receiver with 4.2.2?????For all (Non Sky) HD receiving equipment discussion and where to find the transmissions | |
| Specialist Contributor Join Date: 11-12-2004 Location: yorkshire
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro |
does anyone know of any receivers supporting the 4.2.2 feed format except the qualitv ,,or any due out especially supporting hd as well trhanks | ||
| | #2 | |||
| Regular Member Join Date: 04-02-2004 Location: London [South East]
My System: CPU Intel® Pentium® 4 640 Prescott (3.20 Ghz) Memory 1024 MB DDR RAM - (2x 512 MB - PC3200) Motherboard ECS 915P-M3 Hard Drive 300GB Maxtor DiamondMax SATA 6B300S0 Skystar 2 usb 1.1mtr steerable dish Manhattan XT[CM, Quali 1080ir | | |||
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro | thanks i sold the quali tv receiver for about £100 thats how bad it was surely someone should be thinking about adding it to a new receiver ,they have added afree view module to the tm6900 why not get rid of this | ||
| | #4 | |||
My System: CPU Intel® Pentium® 4 640 Prescott (3.20 Ghz) Memory 1024 MB DDR RAM - (2x 512 MB - PC3200) Motherboard ECS 915P-M3 Hard Drive 300GB Maxtor DiamondMax SATA 6B300S0 Skystar 2 usb 1.1mtr steerable dish Manhattan XT[CM, Quali 1080ir | Oh well too late now. | |||
| | #5 | |||
| Member Join Date: 18-12-2005 Location: UK..Sussex
My System: SKY+ |
Will this card (with the appropriate software) fully decode & receive all 4.2.2 feeds on my PC? Is this easier to setup than a Quali-tv for a relative amateur in this field? | |||
| | #6 | ||
| Member Join Date: 05-09-2008 Location: China
My System: 138E,146E TBS DVB-S2 8920 card TBS Q-Box Ⅱ XP/Vista/Linux Ubuntu | it depends on the software decoder(tv tuner) or hardware decoder(STB).If you're using any kind of dvb-s tv card or tv box. It only concerns your software decoder. As far as i know VLC decoder can do 4:2:2, you can use DVBDream with VLC decoder. Any DVB-S tv tuner could be fine.What i would recommend is TBS DVB-S card 8920 VLC decoder and DVBDream are free downloadable. If you want to watch 4:2:2 on your TV, you can use some device called PCmebox to extend your computer HD video,audio and USB control(wireless keyboard or mouse)to TV. | ||
| | #7 | ||
| Regular Member Join Date: 08-02-2005 Location: Lot, Dordogne, Correze border.
My System: FTE Max, Skystar2.3 and Skystar2.6, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky. | If you can get the signal onto the the PC bus (for example with the Skystar) then just install elecard or Nero8 (my preferred) codec and watch using DVBDream - that way you don't have to create video graphs - because DVBDream does it for you. | ||
| | #8 | ||
| Specialist Contributor Join Date: 29-02-2004 Location: Tyne and Wear
My System: 85cm transparent dish 0.2db lnb titanium wf100 cable dreambox500s technomate 9100 linux Eaglebox UK nds card | Im sure you can use a dreambox in conjunction with various software on your PC | ||
| Nice but Dim | |||
| receiver |
