showtime sat channel on7wIf you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here. | |
| Member Join Date: 22-05-2003
I have posted this information on several other forums...... The situation with Nilesat is really very simple. If you want vertical channels this is pretty easy with a reasonable sized dish. If you want horizontal channels then you will need a much bigger dish. Here is a guide I produced for another forum:- With regards to the UK and Nilesat 7W reception, the further east and the further south you are, the better the signal. The further west and north you go the weaker the signal. Reception is also better when the weather is good and gets better from about 9pm in the evening till about 4 or 6am in the morning and then weakens through the day hours. Vertical channels are much, much stronger. Rough guide for horizontal channels (the weakest ones) Tip of Kent 1.0 -1.2 m London / South coast 1.2 -1.5m East Anglia 1.5 -1.8m Bristol South Wales 1.8-2.0m SW Eng 2.0 -2.4m Midlands, South Ireland 2.4 - 3.0m Lancashire & Yorkshire North Wales Northern Ireland 3 -3.5m Boarders Tyneside 4.0m+ Scotland ?? yikes Vertical channels require much smaller dishes and can be obtained as far north as Scotland on not too big a dish. Vertical only Tip of Kent 60cm London / South coast 80cm East Anglia 1.0m Bristol South Wales 1.0m SW Eng 1.0m Midlands 1.0 -1.2m Lancashire & Yorkshire North Wales Ireland 1.0-1.5m Boarders Tyneside1.2-1.5m Scotland 1.2-2.0m- reni | ||
| Member Join Date: 14-07-2009 Location: south wales
My System: tm 5400 ci 80cm motorised dish |
could any members in s.wales or the west country who recieve this sat please post under this thread,so i can try and work out what system ineed to buy to try and receive it thanks | ||
| Super Moderator Join Date: 10-12-2004
![]() | I have moved a useful post by renibacterium to your thread which you might find useful. | ||
| The Following User Says Thank You to Mickha For This Useful Post: | john evans (19-07-2009) |
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | From the posts around the forum, and working from memory Id say some of those dish sizes in the top post are wrong for the H polarity channels. ![]() South Wales - around 2.4m in the Cardiff area Lancashire - very few reports that far north, but 2.4m probably in the Manchester area Scottish Borders and further north - forget it Problem is of course that extreme fringe reception is at best a guess for the H polarity stuff, very few folks have dishes big enough to even have a go, amnd as we know from the Astra 2D situation the signal strengths vary greatly over the distance of a few miles. | ||
| | #5 | ||
| People constantly ask about 7W reception. My posting above is a rough guide as it states . In South Wales, ( eastern part near Bristol) a 1.8m will do for 7W H, but remember the more west and north you go, a bigger dish is required, so for North Wales I state 3 to 3.5m. Dish size info for Nilesat 7W in western Europe & the UK see post 31 For Cardiff a 1.8/2.0 good quality dish should suffice (eg. Channel Master/Andrews or IRTE)but with lesser quality dishes (you know the ones!) a 2.4m may be required. For Lancs the only person I have seen receiving 7W H on a 2.4m dish is Keano. Generally I would recommend a 3 to 3.5m dish for Lancs/Yorks area. | ||
| | #6 | ||
| Member Join Date: 04-08-2009 Location: Berkshire
My System: Technomate 1500CI+ x 6 Showtime card 1.2CM & 1.8CM | Hi, I am new here, my installer recommended i sign up. just set up a channel master 1.2 in an attempt to get showtime in Reading/Berkshire I am getting all the Verticles no problem, 56% signal but the H as not strong enough, at night time i get 38% signal, daytime about 29% so going to upgrade to a 1.8channel master, do you guys think this will be ok? | ||
| | #8 | ||
| Member Join Date: 08-01-2008 Location: West London 51N
My System: 1.3M eurostar DISH,MOTOR 42e-18w,65CM FOR SKY, TMS 1500 , ECHOLINK 777, SHARP LNB,TM6800 HD+WF165 CABLE | Hi garyG, I get most H transponders 24/7 including the main showtime 11996H and 12073H transponder with a 1.3M eurostar dish in West london about 25 miles from you.(but in heavy rain and i lose most H tranponders) A good lnb is the key and mm perfect setup of the dish. I use sharp Lnb's. Mike | ||
| | #9 | ||
My System: Technomate 1500CI+ x 6 Showtime card 1.2CM & 1.8CM | thanks for the replys, are you getting the showtime sports H transponder on a 1.3 dish? I think i need to purchase a better lnb, does anyone know the best place/one for a channel master 1.2 | ||
| | #10 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | You ideally need the matched feedhorn Gary and a C120 LNB. But remember that there are reception hotspots and 30 miles distance can sometimes make a big difference. | ||
| | #11 | ||
My System: Technomate 1500CI+ x 6 Showtime card 1.2CM & 1.8CM | i think the 1.8 is coming with an "uprated" feedhorn that the guy got from channel master, apparently cost him an extra £100 and comes with the official lnb, so might be good. I am collecting it all tomorrow just does not have a mount so going to have to make one up some how | ||
| | #12 | |||
| Regular Member Join Date: 05-03-2009 Location: UK
My System: -------------- | There is no uprated feed horn or official lnb and channel master have not been a company since 2003 i think it was sold to andrews and now the vsat department was sold last year is now owned by asc if the guy has added a extra £100 to the cost of the feedhorn he has scamed you big time as for the lnb a invacom or inverto c120 will be fine. As far as i know there are a few feedhorns they do some only cover parts of the kuband and there is one that does L&R if i am right the is a .pdf on the asc site if you take a look it will tell you.
| channel, on7w, sat, showtime |
