FTE Max EL-777 Softcam keys update 23-12-07
Old 23-12-2007   #1
Section Leader
echoman's Avatar
My System: Kaon 230, Echostar D-2500-ip - cam matrix reborn, Max S100/S200 FTE, DSR 3000 e extremebox! 2 Panelas 1.80 motorizadas foco primário, 1.20 e 0.80 offset.
FTE Max EL-777 Softcam Globecast Fix Polsat OK PW OK 231207
w*w.sendspace.com/file/5ow7w8
O material exposto neste Site serve para estudo do sitema satélite,o uso desta informação é da responsabilidade do utilizador e serve sómente para teste.
echoman is offline   Reply With Quote
Old 23-12-2007   #2
My System: echolink box
onde posso encontrar o the lates software para o Echolink 777 fta,obrigado
altino is offline   Reply With Quote
Old 23-12-2007   #3
Section Leader
echoman's Avatar
Firmware Echolink EL-3020 DIGITV OK TPS AU PW AU ABSAT AU OK POLSAT AU OK 23.12.2007
w*w.sendspace.com/file/1zgos5
The Following User Says Thank You to echoman For This Useful Post:
khalid4ever (10-06-2009)
Old 23-12-2007   #4
Section Leader
echoman's Avatar
Firmware Echolink EL-888FTA DIGITV OK TPS AU PW AU ABSAT AU OK POLSAT AU OK 23.12.2007
w*w.sendspace.com/file/au1h6o
Old 24-12-2007   #5
Section Leader
echoman's Avatar
Firmware Echolink EL-777 FTA DIGITV OK TPS AU PW AU ABSAT AU OK POLSAT AU OK 23.12.2007
w*w.sendspace.com/file/42pdda
ROUSSI (30-10-2008)
Old 24-12-2007   #6
Section Leader
echoman's Avatar
Firmware Echolink EL-700 FTA Plus DIGITV OK TPS AU PW AU ABSAT AU OK POLSAT AU OK 23.12.2007
w*w.sendspace.com/file/d8tgvv
Old 24-12-2007   #7
Section Leader
echoman's Avatar
Firmware Echolink EL-700 FTA DIGITV OK TPS AU PW AU ABSAT AU OK POLSAT AU OK 23.12.2007
w*w.sendspace.com/file/eg36wy
Old 29-05-2009   #8
Real name: muzia
My System: expressam22
WHERE CAN I GET echolink EL-888 FTA+ update
muzia is offline   Reply With Quote
The Following User Says Thank You to muzia For This Useful Post:
el777, fte, keys, max, softcam, update
