Humax HD - which box to get?For all (Non Sky) HD receiving equipment discussion and where to find the transmissions | |
| Regular Member Join Date: 16-12-2002 Location: Ireland
My System: DB 7020 250GByte HD - Manhattan 100HH -1m LH dish <Network>Netgear WGE111 to Linksys 354 G router <Software> FW Pro, Dreamboxedit and Gemini 3.40 USB also using PC with Skystar 2 and DVBDream |
Hi, Can anyone tell me the difference between the Humax HDCI-2000 and the PR-HD 1000? I'm looking for a receiver for a Premiere sub that will also cover FTA HDs. Ideally I would upgrade my Dreambox but the release of the new HD model still seems a long way off. Do any of the Humax models have a built in PVR like the Dreambox 7020. Thanks, | ||
My System: DB 7020 250GByte HD - Manhattan 100HH -1m LH dish <Network>Netgear WGE111 to Linksys 354 G router <Software> FW Pro, Dreamboxedit and Gemini 3.40 USB also using PC with Skystar 2 and DVBDream | Is there a better value receiver to consider? I see there are a few others mentioned. | ||
| | #3 | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed |
I think the manual is only available in German too. Maybe better to get the HDCI2000 ![]() Llew | |||
| Regular Member Join Date: 01-05-2006 Location: yookay
My System: Nothing at the moment until I find a remote for BigSat 6600CI. Pls see if you can help! | Personally I like Topfield 7700 but expensive. Cheaper one is Foretec Star Passion. Maplin is selling for £149. Please look at the link. _http://www.maplin.co.uk/module.aspx?ModuleNo=99265&doy=search | ||
| The Following User Says Thank You to good2talk For This Useful Post: | rato (07-08-2007) |
| | #6 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Up and down like the stock market that one. Fourth price change since it appeared if that price is correct. I bought mine for £199 on the cusp of it dropping down to £149 first time around ![]() Good value though, if the software delivers blind search and 4:2:2 eventually. Llew | ||
| | #7 | ||
| Member Join Date: 22-05-2003
| PR-HD1000 is the same as the HD2000 except in addition it has a Nagra2 card slot embedded. Great for German Prem*er*. Works well also with Diablo & TRex cams. It does work with BBC HD. I have not seen a better HD picture than the 1000 produces. The 2000 manual covers everything the 1000 does except the N2 card slot which only comes into play if you use a N2 card. | ||
| box, humax |
