usign a PC lcd panel for HDTV | |
| Member Join Date: 25-01-2006 Location: norway
My System: DM7020-s |
Hi, Can someone please perform a test for me with their HDMI HDTV receiver and a standard PC monitor? All the widescreen monitors I have found are 16x10 aspect ratio. I.e. a 1920x1200 resolution rather than the HDTV 16x9 or 1920x1080 ratio. Soon as shall be almost unable to resist buying a HDTV reciver. probably a DM8000. However I cannot afford to buy a 1080p HDTV yet so was thinking about a 24inch lcd flat panel PC monitor. I was wondering how the display would work out, and also if their are any HDCP issues. I know that you can get LCD panels with DVI WITH HDCP so it should work. Anyone got one? Anyone getting a nice picture on the cheap? Thanks, Stvy | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
