Morning, a couple of weeks ago I had my 80cm dish motorised. Everything was ok up to this morning. I was trying out a channel search on Eutelsat W3. I got a few channels which I then saved.
I went back to the sat list using the yellow button to find that there was nothing else on the box. ALL channels gone (Hotbird,etc)
I did a couple of searches on Hotbird, Astra1 etc but found that the box completely froze up when I tried to save the channel search, either at the start of the search or part way through.
I've had another look on the yellow button and found that Astra 1 has been saved also.
Another search on Astra 2 done with same result, box freezing on "saving results".
I have tried turning the box off/on.
Any help much appreciated. |
