Arabsat & Nilesat Reception in U.K.If you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here. | |
| Regular Member Join Date: 06-04-2004 Location: Riyadh - Saudi Arabia
| Hi ppl , Is the reception of both Arabsat & Nilesat receivable in the Britsh Isles I read a post in other forum that someone has received Nilesat near Manchester city with 1.6m dish , but the reception was very poor . Hoping someone has received these satellites can help me out some info. regarding dish size . Cheers | ||
| AL-MADHI | |||
| Member Join Date: 02-05-2005 Location: asia
My System: satellite&computer setup | Hi all is there any one know how to install the krak by the remote pls advice me for humax 5400 & starsat Please DONT hijack other posts with questions irrelevant to the discussion. Start your own thread in the appropriate section. Some of the ART channels are open, but if you want the sport & movies you are out of luck. | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Reception of Arabsat 3A is possible in the UK with an 80cm dish - 90cm preferable in most areas. You can forget anything transmitted off 2D with a sensible sized dish. Nile sat is just about possible in south east England with dishes of about 1.2m in diameter, although the V polarised channels are stronger than the H's | ||
| Specialist Contributor Join Date: 16-03-2005 Location: Belgium
My System: Dreambox with PLi-Emerald 1.09 image, Matrix revolution CAS, newcamd emu, movable dish 0.85 m, very happy indeed | I've got an 85 cm dish and I get a very good reception on arabsat 3, and a complete nothing on nilesat. | ||
| | #5 | ||
| Member Join Date: 03-08-2004 Location: Northwest UK
My System: Humax CI-5100, 80cm 19.2e/13e/7e, 100cm 1w, 150cm 7w, 240cm on order. | I am in the northwest of england and tried Nilesat on a 1.6m dish. Only got the transponder with the educational channels and nothing else. Even then reception was poor with lots of blocking and breakup of the picture. I now have a 2.4m dish and receive all vertical transponders, only two transponders give a slight problem early afternoons, the rest are rock solid 24hours a day. I will be upgrading the lnb soon to improve those. I had a spectrum analyser on the dish last week and can tell you that the nilesat horizontal channels are non existant. They are so well down on the verticals that it isnt worth trying to think about getting them on this side of the uk. I had a brief look at arabsat, but only to the extent of finding it in the sky. I doubt that there will be much to receive other than 3A. I think arabsat C-band would be a better bet than the Ku-band. | ||
| | #6 | ||
| DB Magician Join Date: 19-07-2003
![]() Merlin of the Idiot Guide | With a 0.6db lnb and a 1m dish, I could get some V channels on 7w late in the evening (south coast uk) on a clear day. I recently changed the lnb to a sharp 0.3db and now can get most v channels all day even with a cloudy sky. The actual signal improvement is marginal but the quality is much better. | ||
| | #7 | ||
| Regular Member Join Date: 18-04-2005
My System: Dreambox 7000s 60 gig segate hard drive | Guys just what im looking for Arabsat possible in the Uk JTA you say arabsat 3 is possible with a 85cm dish what freqs and chanell names I have 90 cm and seem to get nothing wht lnb are you using? Kind Regards | ||
| | #8 | |||
The full 26E channel list is here, but you can forget anything off the other Arabsats in the UK http://www.lyngsat.com/arab26.html | |||
| | #9 | |||
Algeria TV, Morocco TV, Sharjah TV, Al-Iraquia, Aljazeera, Almajd, Almanar, Almustakilla, Eritrea, Future, Hannibal, Jordan TV, Kuwait, LBCI, Libya, Mauritania TV, NBN, New TV, Oman, Saudi 1, Saudi 2, Star Academy, Sudan, Syria, TeleLiban, Tunis and Yemen. Freqs can be found on Lyngsat. I'm using the LNB which came with my dish - the salesman told me it was a pretty sensitive one, but that's all I know. I'm sitting on the Belgian coast, which isn't too far from SE England. | |||
| | #10 | ||
| Specialist Contributor Join Date: 01-01-2000
| A good 2.4 mtr dish of high quality dish should indeed recieve many of the Nilesat channels. The horizontal transponders are indeed around 1-2 db lower than the vertical transponders typically 11919H is one of the lowest transponders. Ps on a 3.7 mtr (professional quality ADI feed and PLL LNB)some of the horizontal transponders are still weak ! occasionally during extremes of weather at my Belgium location there is minimal signal please be advised before make large investments. Arabasat 26.0 east slightly better than Nilesat several transponders have higher reception capibilities within the UK. A high quality and good 1.8 mtr dish will recieve a good selection of KU band horizontal and vertical transponders, and all the C band channels with some Analogue signal threshold addition. On my 3.7 all c Band channels are perfect and the vast majority of KU band are equally very very good. On my 2.0 UK based dish All C band channels are good with Analogue signal threshold addition, On Ku band digital equally majority of the channels are also recieved well.( professional quality ADI feed and PLL LNB) Regards to all old satellite | ||
| | #11 | |||
| Member Join Date: 16-05-2005
My System: Humax CI-81000PVR moterised | I am receiving Nilesat all vertical transponders here in Peterborough with 1.2m dish.
| | #12 | |||
My System: Humax CI-81000PVR moterised | Is that possible to receive Horizonal transponders of Nilesat with 1.2m dish in cambridge.
