bbc on 27.5 wIf you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here. | |
| Member Join Date: 02-07-2009 Location: norway
My System: i use a 1.5 meter dish for reception and my pc system is mac |
I live in norway just outside oslo. Trying to get astra 2d for 2 years. have a 1,50 dish with humax freesat hd. Sporadic picture especially during afternoon. Read now that bbc is on intelsat 27.5 west. You need a mpeg 4 dvb s2 8 psk tuner to get it. i would really appriciate some help in choosing the right tuner. The footprint map says that 80 cm is good enough. | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | You can't view those channels with a domestic receiver. They are BBC feeds for DTT transmitters, probably using a proprietary encryption. Llew | ||
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5ºN, 0.5ºW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | What dish have you got? Is it 150cm horizontally? What LNB are you using? Are you certain the dish is aligned properly? | ||
| | #5 | ||
| Member Join Date: 01-06-2008 Location: Finland
My System: Ku and C-band | | ||
| | #6 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | The symbol rate is high too. (39777). You might find it's stretching the capability of most DVB-S2 tuners in domestic receivers. | ||
| | #7 | ||
| Member Join Date: 03-02-2007 Location: West Yorkshire
My System: 1.2M Channel Master, C120 Invacom 0.3 LNB & Feedhorn, with Humax HDCI2000. 68.5E - 61W | Yes it's the symbol rate that is the problem. Most domestic receivers can reach an SR of 45000 in DVB mode but only up to 30000 in DVB-S2 mode. Professional receiver needed i think. The encryption used is BISS i believe. | ||
| The Following User Says Thank You to SatSearcher For This Useful Post: | divibi (09-07-2009) |
| | #8 | ||
My System: i use a 1.5 meter dish for reception and my pc system is mac | thanks for your help everybody. I have a 1 50 channel master and a digiality 0.2 lnb. It has been aligned by a professional guy with a satlook meter. It is possible to enlarge the dish to 1 80? With aluminium perhaps. Also i was wondering if it might help to convert the dish to a similar dish to the old philips dish. The one with the small saucer dish at the front and the reversed lnb. | ||
| | #9 | ||
| Specialist Contributor Join Date: 12-01-2005 Location: naples italy
hello to all. ok here is some info. the bbc 1 and bbc 2 etc is in the clear it has been running since 20 april 09. yes the symbol rate is high 39.777 and most receivers will not lock in on this at all. but there may be some new ones on the market that might. i have tried to receive this with a 1.7 m dish here in naples and no way. i pickes up spanish at 30 west but not the 27.5 west. using a spectrm is you can not see the lobes its not use it. wether it goes encrypt in the future is anyone's guess. for now its in the clear. most receivers mpeg 4 will only go to 30.000 mpeg 4 there are new receivers in china that may go to 40.000. if anyone can pick up tv 5 lobe on the spectrum on 11.665 v then the other will work with the right receiver. even if it was week i would do the research and find a receiver that would work. its not there at all. ralph | ||
| The Following User Says Thank You to ralphmagno For This Useful Post: | divibi (09-07-2009) |
| | #10 | ||
| Sat Freak Join Date: 05-05-2005 Location: javea,costablanca..ESPAÑA
My System: Motorized Gibertini OP150 ,Motorized Fibo MF90, 2X ASC signal 1.20 on stand by,ASC signal 1.80 ,Famaval 1.80 , 60cm eliptical raven ..hirschmann fibre glass 1.20m....and more gadgets | as said and resaid many times you´ll be needing something like this _http://www.scopus.net/pdf/products/IRD-2900.pdf to be abel to process the BBC signal from 27.5º regards | ||
| The Following User Says Thank You to pipino For This Useful Post: | divibi (09-07-2009) |
| | #11 | ||
| Specialist Contributor Join Date: 05-04-2008 Location: Costa Blanca, Spain
My System: 1.8m PF Dish, most sky and freesat recivers, 80cm on Illusion motor and Dreambox DM7025, TDT | according to some other forums, there are some dtt feeds also on 24.5 on 11055 h 18500 3/4 which started up yesterday...you will need a S2-8PSK receiver | ||
| The Following User Says Thank You to woborny For This Useful Post: | divibi (09-07-2009) |
| | #12 | ||
| 'What's On' Guru Real name: Chris Join Date: 25-06-2005 Location: High Wycombe, Nr London, UK
My System: 1m Orbital Motorised Dish, Fixed 65cm Fortec Dish on Astra 1, Fixed 45cm Minidish on Hotbird, Pace MSS500, TM-5600D CI USB Super, Nokia 9800s, Skystar USB 2, Grundig Sky Digibox, Manhattan Plaza XT-M ![]() Best newbie geek pit /age ratio 2005 | Maybe a dim question, but I don't know the box's spec's... Would a QualiTV receiver be suitable (as I know they are quite flexible, and can be used for feeds..)? ust a thought | ||
| >> BBC Worlds' ultimate fan << >> Satellites are an expensive hobby that run away with you. I am living proof of this... << | |||
| | #13 | |||
| Regular Member Join Date: 13-06-2005 Location: 8e 43.9n
My System: motorised Gibertini 125 - fixed dish 72 - stabHH120 - lnb Sharp 0.4 - Jepssen ST HD3 / 1TB WD e-sata hdd - Fortec Passion HD - QUALI IRCI HDTV - Homecast PVR 300 - Digiscrappybox - various CAMs - various subscriptions | QualiTV used to be a pretty innovative receiver with his 4:2:2 capability, dvi connection, hd high level pic quality, solid hardware (but poor software support and with many bugs) but it's completely out of date now, at least in Europe | |||
| 275, bbc |
