Help meFor all (Non Sky) HD receiving equipment discussion and where to find the transmissions | |
| Member Join Date: 18-06-2009 Location: india
My System: measat 91.5e windows xp | hello sir, i saw many HD reciever configuration with two LNB input.Now i'm using to two sat receivers,one for Ku band another for C Band,in this Ku band receiver also used to control the h-h motor.i'm interest to use single receiver can done this things.any chance to do this.please guide me .i'm waiting for ur reply Thank you | ||
| Super Moderator Join Date: 10-12-2004
![]() | There are several new Linux HD receivers that might be suitable, including the AZ Box HD and the Q Box HD. I think that one of the AZ HD Boxes can run 3 tuners, but check out the technical details first. | ||
| The Following User Says Thank You to Mickha For This Useful Post: | birav (24-06-2009) |
![]() | Forget the Dreambox 8000 if you want cost effective, the AZ Box Elite is about £260, the AZ Box premium is about £330, both HD, I don't know the price of a QBox HD, but I'm sure you'll find out on Google. Technomates are probably cheaper. Remember the prices do go up if you add components, like a second tuner, DVD writer etc.. check out the technical specifications, when checking the price, to see what's included. | ||
| The Following User Says Thank You to Mickha For This Useful Post: | birav (01-07-2009) |
