What size dish do i need for nilesat 7'W for footballIf you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here. | |
| Guest
Posts: n/a
First off i would like to say all Showtime transponders are horizontal apart from one which is vertical, And with nilesat the more north in the uk you go the weaker the signal is I am in South Wales and this is what i use Nilesat all transponders vertical (e.g mbc 2&4) and horizontal (e.g SportsNet World on 11.996 H) 24/7 and in the rain on 1.8m prime focus fortec star dish with adjustable inverto feedhorn and inverto whitetech 0.3 c120 lnb and webro wf125 coax cable, Nilesat all vertical transponders 24/7 (e.g mbc 2 & 4) and in rain but no horizontal transponders at all on 1.2m Andrews with ku-band feedhorn and invercom 0.3 c120 lnb and webro wf125 coax cable, | ||
| Member Join Date: 04-09-2006 Location: London
My System: looking for help and trying to help others | thanks mate that was very helpful i have a showtime Subscription in Morocco its still running the family there enjoying it but its hard to get showtime signal in UK London and 1.8 dish seems almost impossible to install ![]() | ||
| Specialist Contributor Join Date: 11-12-2004 Location: yorkshire
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro | im struggling with a 1.2channel master with quad invacom during the day but tea time the channels start to come in a little never had perfect 24/7 pic here in south yorkshire hope this helps someone | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Is that both Vertical and Horizontal iwol? | ||
| | #5 | ||
| Super Moderator Join Date: 01-06-2004 Location: Here again
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Hope not R, or I'll have to be getting the spanners out ASAP. ![]() L. | ||
| | #6 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | That's what I thought and it is of course critical. | ||
| | #8 | ||
| Guest
Posts: n/a
| London also needs a 1.8m dish but a 2.4m is recommended to allow for rain fade by a dealer i know in the london area, But if any one else in london is getting any good results let us know Also for nilesat the more north you go in the uk the weaker the footprint | ||
| | #9 | |||
My System: looking for help and trying to help others | i hope it was as easy as Morocco i would put 5 m not just 2.4 | |||
| | #10 | ||
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro | would a 1,8 do in yorkshire instead of my 1.2 channel master and whats the 1.8 dish like that maplin do cheers | ||
| | #11 | ||
| Guest
Posts: n/a
| | #12 | ||
| Guest
Posts: n/a
| I have a dealer friend in london he tells me you can get it with a 1.8m but to allow for rain fade a bit bigger would be safe, Myself i do not live in london so i am only telling you what i have been told by him | ||
| | #15 | ||
| Member Join Date: 15-11-2006 Location: london
My System: 1.8 meter dish with c120 lnb toward nilesat | i got 1.8 m fortecstar dish and inverto c120 lnb wih matching feedhorn i tried alot to get horizontal transponder but i cant.i can only get all v transponder with 69 or 70 percent signal i dont know what is he problem.anyone can help me with this how i get all the h transponder with same setup. | ||
| | #16 | ||
The problem is not necessarily your equipment although it may not be set up properly however the real problem is London is not in the Middle East or North Africa which is where the beam is primarily aimed at so two choices, get an even bigger dish (not much hope) or move see here | ||
| | #17 | |||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ |
| | #18 | ||
That is irrelevant wod when you are outside the footprint you sometimes get 'hotspots' and either receive it or not, the truth is the footprint is aimed at the middle east and north Africa. It is exactly the same for people in Spain trying to receive sky some can quite easily other have to work harder to get it and some just cannot. | ||
| | #19 | ||
| Guest
Posts: n/a
| Check this thead out about the 1.8m fortec star on nilesat that i am useing Fortec star 1.8m dish Ain't that bad after all / c-band The key to makeing the dish work well is putting it together and useing a adjustable ku-band prime focus feedhorn, If you are not use to putting these type of dish together you will struggle I put mine together with some help from my misses as it is helpfull to have another set of hands to pass you tools etc, | ||
| | #20 | |||
| Guest
Posts: n/a
| It is the same type of thing but the other way around as you say. i know with nilesat aswell from friend in cornwall who has the same 1.2 andrew channel master as me that where he is he gets a bit higher signal than me i know this as i was at this house last week, It is all trial and error at the end of the day,
| | #21 | |||
| Member Join Date: 01-02-2006 Location: East Sussex. UK
My System: Sky Multi-Digital FTA. Quad lnb, 60cm dish. Skystar 2 pvr TV, 1.2m dish, Lnbs x 2 Manual.Technomate 7755 AMD 3000+ 2G CPU, 128 Graphics card, 1024 ram, 150 HD. P4 2.93G CPU, 128 Graphics card, 1024 ram, 229 HD, |
The Fortec Star 1.8m does look a good buy & by the time I got around to Maplins, they had sold out. Should be back in stock soon hopefully. I have just two questions; 1. could I have the model No. of your adjustable feedhorn please. 2. what make of dish is this item 170051409186 on Ebay Thanks again Hugh | |||
| | #22 | ||
| Emperor born of a peasant Join Date: 31-05-2006 Location: Tenerife
My System: Technomate 1500CI+ | Has anybody in northern England successfuly got the horizontal transponders? I'm considering buying the 2.4m Fortec Star from Maplins. | ||
| | #23 | ||
| Member Join Date: 21-08-2007 Location: South Wales, United Kingdom
My System: Hotbird Broadband 2mb | Is the maplin 2.4 dish guaranteed to getting Nilesat, because I live in south Wales and a few people said they bought the maplin 2.4 and chucked it in the bin isit it guaranteed at least for 2 / 3 years | ||
| | #24 | ||
I was looking at the 2.4 metre satellite on the maplin website and asked for some advice from people and whether it would guarantee recieving Nilesat (V+H), a few people said that they bought it and chucked it in the bin, due to the bad quality of the satellite, So I was wondering is the 2.4 m Prime Focus satellie dish guaranteed to getting Nilesat, and would it survive for 2/3 years through tough weathers Thank you | ||
| | #25 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | No-one can answer the first question as it all depends how well its put together. Be warned, from reports on this forum, the dishes are somewhat flimsy.... | ||
| dish, football, nilesat, size |
