ClarkeTech 5000C Flash Dump needed
For all (Non Sky) HD receiving equipment discussion and where to find the transmissions
Old 07-10-2009   #1
My System: ClarkeTech 5000C
I urgently need Flash Dump file for ClarkeTech 5000C. My receiver is dead and flash must be reprogrammed. Tried to download the firmware with RS232 but didn't worked. No lights on front panel.
Does anyone have flash dump file or any idea where I can find it?
I will very much appreciate your help. Thanks
erhano is offline   Reply With Quote
Old 07-10-2009   #2
Amo Amas Amant Admin
Topper's Avatar
Hello
Welcome to the forum
I suggest you google for ClarkeTech 5000C and follow the links there. it would appear to be a satellite Combi unit presumably that is why it has a C suffix, it does though sound like you need a jtag to fix it
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 07-10-2009   #3
Robbo's Avatar
Real name: Mark
When trying to reflash it using RS232, did you start the loader with the box off?.. then turn the box on.
If not, try it, it might bring it back to life
Old 08-10-2009   #4
BombedOne's Avatar
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc.
first, try to load boot_7109.stb via RS232, if successfull, then try the original firmware.
Regarding JTAG, as far as I know, there are no JTAG solutions available for STb7109, except evaluation kit from STmicroelectronics, which costs around $1500..
BombedOne is offline   Reply With Quote
5000c, clarketech, dump, flash, needed
