premire sport portal helpHigh Definition Humax HD satellite TV receiver help and support forum. | |
| Member Join Date: 10-04-2007 Location: hull city/uk
My System: pace ds810xe /manhatten st-200 /tecnomate 1500+ super /65cm traix dish on a satcatcher motor /1 x trex twin cam 1x dragon twin cam duolabs cas3 programmer and diablo cam light | how do you get the football from the premire sport portal on the humax hdci2000 and yes off course the blue movies i have a diablo cam i tryed all buttons to access them | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | I'm using Stealth 2.37 in my Diablo, and can clear the Sport portals no prob. N2 AU on in cam configuration. Llew | ||
My System: pace ds810xe /manhatten st-200 /tecnomate 1500+ super /65cm traix dish on a satcatcher motor /1 x trex twin cam 1x dragon twin cam duolabs cas3 programmer and diablo cam light | i get the portal thats working it the exras like the pay per view stuff whats on the screen .. i know when i had a pace hd box you pres a certain key which was opt or 0 and it brought up a list off them | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | You mean you don't have Sport 1, 2 & 3 in your channel list? h**p://laurals.net/ has a channel list with those channels included (DiseqC 1.2 version). Or if you want the fixed dish version, I have uploaded one in an earlier post here. These are for use with the 0.15 Firmware version. Llew | ||
| The Following User Says Thank You to Llew For This Useful Post: | jasonx2007 (06-03-2008) |
| | #5 | ||
My System: pace ds810xe /manhatten st-200 /tecnomate 1500+ super /65cm traix dish on a satcatcher motor /1 x trex twin cam 1x dragon twin cam duolabs cas3 programmer and diablo cam light | works a treat thank you .. great channel list love it | ||
| | #6 | ||
| Regular Member Join Date: 10-03-2008 Location: Cheshire.
My System: Topfield 7710 HD PVR, Humax HDCI2000 HD Triax 1.1m (on 0.8w), Orbital 80cm dish with 3 LNB 13e, 19.2e and 28.5e 4/1 way diseqc Cas 3+ Diablo 2.3 & TRex 4.6 Rover SDM2 | Just to say sometimes the sport portal has about 10 alternatives some of which appear in the place usually occupied by the Prem Direkt slots, I just go through them all till I find which one is which, probably should have written a list, maybe next time. | ||
| | #7 | ||
| Regular Member Join Date: 19-11-2007 Location: South Italy
My System: Fortec Star Platinum 2 CI slot + embedded., Sat+ FTA, HP NC6000 Laptop1.6gig,Time Athlon XP2400mhz Desktop. 80cm dish, twin LNB for Hotbird 13e,Astra 19e. 2nd 80cm dish and Sky Italia system. | If you visit the Premiere Germany homepage, click Programm and look low down on the page, you can download the Premiere DesktopTV Guide 1.0 program. It's in German of course, but if you don't have EPG on all the channels, I don't, you can use the program to find out what's on when. You download and install, then take an update from the web which gives you channel info for the next 2 weeks. Taxes your German translation a bit, but once you figure it out it's a good tool! For example, if you want to watch a movie on Direkt, you call up Direkt and double click on the movie you want to see. This brings up a panel describing the movie. Click on the tab at the top of the panel "sendetermine und formate", and it tells you when that movie will be shown at different times on that day. Then you search the direkt channels to find the movie. Main panel shows program info and times for 1,2,3 and 4, and all others in the package, including sport. Hope this helps, enjoy! | ||
| Last edited by perthkenny; 12-03-2008 at 09:57 AM. Reason: location of download on page changed | |||
| portal, premire, sport |
