Dish size info for Nilesat 7W in western Europe & the UK
If you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here.
Old 18-11-2007   #51
Manic Midlander Moderator
nanochickin's Avatar
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription
I've managed to get a few of the Vertical transponders in the Midlands on my 90cm dish.
Mostly stuff like Bahrain TV on 11823 V and Nojoom 1 on 11785 V
Nano
Sanity is nothing more than an excuse to be boring
<<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>>
<<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>>
<<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>>
nanochickin is offline   Reply With Quote
Old 18-11-2007   #52
My System: DB7000S HDD USB2GB; 2CM120+Norsat4106Afor HH&7707AforVH on 7°W; Triax 2X110, 1X88 and 1X64. LNBFs: 2BESTQ, 2InvacomQ; 3XAlps, 2Inverto(1Q), 3XBEST; Switches and M/S; Centauri P-168. 30w, 8w, 5w , 1w, 5e, 9e, 16e, 23e, 28e; 13E, 19E; 26E
Actually, Turok, it is Atlanticbird2 on 8°W.
Yes we receive this strongly as you say, in Belgium, because it is a central european satellite. I tried and receive it with a 50 cm dish.
Keano! In another thread you said that you receive nilesat 12399H and that it is one of your best transponders.
This makes me very hopeful about receiving all transponders on the Nilesat wide beam with a CM 180 with feedhorn.
canofan is offline   Reply With Quote
Old 19-11-2007   #53
keano's Avatar
My System: 2.4mtr Channel Master Dish, Fracarro Penta 85cm Dish, 64cm Traix Dish with 4 multi LNB'S Sky HD, Dreambox 800, Dreambox 500, IPBOX 250, Sky HD and a mad wife !
m8 12399H is very strange, if you move the dish between 7.0w and 8.0w it gets stonger.
Example if I have my dish spot on 7.0w, 12399H will be about 22% on technomate then give dish a slight nudge to the west and it will jump up to some where about 30% but in doing so I lose 11996H.
Before anyone says its not 12399H on 8.0w.
Its Al Maser TV etc.
It could be that slight nudge is the difference between middle east beam and wide beam.
keano is offline   Reply With Quote
Old 19-11-2007   #54
My System: , Fibo Gregorian 1.2mtr, Skystar 2
I have also the seen the same behaviour... to get most of the horizontal channels, I have to move my dish to the left towards 5.0W
olisun is offline   Reply With Quote
Old 20-11-2007   #55
Wow!
Strange yes. But are we not starting from the wrong premises?
12399H in the Nilesat set of satellites: NS101, NS102, AB4.
It is on AB4.
Since in physics, zero is a monster that should never be mentioned.
Those satellites are not exactly in the same point in the sky; they simply could not..
This why a little "nudge", as you say, would bring AB2 in the focus of your dish.
But what amazes me is that somebody else may have to "nudge it" in the opposite direction.
Old 20-11-2007   #56
keano's Avatar
Totally agree m8, thats what makes this hobby so interesting.
What is a little nudge on the ground works out to be a few miles difference out in space.
Yes even though the sats are at 7.0w they are spaced out and would not make a difference to people under the footprint but those of us that are not then it makes a big difference.
Old 22-11-2007   #57
I am so pleased you like this site.
AB4 is on 7.2W. By nudging it you recuperate 1/5°. And that is a few miles as you said, Keano.
Old 23-11-2007   #58
keano's Avatar
No probs m8, we're here to help each other
Old 04-12-2007   #59
My System: Technomate 1600ci, Art Sport, Digit Alb, Channel MASTER 1.2
Hi Keano - Are you still picking up the horizontal beams on your 2.4 channel master mate.
jackson50 is offline   Reply With Quote
Old 06-12-2007   #60
keano's Avatar
yep all H beams good here apart from 11804H which is very very weak, I do see it at about 22.00-06.00.
Old 03-01-2008   #61
vma
vma's Avatar
I get Nilsat with my 100cm rotating dish in Northern Portugal.
See this link for spectrum images: _http://www.geocities.com/dazed1970/spectrum/index.htm
Cheers,
vma
vma is offline   Reply With Quote
Old 16-01-2008   #62
My System: 1.3M eurostar DISH,MOTOR 42e-18w,65CM FOR SKY, TMS 1500 , ECHOLINK 777, SHARP LNB,TM6800 HD+WF165 CABLE
7 West / Nilesat
I got my first lock and picture on H transponders this morning using a 1M orbital and Technomate Tms1500 / SHARP Lnb. Location West London.
FORKS is offline   Reply With Quote
Old 27-01-2008   #63
kimbo's Avatar
My System: Technomate 1500, 90cm Dish, Mesh Computer ART, Digit Alb, Fortec 2.4m Dish Channel Master 2.4m, Showtime.
Okay on a 2.4m Channel master in the Midlands.
kimbo is offline   Reply With Quote
Old 27-01-2008   #64
T_G
The Consumate Dreamer
T_G's Avatar
Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything.
