Astra 3A, UK Reception and Dish Size MapIf you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here. | |
| | #26 | ||
| Super Moderator Join Date: 01-06-2004 Location: Here again
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | 24/7 here now mate, with the same ant & MTI 0.3 L. | ||
| | #27 | ||
| Member Join Date: 02-03-2004 Location: De Cymru
My System: loads of stuff, i'll get round to listing it all | im in the neath valley 20 miles north of swansea in south wales with a 1.1M dish, 0.3 dB LNB and TM1000D i cant get any of the transponders listed by william-1 | ||
![]() My Linux boxes: DM800, DM600, DM7020Si x2, DM500 x3, TM600 x2, TM500 x2, TM9100Super, TM9100 My STBs : TM1000, TM1500, TM5200Super, TM5300, TM3150, TM3500, TM3300, TM6900, TM6800Super, TM6900Super My dishes : 1.1M solid TM2300 motor TM4 0.1dB quad LNB, 8, 2x 80cm mesh TM2200 motor quad LNB, 80cm mesh TM2100 motor TM1 0.1dB LNB, 60cm mesh fixed @ 28.2E with quad LNB I dont watch TV | |||
| | #29 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Cheers Joe50, have added your results. | ||
| | #30 | ||
| Member Join Date: 18-06-2006 Location: Edinburgh
My System: Triax TD88 dish w/ 4 LNBs (13E, 19E, 23.5E, 28E), Skystar2 2.6 with March beta drivers, Vista, DVBViewer. | Borderline in Edinburgh with a 88cm motorised. It's 100% quality in current cloudy weather, but only just - move it 0.2 degrees either side and it plummets. I suspect if it was raining it wouldn't be watchable. | ||
| | #31 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Is that for the Czech channels as well as the Slovak channels arfster? | ||
| | #32 | ||
My System: Triax TD88 dish w/ 4 LNBs (13E, 19E, 23.5E, 28E), Skystar2 2.6 with March beta drivers, Vista, DVBViewer. | Sorry, didn't realise the difference. Nothing on 12525V or 12649H, not a peep. Must be quite a bit weaker transponders? Astra beam map says 47dBW for me, and normally I'm fine down to 43/44. Correction, my positioner is off by 0.6 degrees (strange as it's spot on for all other sats). Anyway, Czech tps above now scannable, but completely unwatchable - probably needs a 1.1m here. Slovak channels on 12565H are now 100%Q, but only 23% lev so probably a bit dodgy with rain. German ones are now 45%, so would be fine even with the worst weather. | ||
| | #33 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | OK thanks, yes there is a significant difference between the Slovak and the Czech channels. | ||
| | #34 | ||
| Specialist Contributor Join Date: 11-12-2004 Location: yorkshire
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro | hi to all just checked all horizontals seem ok verticals breaking up here in yorkshire 1.2m .3lnb (still looking for a feedhorn) hope this helps | ||
| | #35 | ||
| Member Join Date: 19-07-2004
| i got czech link today with 1m dish and a droll .6 lnb for about 10min in moray scotland( 40 miles from inverness ) then it faded out on me. i have a czech customer who is desperate to get the channels he has subscribed to, funny thing is he got his subscription before he looked for a installer. he speaks very little english, hence its hard to explain to him why he got to watch ct1, ct2, ct24, galaxie sport and prima tv, c5 film, top tv for 10 min. the the signal dropped out. iv ordered a stronger lnb and im contiplating whether i should get him a 1.5 or a 1.8 dish. | ||
| | #36 | |||
| Guest
Posts: n/a
| All there so called strong lnb would not do much better all the 0.3 and 0.2db lnb talk is a waste of time, What you would need is a high qulity dish like the andews 1.8m with ku-band linear feedhorn & c120 lnb,
| | #37 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Theres was some very strange reception conditions all over Europe yesterday, with Astra 2D reported in Cyprus & Tenerife on "undersized dishes" AERIALS & SATELLITES saw Astra 3A, and I had some Sirius 3 tp's on an 80cm dish which I dont normally get...... | ||
| | #38 | ||
| Member Join Date: 01-03-2005 Location: Kilkenny, Ireland
My System: Skystar 2 1.1m Triax 0.2 Titanium lnb | Kilkenny S.Ireland. 1.1m Triax, Smart 0.2 lnb, Skystar 2. Czechlink 45% strength, 100% quality. Pretty sure it is 24/7 Slovaklink 29% strength, 100% quality. Perfectly watchable but goes in moderate rain. | ||
| | #39 | ||
| Member Join Date: 13-09-2006 Location: Sawbridgeworth, East Herts
My System: Triax TD88 (95cmx85cm), Technomate 1600 super, 0.2LNB, Moteck2100 motor. | Good signal now here (not far from Stansted Airport) on my Triax td88. 74-78% on Czech link, and 70-73% on the Slovak link. 24 hour clear picture. Not tested in bad weather yet, but with comfortably over 70% it should not be a problem. Only received these channels after re-allignment by a pro, and a bit of LNB skewing. | ||
| | #40 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Thanks, will add to the map later. | ||
| | #41 | ||
| Member Join Date: 21-07-2007 Location: lancashire
My System: 95dish, satcatcher diseqc motor, Voyager3 rx, cams etc | I have been told by my Czech friends that there are now czech language programmes on 1west. Satcodx confirms this but my motor is playing up so I cannot confirm it. Anyone else tried this spot? | ||
| | #42 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Yes there are, but not much that is Free To Air. http://www.lyngsat.com/packages/digi.html I can receive the ones on the spot beam on my 80cm. | ||
| | #43 | |||
| Guest
Posts: n/a
| There is no such thing as a stronger LNB-f good luck finding a high qulity 1.5m dish with matched ku feed in the uk, Astra 3a is a 1.8m andrews or prodelin job where you are as i have tried it a few times when i have been working in scotland,
| | #47 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | We have no results for Birmingham, but I would guess at bigger than 1.2m. | ||
| | #48 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | I'm in that region, I'll check with a 90cm and post results. | ||
| | #49 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | I actually remember looking for this info on behalf of another installer last month. At the moment with the cloud the result is Nothing and I'm 30 miles from B'ham with a 90cm & Invacom LNb. But... remember some picture blocking when it's a clear day with signal drop out sometimes. Note: There is also a considerable difference in footprint between Horz & vertical transponders from that satellite on that beam. The Vert footprint is weaker from the footprint maps. Hope this helps | ||
| | #50 | ||
| Specialist Contributor Join Date: 09-02-2008 Location: Newtownabbey, near Belfast, Northern Ireland
My System: Dreambox 800 Nabilo Blackhole v1.0/250 Gig/ Dreambox 500s-(clone) PLi Jade/ Relook 400s 160 Gig-/SifTeam 1.93 e enigma Foretec 90cm Dish with Nikkai Diseqc Motor- 2 sky+ receivers fixed 28.2 east. | Watching Death Wish V right now, 11739V SR27500 Fec 3/4 MGM channel. I am 6 miles North East of Belfast with 90cm Dish. Very clear sky here tonight Signal at 73% I am grabbing Ocko at 81% 10862H SR22000 Fec 5/6. Coordinates 54.618 N / 5.908W(I think) Did a re/scan picked up 3 new tv channels . INT VID1, 2 and 3 on FReq 12032H /27500/3/4 | ||
| astra, dish, map, reception, size |
