South American SatellitesIf you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here. | |
| Member Join Date: 28-10-2008 Location: ireland
My System: Computer: 2.2 ghz intel core 2 duo E4500 Asus P5W DH Deluxe 2 Gb ram Satellite System: 80 cm lidl dish and decoder which works surprisingly well! |
Hello There, its my first post ! I was interested in being able to receive satellites such as intelsat 9 58 W, nss 806 40.5 W, intelsat 805 55.5 W etc In Ireland. According to Lyngsat these birds have C Band hemispherical beams which serve the Americas and Europe. I was wondering what size dish would I need in order to receive these birds. Thanks. | ||
| The Following User Says Thank You to abovethehorizon For This Useful Post: | divibi (16-05-2009) |
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | If you look at the footprint info on lyngsat it gives an approximate dish size. | ||
| To start serious reception on American birds, you need to get a site that will allow a minimum of a -good- 3 metre dish (one that is motorised on two planes). Access to these satellites will require a clear line of site to the west, no trees or buildings in the near vicinity. | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| The Following User Says Thank You to Channel Hopper For This Useful Post: | abovethehorizon (16-05-2009) |
My System: Computer: 2.2 ghz intel core 2 duo E4500 Asus P5W DH Deluxe 2 Gb ram Satellite System: 80 cm lidl dish and decoder which works surprisingly well! | Thanks guys, unfortunately my horizon is largely obscured by houses. NSS 806 might be a realistic satellite that I can receive, its elevation in my area looks high enough to avoid interference from ground noise. The problem would probably be how powerful would this satellite be in Ireland ? According to Lyngsat a 1.6 meter dish would work for c band. But maybe 1.8 ? | ||
| | #5 | ||
| Ground noise can be minimised by inverting the dish if it is offset. A 1.6m dish is really the smallest you can use for C band on any satellite with the exception of the older Gorizonts. | ||
| The Following User Says Thank You to Channel Hopper For This Useful Post: | divibi (16-05-2009) |
| american, satellites, south |
