Octo LNB output in Cyprus
If you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here.
Old 30-06-2009   #1
My System: Prime 2.7m dish Invacom C120 Quad LNB Pace DS430N receiver
I have a 2.7m Prime dish with Invacom C120 quad output LNB and C120 horn in Cyprus.
This system works well with all normal channels received here but I need to increase the number of outputs.
Can anyone recommend the best solution? Is there an Octo independent output LNB that will work with this setup in this fringe reception area?
If not, can anyone recommend a powered switcher unit and how to set it up?
Many Thanks
Pablodaddy
pablodaddy is offline   Reply With Quote
Old 30-06-2009   #2
Robbo's Avatar
Real name: Mark
You may run into problems finding a C120 Octo LNB, a c120 Quattro with a multiswitch is probably your best bet.
Octo C120?
The Following User Says Thank You to Robbo For This Useful Post:
pablodaddy (02-07-2009)
Old 30-06-2009   #3
aka Skyman
Zorba's Avatar
My System: 3m(sky),1.8m(astr/hotbird),1m (nilesat)1m(arabsat)diseqc 4,sky plus,humax freesat,visionet 8000s,technomate 5400 ci+ usb super. Satlook nit colour + Horizon hdsm. wii
Never seen a octo prime focus, yet , so I recommend an Inverto quattro and a Terra multiswitch with 10 or more outputs.( good to have a couple of spare outputs in case the output dies or someone decides on getting sky+. You probably will need a power supply near the dish( in a water proof housing).
Zorba is offline   Reply With Quote
Old 02-07-2009   #4
Thanks for your advice. I suspected that a quattro with a multiswitch was going to be the only way but needed to be sure before I spend the money.
I shall probably go with an Invacom C120 quattro and Vision V75-512S 12 output multiswitch. Anything other than a C120 LNB will mask too much signal here. Comments would be appreciated on this setup.
Thanks again
cyprus, lnb, octo, output
[IMG] code is Off
