| Specialist Contributor
My System: 1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband! | strong Signal Variations,on day/nighttime on intelsat 10 in cband! | | Hello!
with this topic,i want to try to find out,about the strong signal difrence of this in the meantime old satellite!
the indian dordarsshan on 4034 19559 3/4.is one of them with the strongest variations,in the signal!
i want to find out now,when someone in diffrent areas and location,receive it,and what time,dish size is important,and maybe weather condition,temperatur outside also!
then we can see maybe some conformities
in the day/night signal vatiations of each transponder depend on location here in europe,and also other areas,on lyngsat,it looks that this satellite has only 2 beams,but,also in other conitinents,it is not posible to receice all transponders all the time!
with a 2.40m mesh dish!
with 3,66 m mesh for sure it would work,but it is imposilbe to install this size on the roof..
i recogneized,that the variation of signal,affects transponder that use both polarity,with nearly the same freqency, nhk for example,signal here very stable,use nealry the same freqency,with diffrent symbolrates,then one multichoice transponder,the stronger signal,of nhk,take most of the signal on other polarisation away!
in the meantime i got information a solarpanel of intelsat 10 is damage and satellite lost power 25%,does anyone know when intelsat 10 will be replaced,hope the signal will be much stronger in the future !
when every one reports the signal,and the strenth on that time,he receive it,then my target is to make like a signal time table,i dont get all transponders here,my best result was 170 channels with the blindscan,in nighttime when its fog outside or cold and clear sky signal is best,very bad when it is sunny and bluesky! sometimes then i got only 120-130 chanels,and the rest comes back in the night,but weak transponders that are near together,are most affected by the signal variantions,sometimes,a transponder,of the lower freqency is stronger,then it change,and the higher nabour transponder,have more signal and via versa! |
