Nokia 9200/9500/9600 with DVB2000 |
The box has to be connected to a pc either via rs232 or scsi port. You will need a utility program called DvbEdit, this has the function for the spectrum analyzer. DVBEdit 5.0 build 61 was the last release.
Scanner options:
Much improved scanner. The scanner now generates a calibration scan the first time a particular LNB configuration is used. When this scan is operating, you need to remove all signals from the LNB by simply taping a piece of cardboard in front of the LNB. DVBEdit then uses this calibration scan so that the scanner charts aren't so dependent on the output signal from your LNB and on the sensitivity of the Nokia tuner.
Screen shot:
