Boosting Weak TranspondersIf you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here. | |
| Regular Member Join Date: 06-04-2004 Location: Riyadh - Saudi Arabia
| Hi ppl , wondering if any one has tried removing the white cap of Universal Lnb and inserting a small pipe ( 3 in ) long inside it would boost the weak signals . Any thoughts you would have be greatly appreciated . | ||
| AL-MADHI | |||
My System: IDD CI24 ECONO MM Penta 1.20 Galaxy II 1.2Mtr Polar MTG yes it has been on the arc for 21 years and is still driven by a modified wiper motor from a Ford Anglia. It's like me sometimes groans but always performs ![]() Saved us from the black plague of ignoratio elenchi, he awaits a special badge with jugs | The plastic cover is to stop anything getting inside. The introduction of a tube or pipe is only going to diminish the amount of signal received, indeed may probably kill it, I certainly doubt it would boost the level of signal received from any transponder let alone a weak one. | ||
| War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back Last edited by Topper; 18-04-2005 at 09:16 PM. | |||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | If you are suffereing weak signals, buy a bigger dish. Its the only real way to improve received signal strength. | ||
| | #4 | |||
| A bit enthusiastic Join Date: 11-02-2004 Location: Sweden
My System: Giberini 100,Cut Interstar GI-201,CD-80 feedhorn,Humax 8100 PVR,Coship 2300a,18 meters of Antec Superflex 1.6/7.3 ![]() |
Have now replaced the current one with a 0.25 mm cover. Why do you think Invacom uses such a thin cover on the snh-031? Inserting a pipe will destroy the signal completely. | |||
| | #5 | ||
| Regular Member Join Date: 03-03-2005
My System: 2.40m Solid Paraclipse Hydro Humax 5400Z G-Guard 9600 Dragon cam 3 Jonsa 1.80m | indeed, removing some caps from some LNB'S increases signals. One guy mentioned, and don't quote me on this, that placing a neon light starter inside the LNB might increase signal. Maybe, its an urban myth. | ||
| | #6 | ||
My System: IDD CI24 ECONO MM Penta 1.20 Galaxy II 1.2Mtr Polar MTG yes it has been on the arc for 21 years and is still driven by a modified wiper motor from a Ford Anglia. It's like me sometimes groans but always performs ![]() Saved us from the black plague of ignoratio elenchi, he awaits a special badge with jugs | I am not disagreeing there at all if you just remove the cap of course you will get more signal through as you are effectively removing an obstruction. In the NW UK with the inclement weather quite often there is a fine build up of dust grime and sometimes this green algae that seems to cover everything these days. Call me simple but I actually clean the lnb cover at least once a year when I am cleaning the algae off my dish. I find that if I do not then the build up of rubbish retains moisture and thus reduces signal quality. | ||
| | #7 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Polish the cap then give it a squirt of wd40 to help rain run off | ||
| | #8 | |||
thanks toppervte33h for your reply Actually Universal Lnb is designed for Offset dishes , But when comes to parabolic primary focus dishes the Universal Lnb doesn't work perfectly due to wider illumination angle , and in order to the universal lnb to work better is to remove the cap of the lnb and inserting a small waveguide pipe down the lnb throat . | |||
| AL-MADHI | ||||
| | #9 | |||
Pledge furniture spray is supposed to be good as well but I have not tried it. BTW I spray Pledge on squeeky door hinges, works a treat!!!! | |||
| | #10 | |||
At what point in the discussion does it turn into a feedhorn???? Look if it works for you I am pleased for you honest but I doubt many people will PM you for specific details, apart from that the fact that you hardly ever see a drop of rain in Saudi and we hardly ever see any sunshine in the UK makes it a very impractical solution for us in the UK especially on a prime focus dish as the "waveguide pipe" you inserted in the lnb would be constantly filled with rainwater. | |||
| | #13 | |||
| Regular Member Join Date: 08-02-2005
| boosting, transponders, weak |
Similar Threads | ||||
| no signal on some transponders | lasharratt | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 3 | 06-07-2006 12:24 PM |
| sky sat signal weak | sky do i bother? | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 2 | 07-10-2003 10:00 PM |
| Sesat transponders | Satdude | Transponders & channels | 0 | 28-08-2003 03:22 PM |
| bbc, astra extra transponders | meatball | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 1 | 25-06-2003 10:18 AM |
| Transponders - Some OK - Some not | richardinalex | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 4 | 04-06-2003 02:03 PM |
