Echolink Firmware's
Old 16-10-2007   #1
Section Leader
echoman's Avatar
My System: Kaon 230, Echostar D-2500-ip - cam matrix reborn, Max S100/S200 FTE, DSR 3000 e extremebox! 2 Panelas 1.80 motorizadas foco primário, 1.20 e 0.80 offset.
Arrow Echolink Firmware's
Echolink FTA series and clones
Este firmware rola nestes dekos:
AGI AG-R5200D
FTE S 100
Echolink EL 700 FTA
Echolink EL 700 FTA Plus
Echolink EL 777 FTA
Starsat SR X4000D
Starsat SR X4200
Starsat SR X5100
Starsat SR X5200
Univers U4111
Univers U4112
Univers U4113
Univers U4114
Xtream -2
Qualquer um souber que há mais clones, apenas adiciona a lista;
Cumps.
Firms Agrupados
-> Mais Recente
Echolink AU Firmware1.3.7. sw Keys Fix NEW Next Premiere Keys 1nd 14.12.2007
w*w.sendspace.com/file/5yt95a
-> Anteriores
Echolink Firmware 1.3.7. sw_v11[1].3.7_14.10.07_d+.premiere.polsat
w*w.sendspace.com/file/hdjk00
Echolink Firmware1.3.7. sw D+ Fix Seca Keys Fix Polsat Fix BEV Fix Dish Fix 09.11.2007
w*w.sendspace.com/file/butfcp
Echolink Firmware1.3.7. sw D+ New Key 01 Fix SexView for Test Fix 10.11.2007
w*w.sendspace.com/file/q18vc2
Echolink Firmware1.3.7. sw D+ Fix D+ AU PW AU Polsat AU TPS AU DigiTV AU 131107
w*w.sendspace.com/file/pei29h
Echolink Firmware1.3.7. sw D+ AU D+ 01 Fix Dish 00 Fix BEV 00 Fix Premiere all OK 14.11.2007
w*w.sendspace.com/file/oe42zx
Echolink Firmware1.3.7. sw D+ OK Euskatel Fix Dish Fix BEV Fix 16.11.2007
w*w.sendspace.com/file/j79gus
Echolink Firmware1.3.7. sw D+ Next New Key 01 Fix Polsat New Key 01 Fix Euskatel Fix DreamTV Fix 16.11.2007
w*w.sendspace.com/file/n14cv1
Echolink Firmware1.3.7. sw Dish Fix D+ Next Key 00 Fix 17.11.2007
w*w.sendspace.com/file/ei15mt
Echolink Firmware1.3.7. sw Dish 00 Fix Polsat 00 Fix AU OK 18.11.07
w*w.sendspace.com/file/w2mz5q
ECHOLINK AND CLONES ALL UPDATED 20 NOV 2007
w*w.sendspace.com/file/83vhaz
Echolink Firmware1.3.7. sw Nagra 2 AU OK D+ Next Key 00 Fix 21.11.2007
w*w.sendspace.com/file/xkirjr
Echolink AU Firmware 1.3.7. sw Keys D+ New Key 00 Fix Premiere New Key 00 Fix 29.11.07
w*w.sendspace.com/file/yiuhpa
Echolink AU Firmware 1.3.7. sw Keys Fix D+ New Key 01 Fix 30.11.07
w*w.sendspace.com/file/a0eggk
Echolink AU Firmware1.3.7. sw Keys Fix D+ Key 01 Fix Premiere Key 01 Fix Cyfra+ Fix 01.12.2007
w*w.sendspace.com/file/5r66tp
Echolink AU Firmware 1.3.7. sw Keys Fix Digital+ Keys 3nd DigiTv Key 00 Fix 02.12.2007
w*w.sendspace.com/file/y5yc7e
Echolink AU Firmware1.3.7. sw Keys Fix Mediatech Fix nDreamTV Fix CC Fix 04.12.07
w*w.sendspace.com/file/ci0f6v
Echolink AU Firmware1.3.7. sw Keys Fix Polsat New Key 00 Fix 07.12.07
w*w.sendspace.com/file/pydr7m
Echolink AU Firmware1.3.7. sw Keys Fix Premiere New Key 01 Fix Polsat New Key 00 Fix 08.12.2007
w*w.sendspace.com/file/qkzf5m
Echolink AU Firmware 1.3.7. sw Keys Fix Digital+ Keys 3nd DigiTv Key 00 Fix 12.12.2007
w*w.sendspace.com/file/9h80oa
O material exposto neste Site serve para estudo do sitema satélite,o uso desta informação é da responsabilidade do utilizador e serve sómente para teste.
echoman is offline   Reply With Quote
Old 11-11-2007   #2
king of Imagination's Avatar
My System: ECHOLINK EVERY THING
Thinks very much
king of Imagination is offline   Reply With Quote
Old 20-11-2007   #3
perereco's Avatar
My System: galaxis FTA-3 univers U4113 edision 1120cx Win XP SP2 fte ird 120
um ficheiro de texto? desde quando um ficheiro de texto é um firmware? lol
Mais atenção, echoman
perereco is offline   Reply With Quote
Old 21-11-2007   #4
prdesign's Avatar
My System: Satellite
Amigo não entendo muito destes softwares... mas vou fazer uma pergunta que pode parecer ingénua. Trocando a firmware é necessário colocar a lista de canais? é q vou a fazer isso pela primeira vez.. Abraço...
prdesign is offline   Reply With Quote
Old 21-11-2007   #5
vespa150's Avatar
My System: Fte -420 sm -Max S200 -Max S300 -Max S202 sats -Hispasat -Intelsat 10-02 -Hotbird 1 -Astra1C
boas amigo,
ao actualizares o firm a lista continuara igual!!
cumps,
Vespa150
vespa150
Não respondo a dúvidas por PM!!!
