My euro1080 card stopped working...For all (Non Sky) HD receiving equipment discussion and where to find the transmissions | |
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. |
about 3 weeks ago, but I had no time to check it carefully. Card is visible in receiver/cams, responses correctly, but does not decodes the channel. I've tried to re-activate it, website says " your card being re-activated", but still, "scrambled channel". Tried to delete/rescan channel. Does not helps. Anyone has any idea? | ||
| Regular Member Join Date: 15-06-2008 Location: Birthplace of Television
My System: Cuberevo Twin HD on a 85cm motorised Fracarro Penta dish. Superior Dark Motor. Inverto BLACK Ultra Single lnb (IDLP-SINL40-ULTRA-OPP) | I know the Diablo cam doesn't open the channel anymore. I suspect they have altered the encryption somehow. I think they have been having some problems, they are down to a single channel now. | ||
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hello! at that time ,the sell the card,the say it should work up to 2012! send mail,to the dutch hq in europe,mail adress,you can find on the quali tv website,they can help you,and response,very quickly! my coleague,in nabour village,has also this card,i wil ask him tomorow,to find out,are other cards also affected or not.! | ||
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | I'm using oficial card, not diablo cam. Yesterday, I tried to re-activate it using website, and it works now ok. | ||
| card, euro1080, stopped, working |
