Humax ir-hd1000High Definition Humax HD satellite TV receiver help and support forum. | |
| Member Join Date: 14-10-2005 Location: .
My System: 12 Feet "C' Band dish, and 90cm offset "Ku" Band Dish,Nokia Mediamaster 9200S Receiver with DVB2000 software,Metabox-1, HumaxVACI-5300. |
Dear Members, Your comments about the worthness of HUMAX IR-HD1000 are requested. | ||
| Member Join Date: 23-01-2005 Location: Manchester, England
My System: Kaon,Vantage,FortecUltra, qualitvHD, Humax1000HD receivers.Vbox, CM 1.2 dish, 1224HH mount,c120 lnb with CM feedhorn. | | ||
| | #3 | |||
Thanks for your reply. Are you using Humax IR-HD1000. Or if you know about it's perfomance, please tell me about that Receiver. Sorry for my poor English | |||
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hello! it is a very good receiver,and it will receive,a software upgrade in the future for hd+ but only usable for the german channels! the only bad thing is that the memory is strictly limited,after searching a 3. satellite for example astra Hotbird,and then nilesat,the receiver says then in the middle of the search memory full,when more channels are in the list,zapping is a little bit slower! power supply the already known humax problem,can be gone without further notice..! | ||
| | #5 | |||
Thanks for your reply. Is the receiver can be usefull in asian region | |||
| | #6 | ||
Dear Members, Please inform me the up & down grades of the receiver HUMAX IR-HD1000 other than mentioned by Mr. Turok. | ||
| humax, ir-hd1000, irhd1000 |