Muhuhuhahahahahaaaaarrrgggh
Update: With my 1.2 dish in western Germany I get a lot of verticals, but also a whole bunch of stations in horizontal, but only on one transponder : 117660. I also get a very weak signal on horizontal transponder 123030, but too week to really watch it as it breaks down all the ime.
T_G
I only believe stuff that comes straight from Mr. Horses mouth!
T_G is offline   Reply With Quote
Old 28-01-2008   #65
Robbo's Avatar
Real name: Mark
In Kent I get:-
11747V-pixelated
11785V-pixelated
11823V- all channels good
11862V-all channels good ($ ones can't see but % high enough to)
11938V-all channels good
12015V-all channels good
12054V-just the odd flicker of picture occasionally
12130V-all channels good
12207V-very pixelated-unwatchable
No Horizontal transponders at all.
1m Orbital Dish, motorised,Inverto Silvertech 0.2dB twin.
Old 28-01-2008   #66
At the moment in Belgium, when the weather is not too thick, with my CM120 +invacom QTH-31, I get all vertical and horizontal channels on Nilesat 1 and 2, those positioned exactly at 7°W. When it becomes thicker, some of the horizontals start to flicker. I get absolutely nothing from AB4 at 7.2°W, even in brilliant weather.
Old 04-02-2008   #67
Robbo's Avatar
Real name: Mark
Originally Posted by Robbo71 View Post
In Kent I get:-
11747V-pixelated
11785V-pixelated
Now got a 110cm Triax and getting:-
11747V-all good
11786V-all good
11823V-all good
11862V-all good
11900V-all good
11938V-all good
11977V-all good
12015V-all good
12054V-all good
12130V-all good
12207V-all good
12284V-all good
11919H- Got a lock, but just on the limit of receiver sensitivity so no channels.
So a Triax 110cm, definite improvement over a 1m Orbital.
Old 04-02-2008   #68
Amo Amas Amant Admin
Topper's Avatar
Lol
You see yet another fine example where size matters
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 05-04-2008   #69
My System: Dreambox
in Brussels, Belgium:
Dish: 240cm PFA Aerial Oy from Finland
LNB: Inverto Quattro
Receiver: Dreamboxes
Results:
I get excellent reception on vertical and horizontal transponders for both Nilesat and for AB4.
charly20 is offline   Reply With Quote
Old 05-04-2008   #70
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband!
Hello Charly,nice,.to see you also on this board
welcome!
my invacom quad flagne is gone,over the wintertime,when i was not here,now i replace it with the new mti 0.3 db!
dont find any contact adreses in google,of invacom germany,to send back for replacement?any ideas?
Turok is offline   Reply With Quote
Old 05-04-2008   #71
My System: TM 6900 Combo Motorised 80cm + dual lnb in UK TM 1500 Motorised 80cm in Cyprus Pinnacle Showcenter 200 MR Reloaded Diablo 2.3 Hotbird 13E Astra 1M widebeam Astra 1H 1W T2 Beam 7E,5E,10E,16E,26E,33E,42E 4W,7W,8W,12.5W,15W All Ok with 80
Hi
I receive 11862V and 12015V most of the time.
Other verticals come in after dark
Its very critical on a 80cm.I need a bigger dish for this sat
Excellent signal in cyprus on all tpx
Regards
Uk2cyp is offline   Reply With Quote
Old 05-04-2008   #72
My System: Dreambox
Hi Hans,
no idea for contact info of Invacom in Germany. Why don't you contact them directly in the UK?
Old 07-04-2008   #73
"7 West / Nilesat
I got my first lock and picture on H transponders this morning using a 1M orbital and Technomate Tms1500 / SHARP Lnb. Location West London."
UPDATE
Just purchased a Triax 110cm.
24hrs on all V transponders
19000 v and 12054V fade when it rains during 2-5pm.
Most H transponders lock in fine weather and light cloud.
11919 H being the strongest.
The signal improves at 8.30pm.
No H transponders when it rains or even light drizzle.
Location - West london 51.3N
mike
Old 14-06-2008   #74
Design Engineer/Installer
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions...
7w Nilesat Mid UK (Cheshire)
1.1 Triax + Sharp .3 & ...1m CM c120 MTI .6 ch feedhorn through Technomate TMS1000 30m cable run close trees at 7w not tweaked for 7w
We get all the verts and breaching on 11919h
11862v City 7___________56%
11823v Bahrain__________56%
11785v Bubai One________52%
11972v MTV Arabia_______50%
12015v Smile TV_________47%
11940v MBC2____________44%
12130v Al Jadeed________42%
12054v OTV_____________39%
11900v Kuwait ch2 _______38% low
12195v PSC_____________38% low
12284v JSC Sports_______38% low
12207v BBC Arabic_______37% low
10719v Hanibal__________35% low break up
11919h ALKAWTHAR______33% breaching
Have too many channels to list
pedro2000uk is offline   Reply With Quote
Old 14-06-2008   #75
Robbo's Avatar
Real name: Mark
I managed to get a few of the H transponders including Showtime the other week on my Triax 110 in Kent, the exception rather that the rule.
Still got excited for a moment though.
dish, europe, info, nilesat, size, western
[IMG] code is Off
