plywood fresnelIf you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here. | |
| Regular Member Join Date: 23-01-2004 Location: New England
My System: stm5105 based receivers | 4 page article scanned from october 1985 Radio Electronics magazine describing how to build a flat plywood fresnel C band dish antenna. The lnb mounts behind it. | ||
| Ahh, fresnel lenses, like boom/stick antennas, are the sort of thing one looks at when there is really no other alternative, (and then give up, or bribe the man next door). Search for Mawzone(s) and then look in your neighbourhood for something similar. Flat dishes!! Some interesting reading below, Fourier transforms, Maxwell and Huygens formulas abound. _http://books.google.co.uk/books?id=Ik21bBBOYyIC&pg=PA5&lpg=PA5&dq=diffractio n+antennas&source=bl&ots=7e3KraTQnk&sig=X44aglc6KJ gKZdYp3Qin1WpFcmQ&hl=en&ei=NtsqSvrSFZTKjAfq7JD6Cg& sa=X&oi=book_result&ct=result&resnum=7#PPP12,M1 | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | Relatively small one for ku band can be easilly made at home, using blank PCB. | ||
| | #5 | ||
| The problem with Ku band is the extreme bandwidth between 10.7 and 12.75 GHz. No Fresnel design will perform well over such a range. | ||
| | #6 | ||
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | u can have 2 different ones, connected via 22khz switch | ||
| | #7 | ||
My System: stm5105 based receivers | | ||
| | #8 | ||
| For that satellite at your location you could easily construct one from any bit of ply, or make a template out of a piece of aluminium if you own a jig-saw. | ||
| fresnel, plywood |
