Humax icord motor control problems.High Definition Humax HD satellite TV receiver help and support forum. | |
| Member Real name: john Join Date: 07-05-2009 Location: Sussex
My System: Self installed 2 antenna (90cms)...1xfixed Hispasat..1xEutelsat/Astra etc(HtoH)...iCordXcr....Panasonic TV Xcr | Hi Folks........re iCord Xcrs Current rev level(GXLSC1 1.00.16) ......There is comment to be found in two forums re DiSEqC control signals not working.I would appreciate any info on the following:- (1) Has anyone made a Vee Box positioner......DiSEqC input/36volt dc o/put respond to the iCord DiSEqc control?...... How do I change sat positions at present..........manually via the Vee Box remote. (2) If you look at the spec for an iCord (160) in my case, it states for DiSEqC o/puts versions 1.0 1.2 USALS etc. Vee Box spec states works with controls 1.0 and 1.2...... 1.0 is for up to four LNB selections; 1.2 is for DiSEqC motor control.........plus USALS. All sounds as though it may work; but does not. If you look at the iCord satellite set up menu there is a DiSEqc "box" which gives the following availabilities......Disable..Tone Burst A..Tone Burst B..DiSEqC A; B; C; D...For LNB's ???.......DiSEqC A;B;C;D; all with a (2.0).......meaning DiSEqc version 2.0 for motor control????. (3) Has anyone any idea why when the iCord is in standby at random it performs a "System Check" more times than seems reasonable? This is giving me problems elsewhere on my system, which at present I'll not bore you with!! | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | What are you trying to control the V-box with? Disecq1.2 or via USALS. USALS doesn't work with V-boxes. Also, you will also have to tell the receiver that you have a motorised dish not a FIXED dish I woul have thought. (As per the manual) _http://www.humax-digital.de/products/new_manual/iCordHD_100GB_M.pdf | ||
My System: Self installed 2 antenna (90cms)...1xfixed Hispasat..1xEutelsat/Astra etc(HtoH)...iCordXcr....Panasonic TV Xcr | Hi Robbo and thank you for your quick response to my DiSEqC query.........I went through the set up routine again, for a motorised dish for the" Nth" time and for reasons other than previous "finger trouble"; this time the process WORKED on all the sat posns: I use.........Thanks to for the info: re USALS...........I was not aware that the system does not work on Vee Boxes. If any info: re "System Check" comes to" light" in the future I would appreciate the details...........Kind Regards John | ||
| punjetas |
