Astra 3A, UK Reception and Dish Size MapIf you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here. | |
| | #51 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | For Rolf's map. Both Tp's this morning are running fine at 58 per cent quality on technomate Rx. (tech: 68dBuV, bBER : 5-E4, MER 10) | ||
| | #52 | ||
| Member Join Date: 25-05-2008 Location: BIRMINGHAM
My System: Vantage 7100 TS dishes eurostar 85cm lnb 0.2 Astra 19.2 | | ||
| | #54 | ||
| Regular Member Join Date: 21-10-2003 Location: Kent UK and Cyprus
My System: TM 6900 Combo Motorised 80cm + dual lnb in UK TM 1500 Motorised 80cm in Cyprus Pinnacle Showcenter 200 MR Reloaded Diablo 2.3 Hotbird 13E Astra 1M widebeam Astra 1H 1W T2 Beam 7E,5E,10E,16E,26E,33E,42E 4W,7W,8W,12.5W,15W All Ok with 80 | Very strong signal for 3A Czech and Slovak tpx in SE Kent with 80cm and 0.2 lnb | ||
| The Following User Says Thank You to Uk2cyp For This Useful Post: | cyborg_chippy (26-09-2009) |
| | #55 | ||
| Regular Member Join Date: 04-09-2004 Location: Hounslow
My System: , Fibo Gregorian 1.2mtr, Skystar 2 | | ||
| | #56 | ||
Much more accurate map for Astra 3A with recommended dish size rather than the 47dBW quoted as 65cm -85cm required for UK | ||
| | #57 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Jast had a play with the Fibo 90cm on a ground mount, found the CSLink channels with a reasonable degree of stability. Just about managed to pull in the Skylink channels on 12565 H (see picture below of TA3), but skew is ultra critical, as the signal strength was only 60db and there is a Vertical transponder on the same frequency so the signal to noise ratio is very low, it was quite cloudy, but I would imagine that I would lose it with light rainfall. Not sure whether the Channel Master 1.2 will give much improvement on the Skylink channels,as I didn't have a 3" stand on which to mount it, will have to try another day and I've run out of free time for the next few days. | ||
| | #58 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Good going Rolf ![]() I'd be quite keen on knowing the results with the CM when you get round to trying. Result about the same I had with a standard 90cm yesterday. SM | ||
| | #59 | ||
| Member Join Date: 19-03-2009 Location: Cheshire
My System: skylink |
I live in North West and have 1m dish and 0% of Slovak channels on 12565H. On other frequencies 80%. Do you I need a bigger dish or move a dish? | ||
| | #60 | ||
| Manic Midlander Moderator Join Date: 24-09-2006 Location: West Midlands. UK
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription | Managed to pull in some of the Kabel Deutschland stuff on 11474v this evening in the Midlands on a Fracarro Penta 85 ![]() Not too bad considering the size of the dish and how far out of the official footprint we are here in Sunny Wolverhampton ![]() ![]() Nano | ||
Sanity is nothing more than an excuse to be boring <<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>> <<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>> <<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>> | |||
| astra, dish, map, reception, size |
