8W -strange S/R!!!If you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here. | |
| Regular Member Join Date: 08-06-2009 Location: QTH: 47°55′43″N 23°53′33″E
My System: C BANDIT | On the satellite from 8W there are 2 radiosendungs with very strange symbol rate 12748 H 716 acording to flysat, on lyngsat is nothing Please check what kind of receiver can get this !An hungarian freak told me he got them with a certain receiver and there is very good signal.I check it with many models but no way to got them! Please test | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Will have a look with the spectrum analyser later, watching something at the moment. | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Well I can see a small bump on my Spectrum, but only 53db and 5db C/N, won't lock and my receiver won't register that frequency, too high. | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Invalid SR on two receivers. | ||
| | #5 | ||
| Member Join Date: 03-02-2007 Location: West Yorkshire
My System: 1.2M Channel Master, C120 Invacom 0.3 LNB & Feedhorn, with Humax HDCI2000. 68.5E - 61W | I used to get this small radio package a few months ago when it used an SR of 1100, after changing SR to 716 my Humax HDCI2000 won't let me enter anything under 1000, my AZBOX lets me enter 716 as an SR but doesn't lock it. There's a similar signal on Astra 3A 23.5E on 12661V using an SR of just 555, can't lock this either! | ||
| | #6 | ||
| Very few tuners in digital STBs have a filter that allows a stable stream of information through to the demodulator circuit when the symbol rate is below 2000. In a similar way to bandwidth of the analogue tuners of a few years ago, it was a compromise between allowing wide or narrow through the tuner circuit, or a switchable system. Symbol rates on satellite range from the sub-thousand up to 45000, which exceeds many receivers using a single filter tuner. Outside, the incoming signal is further affected by the stability of the LNB doing it's job of amplifying a million times, and then downconverting to IF frequency for entry into the cable. Most are trusting something that costs under $2 to make, then wonder why they have trouble locking into something at one or another extreme. The firmware is often locked so that the user cannot enter a three digit number (or a zero as the first of a four digit number). If you are able to lock into 1000 - 1500 then your receiver/system is doing better than 99% of others out there. | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| The Following User Says Thank You to Channel Hopper For This Useful Post: | SatSearcher (31-08-2009) |
| | #7 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | | ||
| | #8 | ||
My System: 1.2M Channel Master, C120 Invacom 0.3 LNB & Feedhorn, with Humax HDCI2000. 68.5E - 61W | I've managed to get as low as SR 1181 with the AZBOX, although my 1st ever digital receiver, a Nokia Mediamaster 9600 had no problems locking onto an SR of 1000, strange that modern tuners can't seem to do the same. | ||
| | #9 | |||
| _http://lea.hamradio.si/~s56fpw/dir/pdf/cq-tv189.pdf Page 41-44 | |||
| There is a very fine line between "hobby" and "mental illness" | ||||
| | #10 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Yep, Topfield manages 1Msps - 45Msps. | ||
| | #11 | ||
| Member Join Date: 02-03-2008 Location: Syros island - Central Aegean sea - Greece
My System: various receivers -Ku Band lnb smart titanium 0.2db-C Band lnb Pauxis 13° K - Motorised dish 1.65X155 (103.0°E-48.0°W) | I get this small radio package ( Radio Contact FR & Radio Contact NL ) with my NOKIA 9600 with dvb 2000 ,with quite good signal 74 % | ||
| | #12 | ||
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | the old dbox 1 can also handle symbolrates under 100 without any problems,but not every tuner of the 4 diffrence,on mediamster 9600 not working,but there was in the past dbox 1,that has the mediamaster tuner,and medimasters with dbox tuner,both of them exitis,in revision A and B! | ||
| s or r, strange |
