishes in good weather - the first hint of rain and the signal disappears (didnt see much of them during the last year!)
Ive just swapped that old dish for my 85 cm Penta so Im expecting a better performance once I get it fully tweaked and the hedge trimmed back a bit.
(Ive also mounted the pole correctly so it doesnt swing around in high winds which should help a bit!)
Analogue forever!
The Following User Says Thank You to Analoguesat For This Useful Post:
bigtee (04-05-2009)
Old 03-05-2009   #8
Real name: Paul
Another Penta boffin A/S, looking forward to a signal report across the skies up there
satelliteman.
Follow us on
Old 03-05-2009   #9
Site administrator
Its only roughly aligned at the moment as I had to go out this afternoon. If the weather is ok next weekend I'll have a go at tweaking it up a bit.
Analogue forever!
Old 03-05-2009   #10
Real name: Paul
So the birds lost their bird bath then as last time I saw it she was on the ground (posted a while back)
satelliteman.
Follow us on
Old 03-05-2009   #11
Site administrator
They lost the bird bath a long time ago - its been propped up under the hedge blocking up a gap for a while!
Analogue forever!
Old 04-05-2009   #12
Thanks all for responses; rather surprisingly, I have always been able to get only about three of the Nordic transponders (12456 and a couple of others); quite baffling considering my results on other satellites in the arc westerly from 5e right from 1w - 30w including Nilesat! However, I can't get further east than 5e due to obstruction; maybe that has something to do with it or is the footprint of the Nordic TPs weaker down here in the south?
Old 04-05-2009   #13
Unfortunately the officialy published footprint doesn't even include most of the UK. But at your location I would expect the signal to be better than at mine, particularly as you have a 1M dish Vs my 85cm. Is it possible that your arc is off slightly resulting in the wrong elevation when the dish is at 5.0E ?
Old 04-05-2009   #14
Ah ---- I should say, my motorised set-up has the one small flaw; the mast is makeshift and probably not 100% plumb vertical. Nevertheless, I get very very good results on all satellites within line of sight (including Thor Nordic and Nilesat Vs and some Hs occasionally) - so the tracking seems reasonable!
nordic, sirius, transponders
[IMG] code is Off