| | #13 | ||
| Regular Member Join Date: 16-05-2005 Location: KRAKOW / SOUTHERN POLAND
My System: PrimeFocus 180cm (Astra 2D), MABO 115x128 (80E - 30W) , Kathrein ufs910, Amstrad DRX400 SKY Digibox+ Freesat card. | I receive all V transponders on 1,2 offset MABO dish even on rainy days. With regard to H polarised channels i picked some once, but picture was breaking up | ||
| | #14 | ||
![]() Merlin of the Idiot Guide | I (and the mrs) like watching Arabic music on both these sats- although we don't understand the language ! Could someone please tell me what the word 'habibi' means, it is there in all the songs ? | ||
| | #17 | |||
| Regular Member Join Date: 11-12-2004 Location: Stockholm & Windhoek Namibia
My System: 2m NERA Prime Focus Dish for C/ku Bands, DM500, SkyStar2, Technomate 5500CIP, Force 1122. |
I get Nilesat Vertical Transponders all the time except very heavy rain. Horizontal transponders as mentioned are very weak and I see 11919H as the strongest followed by 11766H. I am located near Manchester using a 2m Prime Focus Professional Quality Dish with Invacom 0.3dB LNB and Matched Feedhorn. Cheers. | |||
| | #18 | ||
| ASBO Club Member - Persona non grata Join Date: 30-07-2003 Location: Stockholm, Sweden
| I get Nilesat up as far as in Stockholm, Sweden on a Fibo 90cm dish, MBC2 are pixeling a bit, i guess 10 cm more on dish would have got rid of it. I only get the vertical transponders, the horizontals are dead. Arabsat 3A no problems either. | ||
| | #19 | ||
| Member Join Date: 20-06-2005 Location: Norfolk
My System: Normal |
HI, How did you set up the dish to receive Nilesat? I recently bought a 1.8 dish, and could only get hotbird and Astra on it in Norfolk. Isn't Nilesat to the right of Hotbird. Can onyone please help with sugestions? Thanks a lot | ||
| | #20 | |||
| Regular Member Join Date: 04-04-2004 Location: Germany- Munich
My System: 105 cm motor dish with 75E to 45 W - Openbox 820 CI |
You have to be very carefull by a fixed system when you turn the dish. You also have to turn the LNB a bit to get the right tilt of the LNB Look here to get the proper LNB setting and evaluation for your dish: http://www.satlex.net/en/azel_calc.html | |||
| | #21 | ||
My System: Normal |
Hi, was it hard to receive the Nilesat signal?. I've been trying to get a signal on a 1.8 m dish in Norfolk, but all i vain. Do u have any tips? I only managed to get hotbird and astra, which are strong with a smaller size dish. Thanks in advance. | ||
| | #22 | ||
My System: Normal | Thanks for the reply. It is a fixed system, and it says on the manual that the LNB should be 68.2 cm away from the centre of the dish. That is the only guidline i work by. i did manage to get the right arc, hence being able to receive Hotbird, and i assume they are on the same arc, aren't they? | ||
| | #23 | |||
On Hotbird your dish is 17,66 degrees east so exact 17,66 away from total south. Use a compass to find south. Nilesat is 4,15 degrees west from "0". So turn your dish 17,66 + 4,15 = 21,81 degress to the west if you are on Hotbird. Use a compass for that. Now you should have a proper position. On the evaluation use the scale on the mirror. On hotbird your scale should show something like 26,23 degrees. Change it on Nilesat to 24,69 degress. The last thing you have to do is change the tilt of the LNB. What I mean is you have to turn it in the holder slightly to the left or right till you get a signal. Do not leave in straight. The calculator says for Nilesat + 2,56 degrees. which might be right or left. On hotbird it says - 10,68 so you have to turn it opposite direction for Nilesat. Good luck with it. Hotbird and Astra have strong signals and you do not have to be that accurate to get a signal. But you have to for Nilesat since it is a weak signal. Besides you should receive a lot more satellites than those two. I get about 25-30 Satellites. Cheers Claasi | |||
| | #24 | ||
My System: 2m NERA Prime Focus Dish for C/ku Bands, DM500, SkyStar2, Technomate 5500CIP, Force 1122. | Hi all, I am in the NW UK with a 2m NERA Prime Focus Dish and I receive the following: Nilesat Vertical is fine except during heavy rain and 11747V is the strongest transponder. Horizontal is not receivable normally although I do see 11919H occassionally. Arabsat 2D is not receivable 3A Horizontal and Vertical transponders are easily receivable and much stronger than Nilesat. Cheers. | ||
| | #25 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | 2m is overkill for Arabsat 3A in the UK. I can get it on an 80 cm, although a 1m would be better for more rain fade capability. | ||
| arabsat, nilesat, reception |
Similar Threads | ||||
| Digital Terrestrial (Freeview) TV reception, Aerials! | spiney | Members' input on FAQ and How To's | 0 | 09-06-2005 03:05 PM |
| Nilesat reception reports for UK.... please.!! | JohnC | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 5 | 14-03-2005 05:50 PM |
| Channel 4 Reception problem | athoni | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 14 | 23-01-2004 12:11 AM |
| Bad reception on Channel U (Sky 467) | solara | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 5 | 05-01-2004 01:29 PM |
| Hi/Lo Band reception anomoly? | geoffreys | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 2 | 29-11-2003 05:03 PM |
