EXPRESS 40 EAST (mpeg 4)For all (Non Sky) HD receiving equipment discussion and where to find the transmissions | |
| | #26 | ||
| SatBeams Join Date: 13-07-2005 Location: EMEA
My System: DM800, Kathrein UFS 910, DM8000 (testing) ChannelMaster 120 + Triax TD110, 4/5W-5E-9E-13E-19E + 23E-28Е-40E-53E 40E Ku and C-band :) | It was possible to receive Russian channels with high SR 44950 with Fergusson 8800 and Homecast 5101. Now they have moved to different transponders - 44967V 20000 3/4 (very weak signal) and 44995V 20000 3/4 that makes it possible to receive them with about any MPEG4 capable receiver. Both are still DVB-S! I guess with 1m50 dish it is possible to get both in the UK though good 1m20 may actually work too! Best regards, Alexander | ||
| | #27 | ||
| Super Moderator Join Date: 01-06-2004 Location: Here again
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Signal is there alright, just needs another 5-10% or so to get a picture This 'European beam' footprint is nothing like what's actually there. Will have another look this evening. L. | ||
| | #28 | ||
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hi! here,in Austria,i have pointed i singel 1,50 M Irte Fullsize Dish,in my garden,for this transponder! now,the transponder,has more channels,on it,hd tv promo is switched of,when the starts,not so many channels was on it,and signal was stronger,now it is splitted,and signal,is weker now 1,50 m ,is the minnimum size,here,works every thing perfekt with my homecast hs 5101 that has very sensitive tuner! but,you must point your dish,very exactly,need over an half hour,for this transponder,esapsely the scew tilt of lnb,same problem,then on the turkey east beam,that i can catch,with my 2,20m,tagra dish,since 3 days,picutres will follow this days! hellas east beam,also very low,since simbolrate change,of the package,can you reveive it in uk? | ||
| | #29 | ||
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | 1.20 m,is not enough,and also the gregory,i have interruptions! 1,50m okay! | ||
| | #30 | |||
| Member Join Date: 28-01-2009 Location: Kent
My System: 2 fixed dishes 1 on 28.2 and 1 on 13 east | Help !!!!!!!!!!!!!!!!!!!!!!!! Matt | |||
| | #31 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | You already have the answer in post 29 - bigger dish required | ||
| | #33 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Turok is in Austria, so start thinking at around 1.8m - although it could be bigger | ||
| | #34 | ||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | Even while being in the official coverage area of that sat, I can receive only 10995V (and signal strength not so great) using 1m dish now. 2 years ago I was able to receive both of these mpeg4 TPs with better strength using 90cm dish. | ||
| | #35 | ||
| Member Real name: Sergey Join Date: 15-03-2009 Location: UK
My System: Fortec Star Lifetime Classic | I was dreaming to get the channels from this setellite as well. I had 90x105cm dish that shows up to 49% quality on MPEG4 encoded channels. Sometime I could even see images from this programs. I replaced dish with slightly bigger dish 105x115cm and it still stays the same below 49% quality. Is the next step to buy much bigger dish? Does somebody here had any luck with this satellite? I could see 3 or 4 progrmas from this satellite which are MPEG2 but as soon as it is MPEG4 thn the quality becomes low. Is that because of encoding or transponder are weak(in that case why different programs from different transponders work OK in MPEG4)? | ||
| | #36 | ||
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | No. The channels sent in MPEG4 are from some premium package, not available FTA elsewhere, so power of them is reduced deliberately, to avoid copyright issues. | ||
| | #37 | ||
| Member Join Date: 27-04-2009 Location: Malta
My System: Dreambox 8000 HD Dreambox 800 HD Clark Tech 5000 HD EchoLink 700FTA | I just saw this thread today (didn't notice at first that it was started way back in 2007) anyway I entered these two Freqs (10967 V & 10994 V) in my Dreambox with a 1.2 M Dish and I got these channels quite well albeit with a low signal level of 32/33 SNR. Now my location is in Malta... and I don't know if these Channels will stay ok during the whole day....because there were instances where Channels with a low Signal Level will fade in the evening or vice - versa. These two freqs carry channels like: TELENYANYA, RFL SPORTS,HOME, KULTURA, DOM KINO, DUBL-4, GROSNY, 5 KANAL, 1 MUZ,MIR, Etc Etc Etc. | ||
| | #38 | ||
My System: Dreambox 8000 HD Dreambox 800 HD Clark Tech 5000 HD EchoLink 700FTA | Futher Info.... up to now these channels are ok......BTW Channel Orbita-4, and Kanal 1 are screening King Kong (Latest one) | ||
| | #39 | ||
| Member Join Date: 19-03-2005 Location: Scandinavia 63N 21E
My System: moteck sg2100a rotor. 1,3m dish. inverto lnb. ipbox 900hd. 1,5TB eSATA hdd. | 1,3m dish with inverto LNB in 21E 63N Finland. Ipbox 900hd with conexant tuner. Manual scan of 10995MHz on pos. 40'E gives 15 channels. MuzTV, TNV, Home, TV Centr,RTR Sport, 5 Kanal, Mayak, Radio Rossii, Radio Vesti-FM, Novy Vek etc.. All loud & clear. BER 0. | ||
| | #41 | ||
My System: Fortec Star Lifetime Classic | I have got myself 1.8m meshed dish with 4 petals. Managed to get those transponders but quite on the limit of stability. Possibly further fine adjustment of the dish would help to get more stable picture. Do not know what sort of offset dish we might need here in Uk to get it stable. I believe something bigger that 1.2m good quality dish wold be enough | ||
| | #42 | ||
| Sat Freak Join Date: 05-05-2005 Location: javea,costablanca..ESPAÑA
My System: Motorized Gibertini OP150 ,Motorized Fibo MF90, 2X ASC signal 1.20 on stand by,ASC signal 1.80 ,Famaval 1.80 , 60cm eliptical raven ..hirschmann fibre glass 1.20m....and more gadgets | those channels could be open using an NP4 viaccess PCMCIA Module on a normal DVB-S receiver ,so its not an obligation to have a HD-BOX for those channels | ||
| east, express, mpeg |
