skystar 2 (rev 2.3) for feed hunting?If you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here. | |
| Regular Member Join Date: 03-01-2009 Location: india
My System: dvb s2 usb for pc | hi friends, just bought new pci card skystar 2 - rev.2.3 for feed hunting and looking for some info for feed hunting as under. 1. What are common frqs and SR for feed hunting. 2. is my card able to get feeds of 4:2:2 feeds. 3. can transedit work with hardware blindscan of this card? thanks ![]() | ||
| ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++ ku dish 65cm , skystar 2 rev 2.3 pci card, dvbviewer pro. location : Gujarat, INDIA. Express AM22 at 53.0°E ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++ | |||
| | #2 | |||
| Specialist Contributor Join Date: 29-06-2009 Location: UK
My System: IP9000HD twin HD tuner operating > Triax TD110 Dish & 80cm FaVal Dish working in Tandem 60degEast to 60degWest Humax HDCI2000 operating > VboxII & 1.8 m Alcoa PF dish + Pauxis C-Band lnbf... Skystar2 /Twinhan SD /TS S2-3200 pci cards |
For 1) I'd go to Lyngsat ... all regular feed transponder frequencies are listed ...and your ability to blind scan makes the a known SR irrelevant I suspect. 2) Yes you can resolve 4:2:2 feeds and variations by making sure you select Elcard codecs in your DVB application. 3 I can see no reason why your card wont work with Transedit. 4 ) ...you are a very lucky man to own one of these cards ... I'd love to get my hands on one .. Where did you buy it ...and do they have any more ? ![]() rgds VS | |||
My System: dvb s2 usb for pc | thanks Vipersan i found it from Ebay I will sure ask for another and let u know. | ||
| The Following User Says Thank You to krishn For This Useful Post: | Vipersan (08-09-2009) |
| feed, hunting, rev, skystar |
