T.V with built in digital making weird noiseFor all (Non Sky) HD receiving equipment discussion and where to find the transmissions | |
| Member Join Date: 07-05-2008 Location: UK
My System: T.V with built in freeview | Hi, I bought Dual DLCD1905 TV with built in digital/freeview the other day. I've set it all up and decided to watch some telly tonight in bed. The thing is... when I'm watching the freeview channels there is a noise coming from the telly, it's a slightly high pitched sort of noise. Sounds a bit like crickets chirping in the night lol (if I mute the telly the noise is still there). I only get this noise when I am watching the digital stations. If I switch the telly over to the analogue stations I don't get this noise. What could it be? Complete newbie to this sort of stuff :P Thanks | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Whatever it is, probably one of the components on the digital side of the receiver, you probably need to take the set back to get it sorted/swapped. | ||
My System: T.V with built in freeview | Well I took it back today, exchanged it for the exact same model, and guess what... this one is doing it too. So it's either these brand of T.V's or it's my booster causing it? | ||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
| Could it be interference from another electrical appliance in the bedroom like a mobile phone, a radio alarm, fluorescent light, PC, Laptop, etc.? Just write down all the appliances that are in the room and investigate them one by one. Have you tried taking it to another location in the house and see if it still give this noise? Few months ago I had in my office a strange noise coming from my radio and it nearly drove me crazy and I had to switch my radio off for hours. There was nothing in my office room that was causing it, and finally I found that the source was coming from an old PL light bulb that was in the corridor. Took it out and the noise was gone. | ||
| | #5 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Sounds like the noise you get with borderline reception of the digital signal, although it's usually accompanied by some pixellation on screen. Does your picture breaking up at all during the effect? Llew | ||
| | #6 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Also take out the aerial cable from the rear of the TV. Connect a DVD player to it via a scart connection and see if the noise is still present. This will tell you if it's DVB signal related, although I reckons it's a fault with the TV | ||
| | #7 | |||||
Currently I have a PC next to the T.V but it isn't even plugged in. (I will also use the T.V as a PC monitor). The only other thing I have near it is my Xbox 360. Mobile phone isn't near it etc etc. When I first tried the T.V out I did it in the living room, and I do recall that noise being there then. I remember actually thinking it was coming from the actual programme on the telly. I actually thought it was crickets chirping in the programme lol. On some channels it's worse (freeview). And on some freeview channels it's barely even there... normally on the ones I don't ever watch lol. I will be taking this T.V back. I will probably go to an electrical store this time to get another T.V If the new completely different brand T.V makes the same noise, then obviously it must be to do with my aerial/booster/something causing an interference. Thanks | |||||
| | #9 | ||
My System: T.V with built in freeview | | ||
| | #10 | ||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | I wonder whether it could be digital hash generated by the built-in computer. This might be leaking into the audio lines if the sections are badly designed for isolation. | ||
| | #11 | ||
My Sony satellite STB makes that noise when it needs a forced update or just initialising .........chirp | ||
| | #12 | ||
My System: T.V with built in freeview | Hey everyone, Well today I went to Bennetts and bought a completely different telly. I got a Humax LGB19DTT. Guess what? PERFECT! Set it all up, did the freeview channel search found all my channels and no crickets chirping! ![]() So it can't have been anything interfering like my booster, wire etc etc. It must just be that brand of telly, or a faulty batch maybe! Anyway, glad it's sorted | ||
| built, digital, making, noise, weird |
