1080p? | |
| Member Join Date: 17-07-2008 Location: United Kingdom
My System: None as yet |
Hi I have just bought a Panasonic Plasma tv capable of displaying HD transmissions upto 1080p but the 3 HD satellite receivers I've looked into - Technomate 9600, Kathrein and Sky HD only work at 1080i or 780p. Forgive my ignorance but is HD TV only transmitted at these resolutions or can you buy boxes capable of 1080p? Also - please would someone explain the benefits of Linux based boxes and is the Technomate 9600 Linux based? Many thanks in advance. | ||
| easkey Join Date: 21-12-2005 Location: IRELAND
My System: Technomate 1500+CI on 1M dish with moonblock lnb Astra 19 - Hotbird and Sky Box on 90cm dish Diablo Cam + Cas 3 | Broadcasts in 1080i utilize a higher resolution of 1920 x 1080. The “i” stands for interlaced. Interlaced images are painted in a two-pass process. The first pass paints every other line, the second pass paints the skipped lines. The “p” stands for progressive scan. Images are painted in a one-pass process. There are no broadcasts in 1080p, (1920 x 1080 in progressive scan mode), and none expected anytime soon. However, there are digital formats that can produce a true 1080p signal: Blu-ray and HD DVD players. Only a 1080p HDTV can display Blu-ray and HD DVD in their native, full resolution formats. Among 1080p HDTVs there are also various models with different support modes. The newer models support 1080p/60, 1080p/30 and 1080p/24, with the latter number being frames per second. The 1080p is also preferable for gaming and PC use. Linux is an open software.... So the box can be patched ![]() | ||
| The Following 2 Users Say Thank You to easkey For This Useful Post: | chewyjoint (21-07-2008), hoppo1 (19-07-2008) |
| Regular Member Join Date: 01-07-2006 Location: Alzira (Valencia)
My System: Technomate 1500CI Super, Vantage X221TS CI with Sly FTV card, Illusion motor, 1.2M Tecatel dish with invacom LNB | The TM is not Linux. Linux allows you to do much more with your receiver. Look up card sharing and you will see what i mean ![]() The payoff is that they take more time and patience to set up. Do plenty of reading about them before you buy one. All that being said, I would not buy anything but a HD Linux box if I were to change my receiver but i have been dealing with the sat field for over 4 years now (& still get lost with some of the new boxes) ![]() hoppo1 | ||
| The Following User Says Thank You to hoppo1 For This Useful Post: | chewyjoint (21-07-2008) |
My System: None as yet | Thanks. I've done a fair amount of reading of this and another forum and am considering the Dreambox 8000 in a couple of months time once it's readily available and hopefully a bit cheaper, along with a motorised dish. Does that sound like a sensible choice? | ||
| | #5 | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
I doubt you will get many answers on this because as yet as we do not have any idea what your reasons are for choosing this stb, what are your criteria?. We have no reports from anyone that has managed to buy one to say whether or not is is a good stb. Certainly it would seem to be pricey and it really depends on whether or not you are prepared to wait an unspecified length of time for it and whether or not you are prepared to be a guinea pig, as you may well end up doing a lot of beta testing and fault finding before it is working properly. I am not trying to say it will be a bad stb just I would personally be reluctant to shell out good money when people are having this type of software problem with the DM800 http://www.satellites.co.uk/satellit...rd-reader.html If that is what you fancy then go for it!
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