Para recém-chegados LER
Importante! Regras da casa:
vespa150 is offline   Reply With Quote
Old 21-11-2007   #6
My System: solve problems
este firm dá para o ird 420sm?
nunofr is offline   Reply With Quote
Old 21-11-2007   #7
Matamoscas's Avatar
My System: FTE 420sm, FTE Max S200, Metronic Ouralis Evolution 3 - Galaxy 28(Brasil) + Hyspasat + Hotbird + Astra
serve para os IRD ou MAX
obrigado
Matamoscas is offline   Reply With Quote
Old 22-11-2007   #8
CarMa's Avatar
My System: FTE 420 SM , e FTE MAX S120
Bom dia
Gostaria que o nosso menbro 'echoman' me dissesse se este firmweres servem para os FTE's ird420sm e também para os FTE's MAX s100, e se são diferentes ou melhorados em relação aos que são fornecidos pela __ fmax.moresat.net_
Desde já um obrigado
CarMa is offline   Reply With Quote
Old 22-11-2007   #9
Section Leader
echoman's Avatar
Muita atencão com os firm dos echolink porque : ha 2 tipos de chip ALI nos echolink e por isso 2 tipos de firm diferentes e logo nao sao compativeis.
Alichip 3329B igual ao max e o 3329C que nao é compativel, pelo menos com os max 100 e 200 se calhar rola nos 300CI ???
Old 22-11-2007   #10
My System: Hispasat Windons XP
Será que funca nos IRD (420 SM) ?
marquinhos is offline   Reply With Quote
Old 23-11-2007   #11
Boas,
Sabes me dizer se este firm funciona num velhinho IRD 420SM ?
Obrigado.
pesantos is offline   Reply With Quote
Old 23-11-2007   #12
renova's Avatar
My System: Satellite Hisp. Nil. Hot. Sl65-IRD420SM-Max S100-AZBOX
amigo o soft. é so para serie max e claro seus clones
Comp.
renova is offline   Reply With Quote
Old 24-11-2007   #13
slcartaxo's Avatar
My System: fte 420 maximal;head 500; e agora s200 fte
amigos pq no meu o canal desport e canal eventos nao da,,,, so o canal futbol
slcartaxo is offline   Reply With Quote
Old 24-11-2007   #14
vespa150's Avatar
amigo mudanças para (N3)
cumps,
Vespa150
vespa150
Old 24-11-2007   #15
slcartaxo's Avatar
)) estes tb ja estao a mudar,, tb tenho que mudar
Old 27-11-2007   #16
CarMa's Avatar
Boa Noite echoman, não percebi, ou melhor não entendi o que postastes, porque abrindo o ficheiro não encontro lá nada relacionado com o que mencionas: 'Alichip 3329B ' ou Alichip 3329C ???????????????
Gostaria que respondesses claramente ao exposto e em linguagem leiga, á minhas perguntas com um simples Sim ou Não :
...me dissesse se este firmweres servem para os FTE's ird420sm e também para os FTE's MAX s100, e se são diferentes ou melhorados em relação aos que são fornecidos pela __ fmax.moresat.net_
ou então simplesmente a que aparelhos interessa estes firmweres!
Obrigado
Old 27-11-2007   #17
CarMa's Avatar
EStes updates são melhores que os do 'primo' Max ??
Old 03-12-2007   #18
CarMa's Avatar
Boa Tarde.
Caro Echoman, podias fazer o favor de responder á siguinte questão, anteriormente exposta mas não respondida, sem deixar nenhuma dúvida:
- Posso meter este firmwere no FTE Max s120 ?
-Quais os melhoramentos ou diferênças em relação aos desponiveis no site do 'primo' Max ?
Desde já um muito obrigado.
Old 05-12-2007   #19
thanks
veryvery mush
Old 05-12-2007   #20
CarMa's Avatar
Boas tardes
Como o amigo Echoman não responde eu vou postar a minha experiência:
Meti este firm no FTE max S120 e além de demorar (toda a noite +-) 4h para conseguir abrir um canal free (ANDALUZIA) fiquei sem Au nos Polsat ou seja quando fui ver as Keys ele atualizou os 1ºs 16 carateres e os restantes estavam mal em 3 careteres seguintes os outros estavam bem, actualizei á unha abriu mas como o Au estava ligado logo ficou ás escuras novamente.
Os canais ABs que abriram antes deixaram de abrir.
Bem tive que ir ao site do 'primo' e meter o ultimo firm 30-11-2007 e voilá desatou tudo a bombar!
Por tal motivo não aconselho estes updates a quem tenha a série 100 Max, o melhor é ir ao site do 'primo'
Saudações.
Old 07-12-2007   #21
My System: hotbird, astra,
echoman estes firmwares sao compativeis pa univers 4101?
action2278 is offline   Reply With Quote
Old 07-12-2007   #22
Section Leader
echoman's Avatar
Obrigado
Boas!
Desculpa por ter demorado na resposta.... como já disse, este firmware não é compativel para a serie max. Só não testei no max s300 ci.... mas se calhar rola neste deko.
Cumps.
Old 07-12-2007   #23
Section Leader
echoman's Avatar
Boas.
Não, não são compativeis para o univers 4101
Cumps.
Old 08-12-2007   #24
amigo echoman, k firm me aconselhas pa estes apaarelhs ? e k elen grava as chves pa nagra 2 e irdeto...
Old 08-12-2007   #25
e o k me aconselhas pa estes aparelhos?
echolink, firmware
