Satellite reception in South AfricaIf you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here. | |
| Member Join Date: 05-01-2009 Location: South Africa - GP
My System: 2 x Deltech 24x7 Receivers 1.8mtr mesh dish (C) 90cm solid dish & H-H motor (KU) Satlook Micro G2 |
Hi all, Hope this is the right section to post this topic. I have an FTA receiver &1.8mtr C-band dish pointed at 68,5E. LNB has the following info: Input: 3.4 - 4.2 GHz Output: 950 - 1750 MHz LO : 5.150 GHz Noise : 17K With this setup, what other satellites would I be able to pick up that have FTA programs. I am based in Johannesburg, South Africa and have no buildings or obstructions that could affect my signal reception. Another question I have is the meaning of S/R.....why is it that when I do a blind search I cannot receive transponders that have a S/R of 27500....is there a logical solution to this. Any assitance will be appreciated. | ||
| The Following User Says Thank You to satlearner For This Useful Post: | divibi (21-06-2009) |
| Regular Member Join Date: 05-09-2008 Location: Rastatt/Germany
My System: CKD 12 (3,66m) | Hello satlearner, here some positions, that should work in South Africa in C-Band @western Positions: Intelsat 10-02 @1°W -> every beam Atlantic Bird 3 @5°W Intelsat 901 @18°W -> SE Hemi and east hemi, but not NE Zone and West hemi. Global beams have more low signal for 180cm. NSS 7 @22°W -> East hemi, Global and SE Zone, not West hemi Intelsat 905 @24,5°W -> Global beam has low signal for 180cm Intelsat 907 @27,5°W -> only East hemi! Intelsat 903 @34,5°W -> only SE zone Intelsat 705 @50°W -> Global beam (one Feed from Nigeria) Intelsat 707 @53°W -> East hemi signal is very low for 180cm, her is Global beam much stronger Best Begards Edgar. | ||
| The Following User Says Thank You to dx qwer For This Useful Post: | satlearner (18-06-2009) |
| | #3 | |||
| Member Join Date: 19-11-2008 Location: South Africa
My System: Dreambox 500 S, Eutelsat W3A and Intelsat 7 & 10, Sirius 4.8E, Telstar 12 | Hello Satlearner from Jozi I am not sure if you are familiar with Satcodx and Lyngsat. If not you better get googling ... That's my only advise! I would also advise you to google sasat as well. Ta Mashster
| The Following User Says Thank You to mashster For This Useful Post: | divibi (21-06-2009) |
| Specialist Contributor Join Date: 28-05-2003 Location: Stuttgart (48.79N/9.19E)
My System: Kabel BW | Indeed that's the only SA sat board of which i am aware of that is still alive: _http://sasat.forumup.co.za/index.php?mforum=sasat But as you can see here are quite some people familiar with C-Band reception and will help you. But local boards are important since reception conditions can differ a lot from place to place. | ||
| I demand: Pay-TV subscriptions worldwide available - with any receiver - just like print magazines ! Free access for free citizens now ! | |||
| The Following 2 Users Say Thank You to deepbluesky For This Useful Post: | divibi (21-06-2009), satlearner (18-06-2009) |
| | #5 | ||
My System: 2 x Deltech 24x7 Receivers 1.8mtr mesh dish (C) 90cm solid dish & H-H motor (KU) Satlook Micro G2 | Hi Edgar, Thanks for the info. I will try out the positions and I am making a mod to the mounting of the dish as this will allow easier movement for setting up. Another thing I am working on is a multi lnb setup. I plan on using two additional C-Band LNB's and one KU- lnb. I also read that I am able to install a KU lnb on the mesh dish I currently have. According to the info, the KU lnb will work on the mesh dish as long as the hole diameters on the mesh is smaller than 1/4" (6.35mm). This will be a trial as I am still playing around with my other dish that has the HH90 motor on it. | ||
| | #6 | ||
My System: 2 x Deltech 24x7 Receivers 1.8mtr mesh dish (C) 90cm solid dish & H-H motor (KU) Satlook Micro G2 | Hi Mashster, Thank you for your contribution. I am aware of Lyngsat and SatcoDX. Sure there is a welath of information there, but what I am looking for more refined info. I'd like to know what others have found as being interesting sats. There have been many updates in the past six months, I used to be able to receive channels like B4U music & B4U Movies as well as Ujala which were on Asiasat 3S, now these have left and they used to be FTA. I have still not been able to locate these. I would have loved to be able to receive the signals from Eurobird @ 28,5E but this is not possible. | ||
| africa, reception, satellite, satellite reception, south, south africa |
