Humax ICORD & Moteck DiseqC 1.2 MotorHigh Definition Humax HD satellite TV receiver help and support forum. | |
| Supporting Advertiser Join Date: 22-10-2007 Location: Colchester in Essex
My System: TM6800 HD Super+, TM5400CI, Triax 1.1m Dish & Moteck Motor, also Triax 78cm Dish with Moteck motor. Global Single LNB, Ice Quad LNB. |
Hi wonder if anyone has had any issues with the Icord & a moteck 1.2 motor. We have a customer who had motorised setup with an MVision which was working fine but they wanted us to put in the Icord for them. Setup all the satellite settings in the menus, got 19e/16e/13e/1w all in and scanned and initally seemed to be working fine when changing channels between the sats. But then i noticed an issue with 16e, 95% of the time when we choose 16e the motor just sits there and doesnt move. going between 19e/13e1w all seems fine, just when you select 16e nothing happens. when i go back in to the satellite edit positions and choose 16e the dish moves to the correct position, its just doing it when choosing a channel from that sat list. Any ideas apart from doing a factory reset on box and motor and trying again ? Got version GXLSCI 1.00.13 on the Icord at present. | ||
| www.cdtronix.com Tel:+44 (0)1206 825155 Sky, Freesat, Dishes, 0.1db LNB's, XXX Viewing Cards, Cams, Quality Coax Cables | |||
| Design Engineer/Installer Join Date: 08-08-2007 Location: Central UK, E Cheshire ..near Jodrell
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... | is USALS selected on 16e not diseqc 1.2 otherwise.. I'd put in a lot more sats and see if it does it elsewhere.. | ||
| | #3 | |||
My System: TM6800 HD Super+, TM5400CI, Triax 1.1m Dish & Moteck Motor, also Triax 78cm Dish with Moteck motor. Global Single LNB, Ice Quad LNB. | Was just wondering if anyone else has had any issues with these boxes & diseqc motors. cheers | |||
| www.cdtronix.com Tel:+44 (0)1206 825155 Sky, Freesat, Dishes, 0.1db LNB's, XXX Viewing Cards, Cams, Quality Coax Cables | ||||
| diseqc, humax, icord, moteck, motor |
