are the any hd satellite receivers without HDCP copy protection,on the market?For all (Non Sky) HD receiving equipment discussion and where to find the transmissions | |
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! |
Hello! iam looking for hd stbs,where i can disable,the hdcp copyprotection? dont find,much info about it,i only know,at the moment,shortly,after the realase of the humax pdr 1000,in its first firmeware 1.0.there was a litte software "Bug,where HDCP,was disabled! are the any other hd receivers,on the market,where i can disable hdcp protection,with alternative software,or over a secret menu code? thanks,for your input! | ||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | Changhong ones, but don't know their accessibility outside of china. | ||
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hello! thanks for your reply! maybe the dont support dvb s2,like in usa,then in europe,i cannot use them! | ||
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | They do support DVB-S2, I have their flyer somewhere I think, will try to find and scan, if you want. | ||
| | #5 | ||
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | okay,sounds great,when the have a homepage i can look there,you have a price of this receiver? | ||
| copy, hdcp, market, protection, receivers, satellite |
