smw prime focus 180cm
If you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here.
Old 05-07-2009   #1
My System: 1.2M , DreamBox 500-s Chinese
Smile smw prime focus 180cm
Hi
I can't seem to find how to send a PM to a member in this forum
So I write here - sorry .
I want to use it for KU reception .
I have an option to purchase a used SMW 180cm primefocus sat dish .
With Motor for a very good price .
But I can't find any info about it .
On the SMW site I only read that the OA-1600 was the largest dish they manufactured but this dish is also made from fiber and has the SMW and Waves logo on it .
How does this old sat dish compare to the new KU prime focus dishes made of still from a company like jonsa ?
What is the gain of this SMW ?
Can I use it with a regular universal LNBF ?
Are there still FeedHorns avaible for it ?
Thanks .
vipersvcd is offline   Reply With Quote
Old 05-07-2009   #2
Amo Amas Amant Admin
Topper's Avatar
Hello
Welcome to the forum vipersvcd
I have detached your post from the thread you tagged on to.
Sorry but you have to earn PM priviledges, you don't join a forum so that you can PM people, the very purpose of a self help forum is that you can read how to achieve something or as in your case you are asking a specific question which others read and advise about.
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 05-07-2009   #3
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
Originally Posted by vipersvcd View Post
Hi
Thanks .
I may be wrong, but I wasn't aware that SMW ever made prime focus dishes. Possibly they were manufactured for commercial headend use sometime in the 1980's before they concentrated on offset dishes.
Llew is offline   Reply With Quote
Old 05-07-2009   #4
pictures
Hi .
I visited the seller to day and took some pictures
He says its about 11/13yr old .
_http://img32.imageshack.us/img32/8228/26064769.jpg
_http://img213.imageshack.us/img213/4075/68931819.jpg
Old 21-07-2009   #5
My System: None at the moment
That is a SMW Jumbo 140cm dish.
Telia is offline   Reply With Quote
Old 21-07-2009   #6
Hi
I didnt update
But this is an SMW 150 .
Not 180 .
Old 21-07-2009   #7
Llew's Avatar
That's an SMW OA-1400 offset dish (13 degree offset angle) with a prime focus LNB bracket.
SMW did a polar mount for this dish allowing a 57 degree east to 80 degree west using a 40cm actuator. Doubt if one can be found now.
Old 21-07-2009   #8
Sat Freak
pipino's Avatar
My System: Motorized Gibertini OP150 ,Motorized Fibo MF90, 2X ASC signal 1.20 on stand by,ASC signal 1.80 ,Famaval 1.80 , 60cm eliptical raven ..hirschmann fibre glass 1.20m....and more gadgets
yes ..nice vintage stuff ,i think we will never see high quality stuff like this again..thanx to the chinees
http://www.satellites.co.uk/satellite/signaturepics/sigpic87537_4.gif
pipino is offline   Reply With Quote
Old 21-07-2009   #9
Llew's Avatar
High quality stuff indeed. Should be as good for many more years. As with all SMW dishes (except the 550), they are moulded in ABS plastic and withstand almost anything you can throw at them.
OA-1400 spec -
1500 x 1420mm
Offset 13 degrees
5.5mm ABS
EMC shielding + Acrylic top coat covering copper reflector
Galvanised back support
Gain 43.3dB
f/d ratio 0.45
Beam width 1.2 degrees
Weight 16.2 kg
Old 22-07-2009   #10
Well this one came with the polar mount and the actuator .
I guess I only measured it from top to bottom and see that its 150cm
And thought it was a prime-focus .
Do you think that a 43.3 gain is good in today standards
For this size ?
The Gibertini OP-150 does 43.3db gain at 10.95Ghz
Does this SMW does the same ?
Old 22-07-2009   #11
Sat Freak
pipino's Avatar
i would say yes
Old 22-07-2009   #12
Llew's Avatar
That's gain at 12MHz for the SMW dish. As gain of a dish increases at higher frequencies, expect a lower value in the lower band (surface area of the SMW is less than the Gibertini).
A good match of the feedhorn to the dish will be a factor to consider. If the dish has the original feedhorn, get a decent C120 LNB, an Invacom or Inverto for example.
Old 22-07-2009   #13
Sat Freak
pipino's Avatar
with these dishes i would say XM610 would much just perfectly
Old 20-08-2009   #14
My System: 140cm smw offset dish,strong analogue receiver to move dish,technomate 1000d super,also 5200 d super with smart 0.1db ku lnb and 17k c-band lnbf
hi LIew i have purchased the smw 140cm dish complete for £50 do you know the value of the focus,many thanks
pride21 is offline   Reply With Quote
Old 20-08-2009   #15
Sat Freak
pipino's Avatar
if you confirm its a offset dish you will be looking for a XM610 feedhorn
Old 20-08-2009   #16
Llew's Avatar
The f/d ratio is 0.45. The XM 600 series will work OK with f/d ratios of between 0.45 -0.65.
Old 20-08-2009   #17
Llew's Avatar
Not sure if an offset LNB will work OK with the OA-1400 pipino, as it has a prime focus LNB bracket.
I would be interested to know what LNB/feedhorn is already on the dish (if it came complete) if pride21 could attach a picture.
Old 20-08-2009   #18
hi LIew thanks for reply i took off the lnb holder as i use c-band lnbf with fortec star lnb holder and ku with the fortec star holder,i just wanted to know if you knew the lenth of the focal length from the dish to see if i have got it right
Old 20-08-2009   #19
Llew's Avatar
I don't have that dish myself, vipersvcd may be able to help. Don't know if it's suitable for C-band working, you'll have to modify the f/d ratio of course, probably by trial and error considering the non-standard shape of the dish.
Old 22-08-2009   #20
hi Llew spent some time to focus c-band results very good get most sats from 64e to 55.5w, i now get 18w AIT is quite strong and the light channel,i also use an lnb for offset dish works very well.
Old 22-08-2009   #21
Llew's Avatar
Good to hear that pride21. Wouldn't mind one of those dishes. Rare as hens' teeth
180cm, focus, prime, smw
[IMG] code is Off
