Octagon Hd or Clark Tech Hd the better Choice? | |
| Member Join Date: 23-10-2007 Location: Austria
My System: 4,5 m Andrew -Multifeed C/Ku Band |
Hello Guys, can someone tell me - which Reciever for poor Signals is to prefer? Any Hints? Regards Montafon Guy! | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
Firstly you have to remeber HD stb's have not been for sale for that long and the odds of a hobbyist having enough money to buy and compare two HD stb's are minimal, you may have to wait sometime for an answer from an installer also in a fringe reception area. I think the odds just dropped again
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| Regular Member Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | Hello Johan! the ocatagon is much cheaper then the clark tech,i dont have tested yet this modells,but on the ocatagon i can say,that it posible to select the tuner sensitvity by remote controll,i read on the net,what that exactly means i canot tell you at the moment! when you need a sensitive hd tuner,with hd,buy the ferguson Hd! ++/www.terem.de/Ferguson-HF-8800-HDTV/ it is the same then the homecast hd 5101 ci but with build in multicrypt cam! menu handling is not the best of all,but the tuner senstivy is very good! also where you can take a eye is the new edison argus HD! | ||
| Member Join Date: 27-06-2008 Location: Germany
My System: Fib0st0p 60, 90, 120 & Motors, Triax Unique MF, DVB-S2 cards | I think the Octagon HD is not "much cheaper" than the CT 5000. Both have a sensitive tuner and it really depends on what you want to receive, where & with what equipment. | ||
| | #5 | ||
My System: 4,5 m Andrew -Multifeed C/Ku Band | Thank you guys, i found in another Forum the answer i needed! For all: The Octagon is the more sensitive One than the Clark Tech! Regards Montafon Guy! @Turok: who is Johan? | ||
